Ferg
Contributing Member
Everything posted by Ferg
  1. SERGEY, You just keep outdoing yourself! ferg
  2. I have a blade welder. At one time we made product that required at least a dozen band blades per day. One of my bandsaws uses a 108" blade. You watch very carefully when handling any of them. ferg
  3. A long time ago I got tired of sharpening my knives etc. entirely by hand. Last year my beloved wife allowed me to buy the Tormek system with lots of goodies. I have no need to do anything but strop my Wranglers or Knipper knives. I can maintain an extremely accurate angle etc on any woodworking blade or the many others we have in our home plus "Hoof Trimmers" for goats. Family members have benefitted also. lol All my old leather tools are scary sharp also. ferg
  4. I have received my stamp order from Sergey. Stamps are very finely done. Think I will use my arbor press to make the impressions. Took two weeks + to receive after giving order. Sergey shipped right away. ferg
  5. Tinker, I can go real fast but prefer a little slow. I don't know how good the metal is at the "bearing" area of the shaft on the winder. I can actually control it better with my hand on the foot switch. I guess we can feel better with our hands than feet. lol Winder pulley is 3" while the motor pulley is 1/2". Six to one. I thought I would have some problems with keeping the belt on the winder pulley, haven't so far. I squared everything up as close as possible plus the winder has a small indention in the middle of the wheel. ferg
  6. I have been thinking of doing one of these for some time, all the others showing their handy work, here is mine. I had an extra winder and thought a singer sewing machine motor would be the thing to use. Found Motor, extra brushes, belt, and foot switch for under $20.00. ferg
  7. IF your leather is thin enough, skive it and roll the edge over the fabric after yo glue the liner material. Otherwise the fabric needs to have a rolled edge, just like leather. and sewn. ferg
  8. If you done your parts cutting free hand, begin using a pattern that is the same always. JoAnn Fabrics and many more, carry a double sided tape that is almost transparent but sticky, to hold material while sewing for instance. When using a pattern to cut your leather apply this tape to backside of your pattern then to the leather you are cutting. This stuff will not leave residue if you remove it promptly when finished. Round corners are always a mystery when beginning. Your radius must terminate at the straight line so it flows. Use a stitching gauge and a compass or anything you can make a mark evenly for your stitch line. Using pre-made/cut kits is a great way to learn. It normally makes you want to do the cutting yourself. ferg
  9. Small steps, then big ones. If you have any scraps of leather, you can buy bags of them, practice "stuff" on them. When you begin thinking that is for the birds, make a key fob, wrist strap, etc. The first thing I tried many years ago was a wallet. I kept it for a long time just to remind me of how bad I really was. LOL ferg
  10. I have no idea who you bought your CowBoy from but any of them that I know would not let you have this kind of trouble with your machine. Actually I know of no dealer that advertises or posts on this forum who doesn't take care of their customers. Has it occurred to you, maybe the machine is not properly adjusted plus you are trying to use the wrong size or type of needle. Check with Bob Kovar at Toledo Industrial Machine. He will get you straightened out. No point in blaming the machine for something that very well may not be the problem. Also: You can get real close to top and bottom stitch appearing the same but it takes a lot of trial and error some times. Proper tension is at least 85% of sewing. ferg
  11. You may find that the heavier the machine the less likely it is to sew thin leather if you may wish to do that also. ferg
  12. Look in Amazon for the "Bumper Edges". I got a set of three for less than $7 They are just as good as the more expensive. Came direct from China in 7 days. Use ultra thin Velcro to attach the phone to the case. You can barely tell it is there and the phone is removable if need be. ferg PS: JoAnn fabrics and Amazon has the Velcro.
  13. What ever works. lol ferg
  14. The thread you slightly cut into the wood won't hold real well but that said, your burnisher will "back off" the grinder shaft because it is not a reverse thread. Remember the wooden tool with a cutting "V-Groove" blade in it? You can make children toys and furniture with them, they come in different sizes. Deep threads in hard maple. ferg
  15. You have some experimenting to do. Shaft for grinder is probably not going to match the hole in your burnisher. If this is true, you need to have a shaft made with male end to match burnisher, female end to thread onto the grinder shaft with a "reverse" thread so your extended shaft won't unthread. What you place on the other end of grinder may throw it out of balance and in a short time wear the bearings of the motor. Simplest set-up is a separate motor mounted on a heavy board or work bench with a shaft that will match the hole in the burnisher mounted in pillow blocks. More to it than that but maybe you get the idea. Has it occurred to you that you began this endeavor from the wrong end? There are burnishers available with a shaft epoxied into them so they can be mounted in a drill press or Dremel. Saves a lot of time and money. ferg
  16. Thanks Matt, Forgive my elderly brain. I forgot you were carrying some of the products. Are you offering the "Free" kit? I wouldn't think so. lol ferg
  17. For any of you living in the USA interested in trying the Giardini edge paint. The FREE trial kit doesn't give you much plus the shipping to Ohio is just shy of $40. ferg
  18. Since you haven't had much luck with answers...... My first thought is, "Why chicken leather" when there are a number of other more popular leathers with interesting textures more readily available. Another thought, using chicken leather may have a stigma connected to it that would turn off some lucrative buyers of your watches. Just my .02 ferg
  19. Received my SLC liners today. One four pocket wallet in Simply Classic One Ladies Clutch The Clutch purse is definitely the better of the two. Quality on the wallet is questionable, it is not their best. I believe I will continue making my own. ferg
  20. The 20 ton air/hydraulic jack comes with heavier springs than the 20 ton hydraulic. Works fine so far. ferg
  21. I didn't care for the look of those. I did order a couple of the higher priced to see what they looked like. I prefer making my own but like to see what folks are doing plus a ready source helps if you get real busy. ferg
  22. I installed a 7500 BTU electric heater in our shop two years ago that mounts on the ceiling. It has a thermostat inside, I wanted an exterior to use with it but didn't find a good one that would handle 40 Amps. I have a timer for it. We spend 14 or 15 hours per day 7 days a week from October through most of January in the shop. We have about six folks working a portion of each day. Machinery running warms the shop above 80 degrees until our weather gets real cold. Heater has a blower. I set it so it maintains about 65 to 70 degrees while we are working. Shop contains about 3500 sq. ft. with 12' ceilings. ferg
  23. Mine has 3/8" plates. Largest clicker die I have right now is about 7 1/2" x 8 1/2". My Air/Hydraulic has absolutely no problem with 1/4" plus, thickness of leather. I have one of the thick red plastic cutting boards on the bottom. This unit will cut into that 1/4" if you don't stop it. ferg
  24. I got mine for $90 with a hydraulic jack. I spent $118 to put an Air over Hydraulic 20 ton jack on it. Already had a "PanCake" air compressor. To keep the jack from forcing the die too far into the "Cheater" board I made blocks of sufficient height to place between the upper and lower steel plate. Works great! Since we use a CNC Router in our wood shop I am in the process of making Steel Rule Dies for "Clicking" parts. ferg
  25. SLC is making their own liners in house. Has anyone used them. Curious as to the quality of them etc. Don't get these confused with the Chinelli. ferg
