Northmount
Moderator
  1. And your selling price is ??????????????? Tom
  2. The noise/squeal of that motor would make me even crazier than I am already! Tom Chances are a diode or SCR is shorted out. If so will cook the windings or some part of the circuit before long. The squeal is similar to the sound of a shorted diode in an alternator. Then the windings start to stink as it gets worse.
  3. IP address places the OP in Quebec Since this is a world wide forum, it would be really nice if people would include their location in their profile. The would get better info with searches for equipment, etc. Would know what their dollar is. Tom
  4. Something strange! Usually top tension increases with a thicker thread if you haven't adjusted anything. Seems strange you have less top tension. Go back to 69 thread and make sure it still works, then try 90 on top with no adjustments to see what you need to change. Then go for 90 on the bottom. See what result each change produces. Tom
  5. The type of servo motors used on sewing machines follows the general rule for most motors. The slower the motor goes, the less torque there is available. So the idea for tough or thick leather is to use both a servo motor and a reduction pulley or gear reducer set. The servo motor gives you easier speed control versus a clutch motor, and the speed reducer lets you run the motor at a higher speed so you will have the torque necessary to punch through that first stitch, or to crawl along at a stitch per second, or even slower depending on your setup. I can go as slow as 7 seconds per stitch, but the high end speed is severely reduced. Tom
  6. The clutch motor's torque remains constant, however the lower speed at the sewing machine results in increased torque at that point, so yes, will punch through tough items more easily. The inertia in a clutch motor also helps punch through that first stitch. It doesn't usually stall. Tom
  7. You should specify your location. From your IP address you appear to be in Texas. This is a world wide forum. Some description of the type of hammer you are looking to repair would be helpful too. Is it a claw hammer with stacked leather rings in the handle, or a rawhide mallet, or ... ? Tom
  8. Really now! 7 posts all the same! Don't keep hitting your submit button. Give the server a chance to do its job. It may be busy with other posts, or you may be on a slow network connection. Tom
  9. Really! Duplicated 4 times. Please don't keep hitting the save/submit/post button several times. Give the server a chance to do its job. It could be busy or your network/internet connection could be slow, so you don't see the response happen instantly. Tom
  10. My 2700 tends to feed towards one side as well. Doesn't sew straight without being guided. Tom
  11. Resize photos to 800 x 600 pixels. For your file that is being a problem, try emailing it to yourself and see what happens. In Windows Explorer, select the file, send to recipient, etc. The file might be corrupted, but I would question that if you can view it without problems. Is the file extension .jpg or .jpeg? If it is .jpeg, try renaming a copy. Tom
  12. And the problem and repairs were ?????? I think all those following this thread would like to know. I certainly would. Tom
  13. Take the belt off and rock the drive pulley by hand, else you are likely to do more damage. When a machine is locked/seized up, trying to power through is looking for a lot more damage and problems. Have you got the bobbin, carrier, and hook out? If not pull them out so you know they are not jammed. Tom
  14. Moved to 'how do I do that'. Punch two holes, cut the slit between with a sharp knife. Or buy a special punch from Tandy or other supplier. Tom
  15. Part 2 merged with original post. Let's keep related posts/problems together so we can see the development and trouble shooting steps that are taken in one thread. Was the machine threaded, including top and bottom while you were winding your bobbin? If so, there is likely a bunch of thread piled up inside the bobbin and carrier that will have to be removed. Then you should be able to reset the clutch. (Not my type of machine, so take this with a grain of salt.) Tom
  16. Here is your first post. If you go to your profile at the top right of the page, you can see a listing of your posts. Tom
  17. See this post Tom
  18. From the IP address, the OP appears to be located in Singapore. I would advise all members to at least add their country, and maybe the state as well to their profile. It will enable people who live in the same general area to give you more helpful advice. Tom
  19. Has a nicely shaped yoke, so is easier on your fingers. Barrel diameter appears small, but some like the smaller diameter. I like 5/8" diameter. Just feels better. Adjusable height would be nice too. If you can, depending on location, ask to try them out before purchase. But since Tandy has a good guarantee, you should be able to take it back if it doesn't suit you. Tom
  20. This is an excellent example of why photos should be sized to fit here, and posted here. When they are moved or deleted later, maybe even 5 years later, the thread may become useless as the examples are no longer available. I encourage everyone that posts photos of their work, to post them to leatherworker.net either as a part of your post, or in a leatherworker.net gallery which you can then link into your post. Everyone will appreciate it. Tom
  21. Northmount
    Book cover
    OP hasn't logged in since joining on Aug 25. Tabitha, You have a response to your query. Time to log in again! Tom
  22. According to the IP address, the OP is located in Corona California. Tom
