Everything posted by TomG
What kind of leather and what type mink oil? I've used the Camp Dri Mink Oil Paste and not had that experience. Sounds like you are over doing the oil or oiling an oily piece of leather.
Where To Look For A Good 1" Oblong Punch....any Recomnendations?
TomG replied to thekid77's topic in Leather Tools
Go back to Tandy and check out the economy punch. Their deluxe punches all seem dull, but the el cheapos I've gotten are sharp. Just look through them to find one without nicks in it. Then strop it a little and see how that does for you. Surprising, huh? -
Hey Wiz. Push button? It's a Consew CS1000. It does have the up/down arrows and you set the start speed, normal reverse direction and max speed with the S.1, S.2 and S.3 settings. Is that what you're referring to?
After reading tons of threads and sites on the servo motor mod, and not being able to get a smooth response myself, I did some experimenting. I made a graphic with 3 different black to white gradients. 15, 25 and 30% from the edge. Mine motor worked best with the 30% gradient. I used some thin, translucent plastic from one of the dollar store cutting pad (abt 1mm), about the width of the paddle blade. I printed the gradient on photo, best quality mode. I then used doublesided tape to tape the gradient to the plastic and trimmed. I slid the strip into the photo interrupter and trimmed the strip so that the point at which the motor started was just inside the edge of the strip. I then tape the strip at right angles across the paddle. Setting the motor speed to 10 and the start speed to 9, I was able to adjust the strip and paddle for a smooth, full-range control. I'm attaching some photos and a JPG of the gradient. Hope it helps some of you.
Like chrstn53 said, they make a plastic tool for holding pressure on the smooth side. I think it's actually made from Delryn, but could be wrong. OTB carries them pretty cheaply. It's better than no tool at all and I do use blue Loctite.. Sometimes the red if I don't ever want them coming out... Here's a picture. Not as rugged as the Weaver version for sure.
Lots of folks use the modified arbor press for stamping, etc. Are any of you able to share photos of the work surface and any guides that you lay the leather on? I am struggling to find a way to lay my straps down and move them consistently to stamp names, etc. Thanks
There is a servo motro out there - I think it's a Consew 500 - That uses a Hall Effect transistor. These are actually a semiconductor that energizes with a magnet. So, it's either on or off. You can't do variable speed with those via the foot pedal. The ones with the optical controller, like the one on the video, are able to be variable speed. I Think the COnsew motor I got to replace the hall effect one is a 550 or 1000? I'd have to look. I will tell you that the paper vane didn't work super well. It was fine at first, but as it sagged over a short period of time, it's range and control points changed. One of the isses is that the light on the optical interruptor is way too bright. It makes the control of how much light hits sensor very touchy. And it is so bright that a piece of paper with pencil marks doesn;t work. I used a piece of plastic gift card I cut into a ramp and played with that with some success. I ordered a couple of replacement vanes and did some cutting and filing, but although I did get a variable speed, it was still too touchy for my tastes. But it at least made it consistent and I didn;t have to worry about the paper sagging. Still better than the clutch motor.
Yes. But you have to have an account before you can see the order system. It's not your standard on-line shopping cart system. You have to have your item numbers to put in or you can look up items. I generally open a catalog on one screen and the order screen on another and Ctrl-Tab between the 2. So, if I am ordering say C-54 buckle, and type that into the Item lookup box, it will show me all items with that and I can select the ones I want, one at a time. Not the most efficient way, but it works. And they are great to work with.
Dodgy Finishing Aka Leather Conditioner
TomG replied to Yaakovjt's topic in Leatherwork Conversation
Tandy carries it. But after the suggestion from many on these forums, I have just switched to acrylic floor polish (without cleaners or ammonia) diluted 50/50 with water. I actually like it better than the resolene. I apply it with a soft rag. But others apply it with foam brushes, trimmed shearling and other applicators, If you do a search here for Resolene or floor wax, you will find a ton of threads on how to use it or apply it. -
Well, I've never experienced this exactly, but I use a totally different technique and process. Well.. I lied... I did see something similar years ago when I was experimenting with stuff. I applied some mink oil to a piece of raw leather. It sort of looked this way, if I remember correctly, and all I could figure is that I was applying it unevenly. I never did figure out how to do it properly. As I would try to even it out, it would get darker and darker. I'd take some scraps and try applying the conditioner using different techniques and applicators.. maybe clip some sheeps wool short, or a soft rag or one of those wax applicator pads they use for car wax. Hopefully, someone with more experience than me will pipe in and be able to shed some light on it. As for the Satin Sheen... it is water based and most folks shy away from it.. not all.. but a lot. From all I've ever read here and elsewhere, Resolene, or acrylic floor wax diluted 50/50 with water is the preferred product. I found the reference guide from Tandy. It's a free download and I'm attaching it here. But it's not actually the one I was thinking of. But it might give you an idea of what's compatible... If I find the more extensive one, I'll let you know. It might be in one of the coloring and dying books I read back when. Later Eco-Flo-Leathercrraft-Dyeing-Finishing-Guide.pdf -
Did you dye it first? With what? What sealer? Satin SHEEN is not a real sealer. What conditioner? All products do not play well together. Tandy has a chart somewhere of what works with what... -
Best Way To Apply Fiebings Edge Coat Cleanly?
TomG replied to Colt W Knight's topic in How Do I Do That?
Weaver has a box, but it's probably expensive. And if you don't use it a look, it's probably too much effort to empty and clean between uses. I've gone to Fiebings edge enamel and apply using a ladies foam tipped makeup applicator. Since I use Leather balm with atom wax as a top coat on the surface is the leather, I found that if I have an Oops, I can quickly wipe it off using a paper towel. -
Ohio Travel Bag is my go-to place. I wouldn't use the watch strap bands. That removable pin in the ones I have won't hold a whole lot of sudden impact like a dog tugging a leash, IMHO...
Maybe try leaving off the tankote on the flesh side and just use 3 light coats of Resolene.
Work outside. Brush off what you can. Wipe down with a mixture of lemon juice and water. Rinse in clean water. If it's dirty, use a cleaner like Lexol. If still stiff, some NFO might be in order
Been Looking For This Hardware Everywhere And Can't Find It
TomG replied to bylinesupplyco's topic in How Do I Do That?
Why not try laying it flat on th e stone or anvil when you set it, instead of in the domed holder. Tom -
Well, first, your edges themselves look a bit ragged. You might try a burnish first. Make sure your bit is sharp. Burnish the outer cutting edge well. Use firm (not hard) pressure on the blade and on the guide. You might try cutting a small piece of silicon paper and putting it between the piece and the slab. Then place the edger and guide in position and rotate the leather and keep the groover steady. You may want to take a couple of passes to get the depth you want. The leather looks soft. if it is moving as you cut, it's gonna look ragged. You have to keep that edge from collapsing. If you can't, I'd dump the guide bar and use a small French curve to cut against as a guide.
As I mentioned, I have NO experience with it... But from what I was told, it has a lower working temp than Kydex. An isn't Kydex fixed once it has cooled? Can you heat it back up and rework it?
Here are a couple of items from Staples. Apollo Audio Visual Transparency Film for Laser Printers , Clear http://www.staples.com/Apollo-Audio-Visual-Transparency-Film-for-Laser-Printers-Clear/product_829903 ************************* This is a Write-On film but says it needs special marking pens... Didn't see those listed, but I only did a quick search. Apollo® Write-On Transparency Film, Clear, 8 1/2"(W) x 11"(H), 100/Box http://www.staples.com/Apollo-Write-On-Transparency-Film-Clear-8-1-2-W-x-11-H-100-Box/product_APOWO100CB Good luck
They make a laser film. Just test for shrinkage. the older stuff used to shrink about 10%. And check your settings for a Label setting on the printer. Older printers had fusers that got too hot for the film and could actually melt it.
If you have a scanner, scan the paper pattern, then print on inkjet transfer paper (Tandy, Staples, etc). Perfect transfer... I haven't used these films, but we do screen printing and use a transparent film for making our screens. We have 2 types of film. Waterproof and non-waterproof. One was for use with the older dye-based printer inks and the other used for the newer pigment based printer inks. I'll be at Tandy Monday and if I can remember, I'll see if they have a scrap of the film and I'll draw on it using different inks I have, I have sharpies with regular ink and with oil-based paint, a couple of Molotow pens and a couple of others with India ink.
I saw this just this week. The folks at my Tandy said it's pretty neat stuff. BUT... It is remoldable thermoplastic. In other words, if you leave that nice mask in the car, you will come out to find a mess. If you use it as a bag stiffener, and leave it in the card, you may come back to find it molded in the shape of the contents of your bag <g>... Maybe it's my lack of imagination, but it seems to me the only real use for it might be as stiff templates and them melt it back into a sheet for the next one...
Ahhhh.. Don't you just love guilt
