Take a look at Jim Milan's Bucket List Jazz Band on YouTube. These guys are all over 75. Jim is my father's cousin and if I remember right, over 90. Also on Facebook Not exactly Big Bands, but great music you don't see very often today. Tom
The thread needs to be between the tension disks, else you have no control of the tension. Tom
Patterns and Templates Forum You can do searches here, see upper right of your screen, or do google searches for leather purse or wallet patterns. Some fabric patterns are good too depending on what you want. Tom
Try here Tom
Welcome to the forum. If you post your sewing machine questions in the sewing machine forum, you'll get the experts' attention much sooner. I thought about moving this thread, but then decided after all that it is your introduction, and I should keep it here. Tom
Should post in sewing machines. I'll move it for you. Help wanted is like the newspaper, people hiring or wanting to be hired. Tom
Picture?
Fantastic work. Keep it up. We love to see it. Tom
Interesting, set into a workmate bench. Folds up out of the way for storage. Tom
Nice job Tom
Yes, if you want the impressions to be deep enough and to stay. The right amount of moisture also helps to get the nice darkening or burnishing that you usually want. Tom
Shaving Kit
Northmount replied to venator's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice job. Tom -
I am very familiar with this style of button. Have it on a purse, used to hold a flap closed, and no problem un-rolling in 5 years. Check out "Plate 108 Roll Button" page 273 in the Encyclopedia of Rawhide and Leather Braiding by Bruce Grant. You just go through the slits in the mounting location just before you pull it through the roll to secure it. Only trouble I have had with it is someone decided they had to unroll the button to open the flap instead of simply pulling the retaining loop over the button to release it. Some things are just too hard for others to comprehend. Tom
Cut 2 slits in the leather where you want to attach the button, then pull your strap through the slits before you pull it through the slit or hole in the roll, so goes between your step 3 and 4. Tom Edit You could rivet the strap where it passes through the 2 slits, would make it more secure and less likely to come apart.
Fed Up Of Cheap Rotary Punches... What Next?
Northmount replied to erniethemilk's topic in Leather Tools
Handles made of pressed metal always failed for me. Finally bought a rotary punch with solid steel handles. They don't squash! You'll either pay for one incrementally in replacements, or just go get the right one first off and ultimately save more. Just keep the web between your thumb and finger out of the hinge area anytime you release your grip! It pinches and ... Tom -
The capacitor with its winding shifts the phase angle of the magnetic field, so that 2 rotating magnetic fields are produced in the stator and pulls the rotor around, causing it to rotate. If this cap and winding are not energized, the motor can start in either direction, or sometimes just sit there and hum. The cap and winding are commonly referred to as the starting winding. If the capacitor is faulty, or the circuit is broken anywhere between its terminals, it won't start reliably. If you have an ohm meter, you can test the continuity of the winding and its connections. Power must be off for this test, or you'll let the smoke out of your meter. The resistance should be relatively low, probably less than 50 ohms. You may be able to test the capacitor with the ohm meter too if it is an analog type, moving needle, not digital display. With the ohm meter set on the highest resistance range, you may see the needle kick upscale and then settle back to infinite resistance. What you see is the charging current. If you reverse your ohm meter connections, you may see the needle kick to a higher value, then settle back again. You just discharged and charged the capacitor in the opposite direction. If the meter behaves like this, you can be reasonably sure the capacitor is working. If not, the test may be inconclusive, but tends to indicate the capacitor is faulty. Capacitors may have some leakage current, which is normal, so the ohm meter may not settle at infinity, but should settle at a high value of resistance. Or instead of trying to test the capacitor, just go buy a new one, assuming you have tested the start winding and found it to be okay. During your tests, for each component, no other components should be connected to the one you are trying to test. Tom Edit I see Art has posted as I was typing this up. I agree with him. Up to you as to whether you can do any testing, safely.
You need to post your location so people have some idea of where you are, Florida or Alaska?. Are you going to package for shipping? Or looking only for local sale? Tom
- 3 replies
- leather sewing
- tippmann boss.
(and 1 more)
If you repair used rugs/blankets, they are dirty and will drop junk in your machine. Use a separate old machine for this type of work, and save your good machine. Tom
This one has your pictures attached, so added the price from your other post, and kept this one. Edit is only available to posts for maybe an hour after the post was made. The edit button is left of the quote button. Hope that is okay. Tom
- 4 replies
- servo motor
- shoemaking
- (and 6 more)
Singer 111W1555 Serial Number Year Id
Northmount replied to teched's topic in Leather Sewing Machines
Here it is Singer-111w155-Parts-List.pdf Enjoy Tom -
For Sale: Juki Machines, Brand New - Lu1508N, Du1181N
Northmount replied to jakimac's topic in Old/Sold
Moved this thread to Machinery -- Sewing and Stitching → New and Refurbished to Like New for you Tom- 5 replies
- for sale
- sewing machines
(and 2 more)
Some related helps http://leatherworker.net/forum/index.php?showtopic=56138&p=360338 http://leatherworker.net/forum/index.php?showtopic=24009&p=153039 Tom
According to his IP address, his ISP is Bellsouth, registered in Atlanta Ga, so that gives a little info about his general location. SE USA. Tom
I have a Techsew 2700 which is the same as a 227. Does a great job. Added a flat table adapter for doing flat work. If you use 8 oz or thicker, or hard temper, you will want speed reducer pulleys to allow slow stitching and have the torque you want to punch through the leather. Tom
