You don't say where you are. There are places in Canada besides Tandy that sell leather and supplies. If you identify your city, you may get some additional answers as to what is available near you. UPS and FedEx charge hefty brokerage fees. Like $45 on a $75 item. Most places don't warn you. Tom
Bible Cover With God's Name In Hebrew
Northmount replied to GamberLeathercrafter's topic in Books, Journals and Photo Albums
Unique! Very good, or should I say excellent! Tom -
Never Give Up
Northmount replied to Tree Reaper's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice job. Should grab people's attention! Tom -
Possible, however surface is pressed or machined smooth. As long as you don't dig into the surface ... which you should never do, layer of rouge should prevent contact. And the surface is very flat and smooth. Recommended by many woodworkers to get cutting tools scary sharp. So far I haven't experienced any problems with using MDF. Tom
If you are not doing a lot of skiving, take a look at http://www.hewitonline.com/Scharf_Fix_2000_Paring_Machine_and_Spare_Blades_p/tl-091.htm and see if it meets your needs. Do a google search for other UK suppliers too to see if their prices may be better. Another option posters have listed here is to use a carpenter's plane. Takes some practise but should be more consistent. Blade needs to be really sharp. Tom Edit: won't work well on thin soft leathers.
Or use a block of 3/4" MDF cut to what ever size you like to use. Nice flat hard surface. Cheap to replace when you want. Just recharge it when it looks like you need to. The black is iron from your knife. Shows it is doing the job. Tom
Serious hobby. Others spend thousands on cars, cards, booze, boats, ATVs, etc. Just depends whether you can afford it. Credit card interest is not kind. Tom
Newbie On The Lookout For A Sewing Machine For Bags
Northmount replied to aleejelly's topic in Leather Sewing Machines
Cylinder arm walking foot machine, so you can reach inside bags to do some of the seams. Tom -
I'd watch how dry the books are that you are storing with silica gel. You don't want to pull all the moisture out of the leather. The silica gel shouldn't have any effect on the oils in the leather, but will have on its moisture content. The alternative might be to spread them out so air can circulate around them. That will take more space! Check the relative humidity in your house. If your house is well sealed, it could be high. Hot water and electric heating systems tend to reduce the natural air exchange, increasing the humidity. All the things we have been doing lately to seal up cracks, direct vented furnaces, etc. lead to higher humidity. Then we have to add increased ventilation! How much do the windows sweat on cold days? If there is a lot of condensation, humidity is too high. Was the shelf you were storing your books in on an outside wall? If there is not enough insulation in the exterior wall, stuff laying against the wall and in closets on outside walls collects moisture due to being colder, and gets moldy or mildew. Hope you get it all sorted out soon. It is very upsetting when our work gets damaged! Tom
- 11 replies
A piece of 3/4" mdf makes a good stropping board. You can cut it to any convenient size. Extremely smooth flat surface. More durable than a business card. Don't need to attach a piece of leather to it. Some posters will tell you that a leather strop is too soft and tends to slightly round your sharp edges. Tom
Looks like you need a drop down edge guide. It can ride on top your bottom layer with the bearing guide against the top layer. Allows fairly sharp turns. Tom
You may have a mold problem in your house that is spreading spores. Wet cold walls, bathroom tub/shower area, basement, etc. get it checked out. Some molds are a serious health hazard. Your relative humidity at 72 F should be 50% or less. High humidity contributes to mold growth. You can use oxalic acid in place of lemon juice. Available at lumber, hardware, paint stores, or can be ordered through your pharmacy. There are other threads about mold and about oxalic acid here. Check them out. Tom
- 11 replies
Pretty nice! Welcome Tom
In Desperate Need Of An Old Tandy Pattern For Top Stub Checkbook Cover
Northmount replied to AriezMoon's topic in Old/Sold
Maybe your bank, or another local bank has the same offering. They should be interested in selling you that series of check book. Tom- 4 replies
- vintage tandy pattern
- checkbook
(and 1 more)
Happy New Year Where Ever You Are In The World.
Northmount replied to shadowryder's topic in Member Gallery
Thanks, pass it along, Happy New Year to all. Have a safe, healthy and prosperous New Year. Tom -
American check sizes are standard (binding is on the top edge of the book). So you can measure your own, or a friends unless she is using something totally different. Tom- 4 replies
- checkbook
(and 1 more)
Try working some neatsfoot oil into them, but not too much at once. Tom
Very nice work, both sheath and knife. Tom
Too nice to sit on! Tom
My Watch Straps
Northmount replied to Blak Smyth's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice straps. Where do you get your buckles from? Tom -
When you are stamping letters, write it out first and maybe even check the dictionary. Then stamp it following a rule or lightly scribed line. When stamping an item for a customer, especially names with some of the strange spellings today, get the customer to print out the letters, or type up, or email, and keep a copy. Then a miss spelling is his mistake, not yours ... if you followed his script. Tom
Breastcollar & Headstall Overlay Question
Northmount replied to ranchmom77's topic in Saddle and Tack Accessory Items
Photos would help members comment on how to solve the problem. Tom -
Welcome from another Calgarian. Enjoy your stay. Tom
