Northmount
Moderator
  1. Take a look at these links https://www.facebook.com/KingsleyMachineCo/ http://www.ebay.com/gds/BUYING-A-HOT-STAMP-MACHINE-/10000000000751965/g.html Kingsley are good presses, but are now antiques. You will need to have some method of attaching your brass stamp to a block in the type holder. The double sided tape makes that easy. There is very little working space under the type holder, so would be difficult to place the stamp, press it down to heat it up, then remove it, place the stamp on your leather, then move the package back under the type holder, keeping everything perfectly in position. When your stamp is properly attached to the block in the type holder, you let it warm up to the desired temperature, position your leather, pull down the lever pressing the stamp into the leather for a few seconds. The dwell time you need depends on the foil, leather, and amount of pressure you apply. Tom
  2. If you use leather point needles, don't back tack. Leave your thread tails long and do your back stitching by hand, doing a saddle stitch. Tom
  3. OP's IP address is located in Wisconsin. You should be posting photos and complete description, etc. according to terms of use of this forum. Tom
  4. My iPad doesn't like either file, but my PC has no problems with them. Tom
  5. I think you should copy this to a new post so you get the exposure that you want. Tom
  6. LOL You might want to rename the files to Cylinder Arm! Tom
  7. Merged your two posts into one and moved it to "Leather Sewing Machines". As mentioned above, you will get more response from this area rather than "How do I do that". Also deleted your multiple posts. Don't keep hitting the "Submit Topic" button after you have already hit it. Give the server time to respond. Tom
  8. OP appears to be from the New York area according to his IP address. Tom
  9. Moved your post to leather sewing machines. You will likely get more response there. Tom
  10. Cut a leather gusset, cut a slot in it for the zipper and stitch the zipper into it. Cut the gusset a couple inches longer than the edge you are connecting it to. Run the ends of the gusset down into the spine, as if it were a book cover. Find the exact centre of the gusset, and exact centre of the sides of the purse and glue or temporarily stitch or staple in place. You can have the zipper unzipped while doing this. Line it all up, glue or staple in place with the gusset wrapped down inside. Don't stitch the ends of the gusset into the spine, but let it float. Sew it up, done. Tom edit If you want to keep the purse real thin, just use the zipper like you did, but get one long enough to go about an inch around the two end corners, and cut a slot for the zipper to fit into. I would still find the exact centres to match up so the zipper is not accidentally distorted and hard to zip.
  11. Northmount
    Bespoke wallet
    You might like to let people know where in the world you happen to be. From your IP address, it would appear you are near London, UK. You will find it easier to deal with people closer to you rather than thousands of miles away. Tom
  12. Make sure your top thread is between the tension disks, not just riding around the outside. Has to be between the disks to work. Recheck your thread path to make sure it is threaded correctly. Tom
  13. Show us some of your new work! Tom
  14. Nice looking bag and Oak Leaf. Tandy sells "Craftaids" with all sorts of carving/tooling patterns. Tom
  15. As mentioned in one of the posts, observe what the needle and hook are doing so you can decide what action you need to take. I try to make turns either as the needle is entering the leather or just before it exits. Also not to lift the presser foot too high and lose the top tension. Tom
  16. Located near Autin Tx according to the IP Address. Tom
  17. From the OP's IP Address, he is likely located in Southern California. Tom
  18. See Kevin King's tutorial making a wallet. Comments call it a rolled edge, french roll, bound edge. I think that french roll is the correct name. Here is another rolled edge. Single layer, not bound. Tom
  19. And you are located where?
  20. I read a post some time ago where the poster stopped the lining just before the end of the buckle flap. Couldn't find it with my searches though. This will give you the same, or nearly the same thickness for the whole belt, and reduces the bulk around the buckle and keeper. Tom
  21. Be careful with linseed oil. Raw linseed oil never dries, stays sticky and gummy. Boiled linseed oil has driers or other chemicals added to it so it will dry. Tom
  22. A little info here Also look at this page http://www.montanapitchblend.com/our-story.html Tom
  23. Coat both ends with something (like tar or similar product) to stop the ends drying out before the rest dries. Moisture wicks up the grain to the ends. Stop that and it dries slower and less risk of cracking and splitting. I have a neighbor that does a lot of woodturning. He puts the logs (cut to lengths he uses) into a box full of sawdust and wood shavings. Slows down and equalizes the drying process. Needs to be stirred up every few days to get rid of some moisture and to bring some fresh air in. Tom
  24. I pass through Claresholm every now and then. Sunday and Monday this week. There are a number of members in the Calgary area. Show us some of your work. We're always interested in photos. Tom
