What Is This Tool? May Not Be Leather Tool.
Northmount replied to PeterA's topic in How Do I Do That?
They were used to try to save bloated cows. Cows that get into a lot of fresh hay when they are not used to it. Stick them one hand width behind the last rib where the stomach is basically preening against the skin. When I was about 10 or 12, a cow got into a bunch of frozen potatoes and bloated up real big. Dad stuck her with a pocket knife. Then had to insert a plastic tube to keep it open. Foamed lots, yeast and potato grow well. Had to keep cleaning it out every few hours. It bubbled for about a month before it healed up. Would have been nice to have the trocar. Think it was the same cow that got into the hay yard a couple years later. Found her too late to do anything for her. Tom -
You may use the pattern as many times as you wish to make items to give away or for sale. You do not have the right to make and sell or give away copies of the pattern to others. That is what is copyrighted. You will see some magazines that say you can make/build the items in magazines where patterns, drawings, instructions are given for your own personal use, but cannot sell the items. That is false, but they use it to try to reduce the quantity of goods in the same market as the original creator. Copyright does not limit the number of items constructed, given away, or sold that are based on that pattern. Tom
What Does Leather "strap" Mean?
Northmount replied to Acceptable's topic in Leatherwork Conversation
If it is listed as a strap or belt blank, I would expect to see the width and length. Else must be a chunk of leather suitable for making straps or belts. Tom -
Prospective purchasers would like know where you are located. Tom
Put a piece of 1.5 inch pipe in a vise and use it as the anvil to set the rivets. Tom
A lot depends on the thickness of the leather, whether wet or dry, what allowance you wish to make for pulling the stitches up tight as to whether you leave a gap because it is too short, or a less than tight fit if its too long. Thin leather, I would not bother trying to cut angled. Experiment and find what works the best for you, then stick with it. Tom
Research how to books, including those on Tandy's website, buy a couple. Study out what you want to make, including the kind of tools required to make it. Then go look for just the tools needed and the leather you need. Research some more here as well, especially where hand sewing is involved. There are many approaches to use. Don't be pushed into more than you need for your current project. You can add a few things as you go along. You can find a lot of information here, but sometimes knowing the right terms to search for make it hard to find what you want. Here is some information on hand stitching using a minimal number of tools, using what you have on hand at home. Look at post 19. This is just an example of what you can do thinking outside the box and looking at the implements you have at hand. Working this way will save you some money at the start, and get you started. Then you can go get the better tools, etc. Tom
Cut the leather long, wrap around the pipe, hold tight, cut both layers together in place. The edges' angles should fit correctly. Tom
Piece Of Thread Stuck In Rotating Hook Consew 206 Look Alike
Northmount replied to kwalk20's topic in Leather Sewing Machines
Recheck the top thread path for correct threading. Is the thread properly under the check spring. Replace the needle if you haven't already. Make sure the bobbin is installed correctly and the correct rotation. The machine is having trouble pulling the top thread back up. Try a larger needle. Tom -
I Want To Make A Journal And Line It With Pigskin Suede
Northmount replied to tanda4's topic in How Do I Do That?
Glue with the journal folded half closed so the lining doesn't pucker when folded closed. And will stretch some when fully opened. Tom -
Welcome. Looks like you are off to a good start. Tom
Video: Possible Schärf-Fix 2000 Alternative?
Northmount replied to Daniel G's topic in Leather Tools
$120 USD plus $27 USD shipping. (Sep 30) Tom -
Take a look at this thread as well, depending on your usage and work. Tom
Make sure you are using Vegetable Tanned leather. Other types of tannage will not behave for you, and will not in most cases retain the stamp impressions. Proper casing is necessary to both swivel knife cuts and for stamping. A couple other threads that may be of help to you are http://leatherworker.net/forum/index.php?showtopic=64096&hl=+casing%20+carving&page=1 and http://leatherworker.net/forum/index.php?showtopic=66536&hl Takes practice, looking at others work and examples, and more practice. Keep at it, it will get better. Tom
The 15 A plug is all that is needed. The 20 A plug is a twist lock, which don't pull apart as easily, so is nice to use. And as you can see, the 4th wire neutral wasn't used and does not need to be wired. Tom
Fixed the title for you, peace > piece Tom
Green/yellow wire is safety ground. Blue and brown are both hot. Your home service panel is 110-0-110. The 0 is neutral. Connecting to the two 110 v leads gives you 220 v. Your breakers for 220 are double or paired. So you basically connect to the double breaker, which is 220. And yes this is all single phase. A motor nameplate that says single phase is single phase (unless the nameplate was changed, and you can see if it has been tampered with). If you are unsure about doing this bit of wiring, hire an electrician to fab your extension cords / adapters and to do the hookup. Tom
Wanted : Singer 68-32 Or 69-8 Or 69-26 Bar Tacker
Northmount replied to chouinardragon's topic in Old/Sold
Moved from Help Wanted to Wanted. Might get more action there and doesn't require moderator's approval to be seen. Tom -
Hey, pretty nice! Welcome to the forum and the addiction. Tom
You should state where you are located. Tom
Be careful you don't spread the mold around. The spores can become airborne and affect other pieces of damp leather. Clean and treat the stuff outside if possible. There are other threads here about mold, cleaning and prevention. Listerine in your casing water is supposed to help prevent mold. Tom
Also make sure you rough up the plastic so you can get a good bond. Most glues don't adhere well to smooth plastic. Tom
220 vac (North America) is single phase. Only larger loads like stores, shopping centres, factories, etc. use 3 phase. 208 vac 3 phase wye connected provides 120 vac single phase from line to neutral. Tom
