Laser only cuts by burning. No burn, no cut, just that simple. No other magic rays that cut. Tom
Do a test, see if warming up the leather melts the white residue. If it does, it is wax. Warming it up and buffing it will remove the excess wax. Do a search, there are other threads about wax rising to the surface. Tom
Take a look at http://www.rodnikkel.com/content/building-a-saddle-tree/ to see how a tree is built. Rod and Denise are members here. Tom
Here is the current link on eBay. http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XBlack+240yd+Flat+Heavy+Duty+waxed+thread+for+leather+tent+fabric+hand+sewing+Ne&_nkw=Black+240yd+Flat+Heavy+Duty+waxed+thread+for+leather+tent+fabric+hand+sewing+New&_sacat=0&_from=R40 Tom
Sold http://leatherworker.net/forum/index.php?showtopic=55937&hl=
Just add a post to the thread saying "sold" Tom Edit - I see it is locked so that would stop you adding a new post. Added sold to the thread for you.
There are several threads discussing reducing the noise level for apartment dwellers and for the rest of the family. Types of mallets, support for granite slabs, thickness of slabs, modifications to workbenches, etc. A search would be a good place to start. If you have trouble finding them, let me know. I'd do a search now, but have been at the computer too long and need to get to 'work' instead of play. Tom
Oak Leaf Notebook
Northmount replied to Bob Blea's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice job and pattern. I'm sort of partial to oak leaves! Tom- 8 replies
- carved oak leaf
- portfolio
(and 1 more)
First Five Leather Masks
Northmount replied to LilyLionLabyrinth's topic in Books, Journals and Photo Albums
Great masks, even the face is great! Tom -
Great idea, especially for the one-off jobs where you may never use it again. Tom
They don't erase for me either on the grain side. So on a prototype, I have a couple dots that I was using for alignment purposes that show. Not appreciated. Should have proved it on some scrap first! Tom
Since you backed off the bottom tension compared to what it was (when it was sewing okay before), I would return it to where it was before. There needs to be some tension on the bottom. But an easy pull without any binding as you pull the thread. Then increase the top tension gradually in steps (if the knot is not being pulled up into the leather) while you are testing it. Make sure the top thread is between the tension disks. The knot should be in the middle of the thickness of the leather. Generally, you should leave the bottom tension alone and adjust the top tension to move the knot into the middle of the leather. (Like all generalizations, when you make big changes to the material you are sewing, or sewing with, you may have to go back to the bobbin and adjust it.) So if the knot is on the bottom of the leather, increase the top tension. If the knot is on the top, then decrease the top tension. If the thread seems loose, not pulled firmly against the leather and the knot is where it should be, then both tensions need to be increased. For a needle/thread size chart take a look at http://www.tolindsewmach.com/thread-chart.html There are lots of threads posted here about setting your tension. It would be worthwhile to do a search for them are see what others experiences have been and learn form them too. Tom
Too little top tension is one of the most common causes of the birds nest under the backside of the leather. Make sure the thread is pulled into the tension discs. If that is okay, then increase the top tension in steps and test it. Go back to the thread that was first installed, or at least to the same size. Check the needle for damage or a bend. Tom
Put a piece of fibreglass mesh like used for drywall joints between the layers, or nylon web or such. There is a thread here about reinforcing dog collars that you could search for here. Has some good comments and remedies for straps that stretch. Tom
I have fewer problems with oxalic acid than with the volatile solvents used in cements, dyes and lacquer finishes. As with any chemical you use, read the warnings on the labels and check out the manufacturer's MSDS sheets. Most are available online. Oxalic acid does not need to be highly concentrated to do its job. Strength I use it at smells less than vinegar does. Tom I should add that the oxalic acid "dust" from the crystals would be quite dangerous rather than the weak fumes from the diluted acid. So be careful with the crystals, don't stir up a bunch of dust while measuring out what you need.
I have one, PM me. Tom
Handbag-Clutch
Northmount replied to Tatyana's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Great job! Well done. Tom -
Issue With Consistent Stitch On Cobra Class 18. Help!
Northmount replied to Boa's topic in Leather Sewing Machines
I see an error code 3 show up. For some servos, that is a motor overload. Have you tried hand wheeling the machine with no thread, no belt so you can feel whatever is catching? It could be a fault in the servo, but I really doubt it. To me it sounds like you have a mechanical problem. Tom Edit: Follow Wiz's advice to determine where the binding is happening. -
From 7 and up seem to be somewhat similar. Tom
Aluminum may leave marks, like pencil marks, on leather if the edge is accidentally drug along the surface of the leather. Try it and see what you think to see how careful you need to be. Tom
Established Made In Usa Brand Looking For Handsewn Wallet Maker
Northmount replied to cordovan's topic in Old/Sold
You should provide some info on your location and expectations for volume of work. Tom -
Recommend you download "The Art of Making Leather Cases" Vol 2 by Al Stohlman. There are full instructions for several handles like you want to make. Tom
Servos are available from any of the dealers listed in the banner ads at the top of this page. If you don't see the ads, disable your ad block for this site. Each time you refresh the page, you will see new ads, so you can get to all the dealers. They support this site, and best of all, they help everyone here, not just their customers. In general, most servos will fit, depends on the mounting holes in your table, but they are very standard. More power is usually better. Get one with a 2" or smaller pulley. Might require a shorter belt. Where you have two separate needs, should probably split the request into separate threads. Tom
Do you have the original shipping box for the head? Whether you do or not, I can pull the head and motor off and help you box it up so the mover shouldn't have a problem with moving it. Send me a PM. If you are staying in the Calgary area, I could move it for you (with your help of course). Can't do the heavy work I used to do, so I get in trouble now and then! Tom
- 3 replies
- cobra 4
- used very little
(and 3 more)
