Northmount
Moderator
  1. 400 watts. 746 W / HP so this is 400 / 746 = 0.54 HP Tom
  2. Love your story. When my youngest son was about 2, he came upstairs to the kitchen and handed his mom a number of screws. Where did you get these screws from. He took her to the basement stairway and showed her he had taken most of the screws out of the stair handrail. Anytime I went out to the garage, he would say where's dad going and be trying to get his shoes on to follow me. When I was about 2 to 3 years old, we lived in a house with no electricity. The wringer washer was powered by a little gasoline engine. One day I handed my mom a couple bolts I had taken out from under the washing machine. Kids that are hands on mechanically inclined will find ways to take things apart with or without the right tools. I have 8 grandkids now. Some of them are following this tradition. Tom
  3. I've seen comments about using deglazer, or toluene or other solvent to remove the surface oil before gluing, so suspect that it would help with application of an acrylic finish. Looks like time for some test swatches to see what works and how it stands up to lots of flexing, etc. before you try the real project. Tom
  4. Using a string gives you the wrong length. Belt length should be measured at the top of the pulley where the belt rides, not in the bottom of the groove. Bottom of the groove will be too short. You could draw out the mounting positions and size of each pulley on a piece of poster board. Then measure with a cloth tape. Or if you remember any of your geometry from school, you can calculate the length of the belts. Half the circumference of each of the 2 pulleys the belt will go around, plus 2 times the distance from centre to centre of each pulley will give the belt length. You have to know where you are placing each pulley for either of these methods to work. Tom
  5. Oils are used to condition and moisturize leather. They do not seal. Acrylics and lacquers seal the surface. After you have sealed the surface, oils won't do much since the surface has been sealed. You can do a search here for sealing leather, or conditioning, or acrylic, or lacquers, or resolene, or neat lac, or saddle lac, etc. You will find lots of comments on the various types. If you are close to a Tandy store, you can go look at some of the products they have and ask about them. Depending upon the sales person you speak to, you may get some good information. Tom
  6. See your other thread you started with photos for answers Tom
  7. Oxalic acid crystals will help to clean and bleach the surface. You may not get all the way to the nice example you show. Do a search here for oxalic. You will find lots of discussion and ideas. Tom
  8. Lots of options and information here. Do a search for "clicker" or "shop press" or "hydraulic jack". Even some plans and photos for adapting a shop press. Tom
  9. Contact the attorney general for his last known location. If the phone or Internet was used for the transactions, it is a case of wire fraud and a more serious crime. Press charges. Tom
  10. Outside is the show side as Electrathon said. Whether laced or stitched. Tom
  11. Several grades of Loctite are available. And they do hold in an oil environment if the oil was cleaned off the surfaces prior to adding the Loctite. May years ago I had to do a temporary fix on a mechanical accounting machine. Didn't have the correct size nut for an eccentric adjustment. Applied some Loctite, let it set up. Came back a week later, all was still in the correct position. Replaced the nut with the correct size. I tend to use the less permanent type that allows you to unscrew the screw/bolt/nut later if necessary. In a pinch, have also used Loctite "bearing retainer" for screw threads. Works fine. And wrt bottoming taps. A bottoming tap should work in this case since you are not trying to jamb the screw tight against the shaft. Tom
  12. No excuse necessary. Always happy to hear from new members and long timers too. And I should have said, Welcome to the forum! Tom
  13. Do a search here for sheath and head or round knife. There are several threads with lots of photos to give you some really good ideas. Always use a welt. Only half the sheath needs to be open, so you twist the knife out of the pocket. So only one closure strap needed. Tom
  14. PM Johanna. See top bar for PMs. She will be able to do that for you. You can also set your preferences to no notifications, so there would be no emails in the meantime. Tom
  15. I really admire Bob's work and his willingness to help others and share his knowledge along the way. Great achievement Bob. Congratulations. Tom
  16. The memory used in today's cell phones, tablets and PCs is not sensitive to magnets. Hard-disk drives may be sensitive to extremely strong magnetic fields, but you are nowhere close to that. Consider that the TSA X-rays your laptop and does no damage. The one thing to note about cell phones and tablets is that the some manufacturers use magnetic switches to turn the screen off when the device is holstered or cover is closed. You need to know where these switches are so you can avoid them with the closure, and use them to turn off the screen as needed. If the device can be inserted front to back or back to front, then the screen switch magnets need to be on both the front and rear of the pouch/case. If you do a search here, you will find much more discussion. Just be aware that many people believe old wives tales that are not applicable to today's memory and devices. Even floppy disks are not as sensitive as people claimed them to be. Tom
  17. Make sure the needle is on its way back up before reversing, else the hook may miss the loop. The you will see a missed stitch and maybe even a birds nest. Tom
  18. The leather is probably being pulled up with the needle, lifting the presser foot. Tighten down the spring on the presser foot. Tom
  19. Something wrong in your browser setup. I use Win 7, Win XP, and the iPad. No trouble using copy and paste, or the quote function. I usually use Firefox as the Windows browser. Tom
  20. Just used a fine tooth file. Carefully, and lightly. Rounded all edges that could contact the leather or snag a thread. Tom
  21. Flickr link works fine. Must be something about permissions messing up my view in the original post. VERY nice case! Tom
  22. Photo has disappeared, not available. Tom
  23. Here is another thread about printing on leather. Tom
  24. The inside layer has to get shorter when curved around your bod, so it wrinkles. One method to reduce the wrinkling is to glue up while curved, not flat. Higher quality leather may help also. Stay away from leather closer to the belly. Many belts are cut from along the backbone. Tom
