Ferg
Contributing Member
Everything posted by Ferg
  1. I use photos of product, mostly old, to get an idea of how things are made. I then do some measuring of the subject, make a heavy paper prototype and go from there. Ferg
  2. Excellent design, construction, and carving. Ferg
  3. I Bought a used but very good "bottle jack" press last year that was already modified for clicking. I replaced the hydraulic jack with an air over Hydraulic 20 ton jack. I click with mostly steel rule dies I have made. The dimension between the steel plates on the press is very consistant so I made "stops" so the die doesn't bury itself into the cheater plastic board. I quite often want to click a number of pieces from same set of dies. For each cut I stack several pieces of leather so I can cut them all at once. I can click a half dozen pieces with no problems, taking about 30 seconds. BTW: It would be great to have a good sized clicker but my set up cost me less than $200 and suits me just fine. I also have a pancake compressor dedicated to the press. When I am not using the press I use this compressor to keep the multitude of tires on equipment I have, "Pumped Up". Ferg
  4. Al was 44 years old when he and Ann married. They were very busy and perhaps they didn't wish to have children or just possibly they simply could not. Ferg
  5. Note my two words inside Parenthesis. Ferg
  6. The Q-tips would be shot and lose cotton before you got around a wallet I'm afraid. (Just kidding) I realize many folks are trying to do leatherwork as cheaply as possible if for no other reason than the fact they are just beginning their fabulous journey with leather. When I was beginning, almost 65 years ago, I wanted to buy the best tools I could possibly afford. When learning to do edge painting, spend $20 to $25 for a tool that is made to work perfectly for this application and save yourself a million dollars worth of aggravation. Ferg
  7. Jakob, That is a "Zig-Zag" stitch. I don't know of a reason for using it other than it looks neat and different. Your machine may not be "Zig-Zag" capable. Ferg
  8. Photo of your work would help. Ferg
  9. I could be mistaken but it seems when I ordered from these folks and seen how much the shipping was I questioned it. Was told their program doesn't figure the exact ship cost, they will reimburse any difference. Remember, I am not sure it was these folks. Worth it to question? Ferg
  10. Additionally: Keep an old toothbrush handy, at the sink, if you are edge painting a fairly large piece, the paint begins to gel on the roller before you are finished. Secondly: A small container of water setting close by on your workspace will come in handy if the paint is beginning to get a little sticky on the applicator. Make sure you have some clean paper towel handy also, it will be needed to dry off the water left on the applicator before you put it back into your paint. Ferg
  11. I am curious, have you used the tapered applicator from Tandy? Ferg
  12. The tapered roller tool is the best I have tried of all the tools. I have no experience with the Edge Kote. I have Fenice and Giardini. My preference is Giardini. Lekoza has some colors of the Giardini and it is not expensive since it takes very little to do edges. The tapered tool allows application without the paint running onto the surface of the leather. As usual it takes some practice. Ferg
  13. Why don't you get some white Doe Skin, laminate it to a heavier piece of veg tanned natural/or other, stitch and no paint to mess with. Ferg
  14. Ray,
    You might just like to look at some of the work Keith does. Not trying to promote him.
    He has orders backed up for 6 months to a year.
    www.kbgrips.com
    Ferg
    1. raysouth
      raysouth
      Thanks Ferg.
      I will have to go there and take a look.
      Love to learn and see what others are doing.
      God Bless.
      Ray
  15. Ray, My son-in-law makes/sells wood grips for hand guns. He has told me in the past you need a license and whatever that includes to ship fire arms. Ferg
  16. Don't let them bug you!!!! Ferg
  17. Wiz, You need to add that machine to your arsenal. I can see it now, resting in your shop. LOL Ferg
  18. First note: You can get a spray at Jo Ann Fabrics or Walmart for instance that will retard the fraying when you punch holes. If you have an edge/exposed, you can do a "Lap Over Seam with the fabric held inside the leather. Glue the fabric first then do the seam. You can create the same if you are making a pocket for a purse or similar article. Glue the edge of the fabric to the leather after using the "Fray Spray". Ferg
  19. You must have a bad day about every other at least. LOL Not Sandy! I have done/made thousands of things while I was a building contractor for so many years and then as a manufacturer of wood products. Half the equipment in our commercial shop was either made by myself or modified by me. I have an insane desire to learn how to do everything there is to know about everything. No exceptions. I don't worry about what someone happens to make for a living if I can learn to do it I will learn a better way, that is just the way it is. Ferg
  20. From the info I could find it is not a Clone but an original. HERMAN KOHLER. Ferg
  21. I have an idea the folks doing the writing for Weaver's wouldn't know the difference. Quality checking?????? Ferg
  22. WIZ, I hope your rented shop is bigger than the trailer. Otherwise you wouldn't have room for all those Domestics. LOL Ferg
  23. Lets see if I can give you a thumbnail idea to get you going. Since you have already visited Tandy, return and get a bottle of theEDGE PAINT GLOSS EDGE AGENT. It is most likely a Fenice product and may be labeled something entirely different but this is one thing you need. Also get a bottle of edge paint color you would like to use to begin. Tandy also has a "Craftool Pro Edge Dye Roller Pen", get it also. Do not sand the edge of your fuzzy leather before applying the Agent. This is assuming all layers of leather are nearly exactly lined up, if not you will need to clean up that edge, with careful sanding or cutting. Before using the Agent shake the bottle pretty hard for about 30 seconds, it will have bubbles inside the container. Tap the sides of the container with a small screwdriver or anything similar, that will make the bubbles burst. Now, dip the edge roller into the Agent, not quite over the large end of same. Tap it lightly on the edge of the bottle to get any glob off the tip. From the finish side begin rolling the edge roller over the edge until you see it completely wet. Don't get carried away, too much will run onto the face of the leather. I hold the leather piece in one hand while turning it to get the edge completely covered. If you don't get globs on the roller and also on the edge it will not "run" where you don't want it. Allow this application to dry for at least an hour if in air conditioned/heated space. Again, don't sand first application. Apply another coat of Agent, allow to dry for 24 hours. You can then sand with 600 grit sand paper/cloth until you feel it is smooth. Do not press down hard on the sanding paper, light pressure is definitely desirable. You need to get all sanding dust off the edge and any that may be on the remainder of the leather piece. Now, you are ready to apply your finish color of edge paint. Shake the bottle and tap it as I illustrated above. I like to use at least two coats. I am using Giardini now, it is thicker consistency than the Fenice. TANDY's edge paint may require more than two finish coats. Allow at least 12 hours between applications and do not incorporate the product into use for 24 to 48 hours. This is not for everything you make but it will make some very nice edges on most. Ferg
