Northmount
Moderator
  1. Similar machine to what I use, but ... If I had such a mess on the bottom, would have made a huge birds nest and jammed the machine solid. So I am wondering if part of the problem here is the safety clutch needs to be reset. Timing and probably bottom feed would be inconsistent. This is purely a guess but maybe worthwhile to check. Tom
  2. Try laying either a couple strips of thin solder, or aluminum foil, or brass shim stock, or strip cut from an aluminum soft drink can across the threads in the hole and carefully thread your punch tube into it. Just snug it up. Don't be heavy handed and tighten too tight. You only need to hold the tube from dropping out. While punching, the mating surfaces are simply pressed tighter together. Another option is to use Loctite. There are several grades available, including a bearing retainer grade that doesn't form a permanent bond, so you can remove it at a later date if you need to replace the tube. Most types will loosen if heated. I used to service mechanical accounting machines a long time ago. Lost a nut that held an eccentric adjustment in place. Put some Loctite on an oversize nut and let it set. Came back a week later with the right parts and fixed it right. It had cycled through thousands of operations during the week and stayed in place in the correct position. Tom
  3. According to his IP address, he is in the UK. Would be great if people would identify their location. This is a world wide forum! Tom
  4. Copied Kate's instructions into a single PDF file. Tom Biker Wallet.pdf
  5. He was last online Saturday, so hasn't seen your post! Good idea to quote a post so he gets an email notification if you want to be more sure of a response. Tom
  6. LOL. If it doesn't burn your fingers, it won't burn the leather. Rather than touching it, I would practice on some scrap to see how it works. Maybe also do a test touch to a piece of scrap to see if hot enough or too hot after you heat it each time. Tom
  7. Thanks, I missed them as I was reading through your post. Tom
  8. A couple pictures showing what happened would help others understand and reply back with suggestions. Tom
  9. Where in the world are you located? This is a worldwide forum. Tom
  10. Then if you move any photos, you break the link and no photos will show in your posts. One disadvantage to posting photos on other sites and linking to them. We see a lot of broken links in older posts for this reason. Best is to resize, down to 800 x 600 pixels. You will be doing a great favour to those that are on slow ISPs where it takes forever to download large images. Tom
  11. Resize your files down to 800 x600 pixels. That is adequate and a real bonus for users on limited bandwidth web connections. There is a lot of software and apps out there that you can use to do this, some even web based so you don't have to install anything on your own device. Or depending on what you are using for an email client, you can email the files to yourself. Others put up images on their Facebook, then download the file as a smaller version and paste into their post. Do a Google search to find apps or software or services that suit you. Tom
  12. See this thread for more information Tom
  13. Check this thread A couple here may still be for sale. Tom
  14. Tandy has some odds and ends (free lesson plans) in their leathercraft library. Might be able to selectively adapt them to your needs. Tom
  15. Reduce the file size. 800 x 600 pixels is large enough for viewing and makes a fairly small file. If you are using a PC, one of the easiest ways of reducing a file size is to email it to yourself. Right click on the file, pick "send to", "mail recipient", and follow the prompts. Otherwise, there are lots of programs and applications available to reduce file size, depending on what you are running. There are some web based applications too, so you don't have to install something on your device. Do a little searching and I'm sure you will find something suitable for you. Tom
  16. Checkout Cowboy thread at http://www.tolindsewmach.com/thread.html. Has a few colours, and good range of sizes. Tom
  17. The name was likely on some equipment that was imported. Over 50 years in the power/steam/petrochemical/process/ and control systems industries. Hard to remember some of the projects and details. I look back on some of my correspondence on some of these projects and think that guy was pretty sharp compared to me, then see my name at the bottom. We sure tend to lose the detailed knowledge when we move on to other areas of work and specialization. Tom
  18. Terrific work. I much prefer the watch band that is a single band with the watch sitting on top like the black one several photos above. They don't exert continuous stress on the pins. Better for the active working man. Pins last longer and don't get pulled out if you snag the watch strap. Tom
  19. Very good representation of a safety valve. In my other life, have done a lot of work with safety relief valves. Am familiar with your company name. Tom
  20. Check with MattMain. See his recent post. Let us know if volumes 1 and 2 are available. Tom
  21. Thanks for the link. Copied files, optimized and converted to searchable PDF. 5 MB approximately. Tom glove_making os.pdf
  22. You might like a cylinder arm for purses. Tom
  23. Try a loop of fresh tape and keep patting the surface to grab the residue. Works for many types of adhesives, might work for you. Tom
  24. And a quart of milk is about one litre. Tom
  25. If it is nice soft flexible leather, it's not likely veg tanned. Most jacket type leather is chrome tanned from what I have seen. And yes, even chrome tanned leather will bleed through when it gets wet enough (water) or with a more volatile solvent. Walked 5 miles in a pouring rain wearing a black leather jacket. My shirt and skin were blue from the leather dye. Jacket was a little stiffer for a few days after it dried out, but softened back up just by wearing it.m Tom
