Really great piece of work, should say really great piece of art! Tom
The head page says Resources: Links, periodicals, books, Guilds and other professional organizations, trade show and demonstration announcements go here. So I believe you are in the right place. Fire away, full steam ahead! Tom
Another dumb story! I had a wet distributor cap after washing down my car's engine. So I took the cap off, rinsed it with methyl hydrate (alcohol) wiped it out, plugged all the spark plug wires and coil wire back in and put the cap back in place. Climbed in the car and hit the starter. BANG! Didn't start! Checked under the hood. It had blown the distributor cap off. So had just enough fumes, plus a spark, and off she went! Haven't tried that since and that's over 40 years ago. Tom
Myth or no myth? Let's get the information relative to whether solvent vapours are explosive or not. For an explosion to happen, there needs to be a high enough concentration of the flammable vapours exceeding the lower explosive limit (LEL). It is different for various vapours and gases. If you keep enough air moving through the space, no problem with explosions. Hydrogen is one of the worst with the widest explosive range. Lower Explosive Limit (LEL) 4% in air, Upper Explosive Limit (UEL) 75% in air. See the following for more information on other vapours and gases: http://www.wermac.org/safety/safety_what_is_lel_and_uel.html I know of a house (next door to my MIL) that blew up. They were installing carpet in the basement, using a glue with a very volatile solvent. They were just about finished when the vapours hit the gas fired hot water heater and ignited. Lost the whole house (insurance built them a really nice replacement). Most of these solvent's vapours are heavier than air, so sink to the lowest area. Thus the basement without adequate air exchange became a disaster. If we assume that toluene is the solvent, its LEL is 1.2% and UEL is 7.1%. So if the concentration by volume in air is in the range of 1.2 to 7.1%, and there is a source of ignition, there will be an explosion. Toluene is a common strong solvent. One weekend many years ago, I was working as Shift Supervisor in the Utilities Plant just across a service lane from the Gas Compressor House. The Refinery produced hydrogen and used it in a hydrogenation process to remove sulfur from the hydrocarbon streams used in the manufacture of diesel and gasoline. The two hydrogen compressors (1200 hp 3 stages each) were located along with other compressors in the compressor house. They raise the hydrogen pressure to 1200 psig for the Unifiners. I get a phone call from the Process Shift Supervisor. They have a hydrogen leak and have 95% hydrogen atmosphere in the Compressor House. Of course it was safe from causing an explosion since the atmosphere was well above the UEL. How to get from there back to hydrogen free, while passing through the explosive zone? No one can enter it without a Scot Air Pack (no oxygen to breath), no one can shut off the electric drives or switch anything for fear of creating a spark even though all the wiring is in sealed explosion proof conduit and boxes. Can't take the risk. They bring in the plant fire crew with some new fans they had purchased recently that ran on water pressure and placed them in the doorways to ventilate the building without doing anything inside the building, and to avoid adding any risk of generating a spark. Even outside the building, gas was above the LEL. We monitored the % LEL in the Utilities Plant 50 feet from the Compressor House. The drift and seepage of the hydrogen into the Utilities Plant raised the % LEL in the building to 2%. We had 3 large boilers that were potential sources of ignition if the hydrogen level got too high. Anyhow, to make a long story short, they were able to ventilate the Compressor House successfully with no fire or explosion. Funny thing was that they couldn't find the source of the hydrogen leak. Must have blown an oil seal and had it reform by itself. Tom
You are really getting the hang of it. I like your work! Tom
@jbennion Moved your post to leather sewing machines. You are more likely to get answers here. You might like to add your location to your profile since you are interested in visiting a shop. You might get invitations from Mars or Venus otherwise! This is a worldwide forum. Have you done any internet searches for Singer 97-10? there are manuals available on some sites. Welcome to the forum. The best all around leather working site available. Tom
Tippmann Aerostitch II still available?
Northmount replied to DavidMillsSaddlery's topic in Leather Sewing Machines
I suppose you could run an engine driven compressor for compressed air. Also need power for the solenoids, though it may be only 24 v. So if I was going to setup for work "in the deep woods" I would just use a standard machine and hook up to an gasoline or diesel engine driven electric generator. I know some people use propane fueled engines on their generators. For more permanent locations with natural gas available (no electric utility) I would install a Generac 20 kW generator set. I helped install one for backup power in an area subject to frequent power outages during summer rains and floods. Can run on nat gas or propane. Certainly allows one to sleep better and have peace of mind knowing you can keep two 1 hp sump pumps running! Tom -
Wanted : Singer 111W drop feed
Northmount replied to chouinardragon's topic in Leather Sewing Machines
Moved this from "wanted" to "sewing machines" since you have posted similar in used. Wanted requires moderator approval for every post. Tom -
Hearing protection for stamping leather? Necessary?
Northmount replied to JC2019's topic in Stamping
OSHA sets legal limits on noise exposure in the workplace. These limits are based on a worker's time weighted average over an 8 hour day. With noise, OSHA's permissible exposure limit (PEL) is 90 dBA for all workers for an 8 hour day. The OSHA standard uses a 5 dBA exchange rate. Other jurisdictions may use 85dBA as the limit. That is fairly loud in comparison to tooling leather. Comparison chart https://www.noisehelp.com/noise-level-chart.html Safe noise levels https://www.noisehelp.com/noise-dose.html Tom -
Just bought a second hand sewing machine...
Northmount replied to Erfan's topic in Leather Sewing Machines
Also pull the thread out of the needle or you'll likely have a big birds nest to deal with. Tom -
Consew 206RB-5 walking foot sewing machine Los Angeles CA pick up
Northmount replied to Tony11's topic in Old/Sold
Users can't delete. Just mark as sold, and we take care of it. It gets locked and moved to old/sold. Tom -
Definitely! I should have mentioned that! Tom
@Blueboost Add a picture or two ... add some specs so people don't have to go look it up, maybe that will help generate some interest for you. Tom
Resize your photos so you can post them here. Tom
@anvlts You have a request asking if this machine is still for sale. Please advise. Tom
@idahoderrick Moved yourpost to leather sewing machines. You'll get responses here. Tom
Uploaded the files so they would be available later 345 Service Manual JA_345-H3_346-H3_9-84_E.pdf Sub Class Parts kgi582aa.pdf parts 5ao8mf6d.pdf New 335 Service Manual JA_335_11-15_EN.pdf Instruction Manual BA_335_01-14_EN.pdf Instruction Manual BA_335-11-15_EN.pdf Parts List TL_335_02-16_DE_EN_ES_ZH.pdf Parts List TL_335_06-09.pdf Service Manual JA_335_01-14_EN.pdf Old 335 Pfaff-Service-Instructions-Various-Models.pdf Tom
Adding photos here would be a good idea. Tom
Looking for someone to lengthen some Synthetic Leather Straps
Northmount replied to a topic in Old/Sold
You should provide more information, such as your location. Might be somebody on the same planet as you. From your IP address, you appear to be in the Redmond, WA area. Photos might help as well! Tom -
@Techsew Ron
Dying tooling leather
Northmount replied to GregS's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Dye is not a finish. If you want to protect it from moisture, pick a finish that is somewhat water resistant. Lots of them are. To get a nice high polish, wax the surface. You can dye any time you wish depending on the result you are looking for. If you dye an article before punching holes, you can go back with a small brush and touch up the holes. You can dip dye the whole thing after all the cutting and punching. You can use an airbrush to apply dye. ... Tom
