Made these for Pops for Christmas. He has some of those Nocona suspenders and they are really heavy.  These are 1/3 the weight.  I put the cheap spring latches because of weight. They are 4/5oz. HO lined with the thinnest veg tan I've ever seen. I bought it to make the inside of wallets. I would like to know if anybody knows how to keep the slide buckle from moving every time the elastic stretches. I had his other ones to measure so I know the shortest length. I put the slide buckle all the way to the bottom so it couldn't get longer. You can make them shorter if they stretch.
Lookin good . . . I tossed the idea of elastic . . . my buddy and I both wear solid leather suspenders.
Don't have a problem once that "fit" size is found.
May God bless,
Dwight
www.dwightsgunleather.com
Beautiful work!  Batz Corp sells stainless steel and brass trigger snaps that are a step up from zinc diecast, but maybe not with the slide for the elastic band.
  • CFM
yup what Dwight said!! My pair also has no elastic you don't need it if they fit right. your tooling is out of this world btw.
Wow, that is some fine tooling. Looked like it was a fun project.  I'd go with the leather instead of elastic as the others said.
Beautiful.  I may have to look at making myself a set one of these days.  And your stitching looks pretty awesome also.
    /dwight
very nice work:You_Rock_Emoticon::thumbsup:
Very nice! I made a pair of plain ones just to get the process down. Going to have to improve my tooling!
Not so retired RN. Living on the Washington Peninsula.
OUTSTANDING !!!!
I’m a real old guy. I’m hard to impress. But you have done it.
a simple design,  done flawlessly.
VERY nice work!!
I’m truly impressed!
Joel
Edited by GrampaJoel
