Northmount
Moderator
  1. I was shaking up a bottle of dark brown dye a few days ago. Suddenly saw lots of black spots appearing before my eyes. Thought for a second it was more eye trouble! Dye hit the white fronts of the cabinet doors, the front of the deep freeze with a wrinkle finish, the floor, ... It sure set fast, really hard to get out of the wrinkle finish paint. Took some scrubbing on the vinyl tiles too! Finally used ethyl alcohol on the cabinet doors. Softens the paint too. Good thing I hadn't given them the finish coat yet. Tom
  2. Where did you order yours from? Tom
  3. Do a google search like this "site:leatherworker.net leather hat" without the quotes. Google has much greater search capability having indexed most of the available web. Site: limits the search to the specific site. Tom
  4. A photo would help. Some bags have handles on both sides. Might fit for yours too. Another possibility could be to attach it to diagonally opposites spots on each side of the bag. Tom
  5. Bob has this chart posted on his site. http://www.tolindsewmach.com/thread-chart.html Tom
  6. Moved to help wanted. OP's IP address is located in Winfield, West Virginia, 25213 Tom
  7. According to the IP address, poster is located in North Dakota. Tom
  8. You definitely don't want mould in your shop, so need to get it cleaned up. I found oxalic acid removes the mould and stain. Some people put plain old listerine mouthwash in their casing solution to help prevent mould and fungus while tooling. Tom
  9. Thanks from all. Great list to have available. Tom
  10. Thread (and belts on conveyors or flat pulleys) always climbs to the high side. Tom
  11. oltoot sent me his photos and instructions so I could put them together and upload them here. Took a while to get here since the cable company accidentally disconnected me and took a week to come back and fix it. Hope you all appreciate oltoot's work. Tom Ground Seat Instructions.pdf
  12. Looks like the OP moved them or changed access permissions. Looks like they were posted on a photo sharing site instead of on this site. Tom
  13. Tell your prospective buyers where you are located! Tom
  14. Northmount
    Darkhand
    I'm sure someone does. Tell them where you are located! Tom
  15. Take a look at these links https://www.facebook.com/KingsleyMachineCo/ http://www.ebay.com/gds/BUYING-A-HOT-STAMP-MACHINE-/10000000000751965/g.html Kingsley are good presses, but are now antiques. You will need to have some method of attaching your brass stamp to a block in the type holder. The double sided tape makes that easy. There is very little working space under the type holder, so would be difficult to place the stamp, press it down to heat it up, then remove it, place the stamp on your leather, then move the package back under the type holder, keeping everything perfectly in position. When your stamp is properly attached to the block in the type holder, you let it warm up to the desired temperature, position your leather, pull down the lever pressing the stamp into the leather for a few seconds. The dwell time you need depends on the foil, leather, and amount of pressure you apply. Tom
  16. If you use leather point needles, don't back tack. Leave your thread tails long and do your back stitching by hand, doing a saddle stitch. Tom
  17. OP's IP address is located in Wisconsin. You should be posting photos and complete description, etc. according to terms of use of this forum. Tom
  18. My iPad doesn't like either file, but my PC has no problems with them. Tom
  19. I think you should copy this to a new post so you get the exposure that you want. Tom
  20. LOL You might want to rename the files to Cylinder Arm! Tom
  21. Merged your two posts into one and moved it to "Leather Sewing Machines". As mentioned above, you will get more response from this area rather than "How do I do that". Also deleted your multiple posts. Don't keep hitting the "Submit Topic" button after you have already hit it. Give the server time to respond. Tom
  22. OP appears to be from the New York area according to his IP address. Tom
  23. Moved your post to leather sewing machines. You will likely get more response there. Tom
  24. Cut a leather gusset, cut a slot in it for the zipper and stitch the zipper into it. Cut the gusset a couple inches longer than the edge you are connecting it to. Run the ends of the gusset down into the spine, as if it were a book cover. Find the exact centre of the gusset, and exact centre of the sides of the purse and glue or temporarily stitch or staple in place. You can have the zipper unzipped while doing this. Line it all up, glue or staple in place with the gusset wrapped down inside. Don't stitch the ends of the gusset into the spine, but let it float. Sew it up, done. Tom edit If you want to keep the purse real thin, just use the zipper like you did, but get one long enough to go about an inch around the two end corners, and cut a slot for the zipper to fit into. I would still find the exact centres to match up so the zipper is not accidentally distorted and hard to zip.
  25. Northmount
    Bespoke wallet
    You might like to let people know where in the world you happen to be. From your IP address, it would appear you are near London, UK. You will find it easier to deal with people closer to you rather than thousands of miles away. Tom
