@tieflyer You have some interest shown here. You haven't been online here since March 22. @StitcherToo If you quote or flag someone, they normally get an email so you will get faster response. Type "@" followed by the username and a list will pop up. Pick from the list. Tom
Hey @CowboyBob do you know anything about the Cowboy 8020 splitter? Looks like some interest in this thread. Tom
Talented YouTuber
Northmount replied to AdamPCain's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Copied and pasted into a browser, works for me. Tom -
I came across this checklist. It is not specifically for leather sewing machines, but has many common problems listed. Hope it is of help to someone here now and then. Sewing Machine Common Troubles.pdf Tom
A great amount of really great leatherwork (tooling, stamping, carving) has been done with all kinds of tools; home made, cheap, expensive, etc. Good tools may help, but the main thing is how you use the tools you have. You don't need 100 different stamps. 10 stamps in total may provide all you really need tool-wise. Practice and patience are the requirements for good tooling of any style. Of course we all like to have nice tools, and there is always another one that we want to add to our collection, but this is mainly just "wants". Tom
I'd say leave it as is, mostly due to your comments, but mine would be much the same. Tom
Just a very nice happy story from the UK
Northmount replied to chrisash's topic in All About Us and Off Topic
Most of the kind and grateful people don't make the news. There are lots of them around, quietly going about their life, but the squeaky wheel gets the grease, good or bad. Seems more often bad. Tom -
Both are good choices. Ad revenue is good as it supports operational costs. Send a PM to @Johanna Tom
Saddle Sewing Machine? Need Help Please
Northmount replied to MRoyster's topic in Saddle Supplies, Tools & Trees
Definitely! Tom -
Content in the photo really has a big impact on file size (range of colour and intensity). In Photoshop, when saving a JPEG, I have a choice of "quality" from 0 (smallest file size) to 12 (largest file size). So I picked a random photo that was saved as a TIFF. 1447 x 1551 pixels (20" x 21.5") saved with a resolution of 72 pixels / inch with a 3 MB File size. Saved it as a JPEG without reducing the size. Set at 0, file size was 142 kB. Set at 12, file size was 1.4 MB (10 times larger). Resized the original to 746 x 800 pixels maintaining the same proportions, and did test over. 0 yielded a file size of 81.6 kB, 12 yielded a file size of 514 kB. So quite a range of file sizes. My numbers quoted in a previous post above were out by at least 10 times; should never quote numbers without testing and confirming! Resizing makes a substantial difference, and the quality setting makes a lot of difference too. I think the quality setting gets missed in a lot of resizing applications, or missed by the user in other cases. Would be nice if we could keep things simple, just one setting instead of too many choices for the average user. Tom -
The only size restriction is the size of the files. I think it is about 3.4 MB. (Maybe I reversed the digits.) My limit is different and I of course don't see the regular users limit anymore. 800 x 600 pixels yields a file around 4 kB. So you can load lots of photos if resized down. Depending on software you have or are using, you can set file size rather than pixel dimensions. Up to you to resize to what will fit within the site's limitations. Would be nice it the site resized automatically! Tom -
Fortuna Skiving Machine Restoration
Northmount replied to lintonleather's topic in Leather Machinery
@lintonleather according to the IP address OP is located in the Nottingham, Nottingham, NG5, United Kingdom area. It's a good idea to add your location to your profile so you get help related to your area of the solar system! Tom -
This statement is not correct. For the past say 100 years or more we have been heating objects to expand the hole to enable release of nuts, etc. We heat a ring and drop it over a shaft to act as a bearing retainer for axles. As soon as the ring cools it shrinks tight to the shaft. If you look at the molecular level, heating an object causes the molecules to vibrate faster and push away from each other. So looking at the circumference of a hole, the hole can not get smaller. One problem with heating a block of metal with a relatively small screw is that the screw heats up nearly as fast as the block of metal. Thus not enough differential expansion to really loosen the screw. But simply heating to a high temperature (not enough to destroy the properties of the object) and cooling often helps to break the rust or corrosion that has locked the 2 pieces together. An impact driver is very helpful, but care must be taken to avoid the driver slipping out of the screw slot and damaging the screw slot so you can't get a good grip on it after that. Tom -
There are various types of penetrating oil available. Lots of different brand names. Loosen-all, penetrating oil, rust remover, etc. In general, they work better than diesel fuel and other light hydrocarbons. Tom -
@jdwhitak You've got a couple unanswered requests here. Are you still selling the knife? If not, tell us and I'll move the post to old/sold. Tom
- 6 replies
- tina
- lindispensable
(and 2 more)
Cowboy Holster Tutorial
Northmount replied to Jim's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Fixed broken link in original post. https://leatherworker.net/SimmonsHolster.pdf Tom -
@McBeal Moved your post to Leather Sewing Machines (even though you are using canvas). You'll get more input here. Tom
Because you posted in Help Wanted, which non-members of these forums may post in. Help Wanted is generally for hiring help, or alternately, people wanting work post here too. Then almost all replies to the post also require approval. Moved your post to How Do I Do That. Tom
@ABHandmade Top notch as always. Great job. Tom
He hasn't been back to this site since he posted it! @Saleigh You still around? Tom
Need advice on sewing across transitions
Northmount replied to KennethM's topic in Leather Sewing Machines
Wizcrafts has explained why stitch length changes with the thickness of the leather. https://leatherworker.net/forum/topic/74979-stitch-length-changing/ @KennethM Moved your post to leather sewing machines. Tom -
@nokiddin Hi. I see your are from the Winnipeg area according to your IP address. You might like to add your location to your profile. Here are a couple wallet liner patterns that have a piece in the middle that adjusts as you open wallet flat and when folded. I don't recall where I collected them from so can't credit the originator. Probably found them here on Leatherworker.net. I trace the pattern onto a manila file folder and cut it out, then assemble it (with staples) to make sure the parts fit and operate correctly. You may need to change the distance between the slots and the length of the tabs that fit into the slots. Once I'm sure of the dimensions and fit, I trace onto pigskin. I find pigskin thin enough and quite durable for wallet liners. Tom Walletpatterns.pdf Liner_photo.pdf
OP appears to be located in the Denver, North Carolina, 28037 area according to the IP address. @offerd15 Some photos might assist you in getting some interested parties. Tom
@AMTN85 please read and comply https://leatherworker.net/forum/forum/70-announcements/ Tom
Or grind the end to round instead of pointed. Continue down the sharp side a little so that no sharp spot is pointing up when you reach across the bench and catch your wrist! If you buy a draw gauge from member Bruce Johnson, he will supply it with the blade already trimmed like this. Tom
