Everything posted by rmr
Many years ago I had one- it is certainly quicker than hand stitching. Mine was very problematic- I had a heck of a time getting it "tuned" just right so it wouldn't miss stitches. Then if you changed thread thickness you had to start all over again. Plus I found with some projects- you need 3 hands to operate the thing- one to pull down on the handle and 2 to control your work. I finally got so frustrated with the thing I sold it and took the funds to purchase a cobra machine- which I found it amazingly easy to learn to use- stitches are better and I cant remember the last time I dropped one. IMO- I would save a little more $$ and move up to a cobra or one of the other similar machines, which work equally as good. There are many out there used these days - it will be worth the investment, learning curve will be reduced by about 90%, you will be less frustrated than with an expensive piece of equipment (boss) that only works so so good luck with your decision
great- I do have that attachemnt
Thank you- I do have a flat table attachment for my Cobra- I guess I need to take some scarp canvas and try it out- it would be awesome if I don't need another machine RMR
I would like to start making canvas duffle bags, sportsman's bags, gun cases... ( like the filson bags) using 18oz canvas- possible waxed canvas- with leather trim pieces. I currently have a Cobra 4 cylinder bed machine and a Cambell Bosworth for my leather work Somewhere I read for heavy canvas that a cylinder bed machine( cobra) will cause bunching of the canvas- is that true?? That article recommended a flat bed machine. If that is correct info- what would be a good machine to be looking at. I have never worked with canvas before. I would probably just use the Cobra machine to sew the leather trim pieces onto the canvas- so I just need something to sew the canvas. Thank you in advance RMR
thanks guys for the reply and advice- sounds like I need to start practicing
I have a range bag I will be sewing around a curved end. The curvature will not allow me to use my cobra cylinder bed to sew very well- I was contemplating using either the holster or stirrup plate . I have never used them- but I remember somewhere someone saying that you need to reduce the tension on the needle thread and will probably need to re-adjust the stitch length. Is that true- or any other recommendations Thank you RMR
Thanks- I will give that a try- I guess I have been ay overthinking this one
I am trying to find a source for 6" long 2 ring binder hardware - I have tried Buckleguy, hardware elf, ohio travel bag....... I have found them online- but you have to buy 50 units at a time- only need 2-3 any ideas thanks in advance RMR
Im getting ready to make a leather cover ( somewhat similar to pictures below- but different )for a fly reel while its on a fly rod. Will be used primarily to transport the rod/reel to and from the river and protect the reel from getting nicks/scratches while in transport. It will be exposed to the elements to a degree ( so might get wet, but hopefully not soaking wet)- its not going to used to keep the reel waterproof Most of the other outdoor products I have made - I have used Latigo. I can use that here also but am having a difficult time locating Latigo in the thickness I desire. I have seen other cases made from Bridle and English Bridle leather . I do not want to use a chrome tanned product because if it gets wet and the chromium slats leach onto the reel or rod they may corrode them. So would you use Latigo or Bridle/english Bridle leather for this project - or other recommendations Thanks for any insight RMR
I have 3 of Terry Knipscheild (sp?) knives- head/round knife, skiver and pointed knife. Have had 2 of them for 3-4 years now- I stop them prior to using them each time to keep them razor sharp- and still have not had to have them re-ground. I ususally am cutting 5/6 or 8/10 oz veg tan, latigo or bison. don't hold off getting a quality round knife because of the concern about having to have it reground RMR
I see the same- Im guessing as its passed through the leather multiple times- it starts to pick up some of the dye, or even oils/waxes in the leather and starts to discolor. Switch to an off white and it will not be noticeable RMR
I have some weaver exact touch edge paint that is several years old now- it has gotten somewhat thick and clumpy- still usable - just not as this as I would like it to be. Can this product be thinned?? I tried a small amount with water- didn't mix well. Thanks RMR
What Is This Tool Called, And Where Do I Find It?
rmr replied to conceptdiba's topic in Leatherwork Conversation
Sorry- was the instrument from post 147- tried to cut and copy- cant figure out how to do that RMR -
Did anyone ever get one of theses units?? let me know how it worked out Thanks RMR -
I just got done with a brief case made from Horween Dublin. I found what imstephenjones recommended plus roughening up the surface that is to be glued with a scratch awl really helped . One of the things I took a while to learn, was when applying products like barge rubber cement ( that is the product I use) -its imperative to make sure the glue on both pieces in dry before compressing the pieces together. Good luck RMR
there is a guy on ETSY( I believe from China or Hong Cong) - selling electric edge creasers for 32 USD. It comes in one size- I have an email into him on how far back from the edge is the creased line. Its not adjustable temperature - looks like a wood burner with a modified tip. The price is right- just don't know how good it will be- trying to get more info on it.
I know many thin down their feibigns oil based dye with denatured alcohol. I just starting doing the same- to make the dye go farther. I did a few tests on some veg tan caps using both light and dark brown as well as mahogany oil dye. Thinned dye ( dye to alcohol) 75:25, 50:50, 25:75. It was really hard on any of the samples ( comparing samples within each color ) I did to tell that there was a difference in the color of the final product once it dried. So My question is- how far do most of you dilute/thin your Fiebings oil based dye with denatured Alcohol?? Im guessing there is an endpoint where there will be a difference in color RMR
Dougster With the amount of $ you have spent there in the short amount of time- if it were me- I would shop elsewhere. Besides- there are far better superior quality suppliers of leather and leatherworking tools out there than Tandy
thank you all for the sources. I guess I should have asked this in the original post- will these gadgets cut nylon thread in the 207-277 size?? and do they provide good security where the thread is cut from pulling back through the hole? Thanks RMR
I have heard that some burn/melt/cut their nylon thread instead of just cutting it- one to prevent it from freeing and two to keep the stitch from undoing itself. Are there better tools than others for this purpose- and or can you direct me to where I may find one Thasnk you RMR
Thank you Paul That is exactly what Im looking for !!!!!
Using Leather Sewing Machine To Poke The Holes In Thick Leather...
rmr replied to thekid77's topic in How Do I Do That?
I do it quite often when doing a box stitch- makes sure the holes are evenly spaced out and on a nice straight line. Its a whole lot easier to handstich a box stitch than trying to use a machine and messing up every other item. -
I just recently received the skiving knife from Knipknives. It feels great in the hand- and so far from what I can tell - it skives much easier and more uniform( for me) than my round /head knives - also from Terry at knipknives
