Thanks but that does not answer the question, its not if you like the machine or not, that's like asking if you like a ford focus over a BMW.
Its about if you can tell the difference in a blind test (not knowing who made what) of the stitches.
Mi omputer is ot ood at speeling , it's not me
  • Replies 119
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I don´t think you can when your knot is properly balanced in the material and you are using the same thread and needle in either machine. A 301 stitch is a 301 stitch. A singer 111 stitch line will look the same as a Pfaff 145 or Adler 67 stitch line for the same reasons. So when someone says this or that machine makes a beautiful stitch... - hell yeah - why should it make an ugly stitch? Proper machine adjustment and the choice of thread and needle and the material you are sewing are the key factors for a good looking stitch line. Machine poorly adjusted or the wrong needle or thread combination for the chosen material can make a stitch look ugly but not the machine you are using - as long as it is properly adjusted / set up for what you want to sew.
  • CFM
 It will give you a nice pretty even stitch line that has the top and bottom stitches snugged up tight with the correct tension.
for about an inch or 2  it is a shoe patcher. it will NOT  sew a belt, It will not sew a holster, it will not sew wallets  after a inch or 2 You will have to stop and tinker with the damn thing because
again. It is a SHOE PATCHER  It is designed to sew a couple of inches to patch a shoe.
I have one, I even have a servo on it.  I have not FINISHED a project using the patcher.
Please fgeel free to buy one and make it run like a Porsche
here is the best advice i can give you if you buy one.  go on youtube, seek out MANLY ACRES
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
I don't have one and not looking at buying one
I don't expect a high cost industrial machine to be as reliable as a domestic machine
What i do expect is not the bullshit from people who have heard of them but never owned them, who crucify them out of hand as crap; and people should by something the seldom use at a price they cannot afford
If you find you cannot do more than a couple of inches or it needs constant adjustment that's fine you have one and speak from experience, but others have also stated once set up they are fine, so maybe both are right. there are plenty of comments on here about Industrial machines that wont work properly
so is the finished stitch good or bad thats all I asked
I had one, I bought it when I had a particular need for a transverse-feed machine. I was hoping that I could modify and dedicate it to this task. While waiting for it to arrive I found a real transverse-feed machine.
I wasn't impressed with the patcher, though it did sew within certain limits. To give you an idea of the quality only half the supplied bobbins fitted the shuttlehook. Two bobbins still had the lathe swarf wrapped around them. When I turned over the machine sand from the mould fell out. The thread tension nuts were just plain steel hexnuts with no provision to stop them vibrating loose so the tension changed as the machine sewed. Their coarse pitch made it difficult to get the tension "just so" when working with less-forgiving combinations of thread and leather. I can't remember if the stitch length regulator (a plain steel set screw) had a jam nut or not, but that would self-adjust too. IIRC there was no way to adjust foot pressure or slip the presser bar to adjust its height.
Why do some people think these machines are fine and others junk? Well see my above comments of inconsistency -- Person A gets a lemon and Person B gets one that works out the box. What are going to be their conclusions? Person C has the skills, tools and willingness to mend and modify the machine to do what they want, Person D wants/needs it to work out the box. Also different people have different thresholds for "good" vs "junk", especially if they've never used a real industrial machine before. Some people seem to be happy with extravagant workarounds and limitations to use these machines. I'd rather saddle stitch everything.
Is the finished stitch good? Let's just say I wasn't happy enough with the consistency and appearance of the stitch that my machine produced to put my name on it. I've not yet seen any examples of work that have disabused me of that impression. I used mine for a few repairs where I had no other option (you know, being a patcher machine) and sold it on. I haven't mourned its absence.
Is this the type of machine youse are discussing?
I was thinking of buying one.
Just cos I think its rather an antiquated & basic look which I like. I doubt I'd do any real sewing on it anyways.
I can get this off ebay.uk, UK stock, for about £60 delivered
Yeah, it is the abomination we are talking about.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
I've looked at these off and on for a while now, yeah I'm guilty of not owning one.  As someone doing typical hobby/personal varieties and quantities of products, I've concluded I can get a lot of hand stitching done in the time I would probably spend fiddling around with one of these Rube Goldberg machines and it will look much better.  Until some outfit puts out a decent hand crank machine priced for the hobbyist, I'm a hand stitching.
  • CFM
I trust Frodo's impression of it!  But I've been on the fence as well. My problem is I want to buy it more for the idea of getting the piece of crap to work than to sew with it. I'm not gonna waste expensive leather on this i make to many mistakes already.
That is the China Patcher, guaranteed to provide untold enjoyable hours as a Tinkers Delight.
kgg
