Or punch a hole in the belt to fit, epoxy the leather to the metal tip, then cut or file off the excess post, or take the post off completely and just epoxy to the belt. Tom
Bill Fold Critique Needed
Northmount replied to jamos1978's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Pretty good for 6 days! You already know what you need to work on, so the next step is more practise. And when you think you have practised enough, do more practise. Tom -
And you can attach a flat bed adapter to a cylinder arm machine. Depending on what parts you are sewing, sometimes the flat bed makes that part of the job easier. Tom
Wallets In The Snow
Northmount replied to Bifrost's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Pretty nice. Lots of color. Check the tension on your sewing machine. I notice in the first couple pictures, the knot is pulled up too high. Tom -
Made A Check Book Cover Today
Northmount replied to Fd3615's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looking pretty nice. Keep it up. Tom -
White Powder Crystals On Leather Surface
Northmount replied to chevvy64's topic in All About Leather
Warm them with a hair dryer to see what they do. If it is fat, will tend to melt as it gets warm. Tom -
To help reduce the wrinkling in the lining, form the leather as you glue the lining in so that it is curled about halfway to the position it will be when fully folded. I assume you are concerned with the flap. Note that the flap will not return to flat as it has to stretch the lining to do that. If you can't tolerate not being able to return to flat, then you can design (force) wrinkles in the location you want by gathering a little extra bulge in the lining as you glue it. Try it on some scrap pieces first to see if it is doing what you want it to. Tom
Google Search Results Containing Malware
Northmount replied to Dennis Oakley's topic in Feedback and Suggestions
Works fine for me. You likely have a root kit virus, pointing you to a rouge DNS server. Search for malwarebytes and install it and run a scan. Also download tdsskiller from support.kasper.com/5350 install it and run it to detect and fix. I had a similar thing a month or so ago, also related to google searches, but couldn't get any results from a google search. Hope this helps Tom -
I second using a hair blade. Try the fine and coarse to see which looks the best. I'm tending to the fine blade, since the thistle is wispy. Tom
Difference Of Craftsman Oak, Oak Leaf, Live Oak Tooling Leather?
Northmount replied to naturalisme's topic in Getting Started
The catalog has some description. I'll abbreviate their descriptions. Live Oak - Best, top quality, long life, superior performance, excellent carving, tooling, dyeing, oiling qualities, American sourced Oak-Leaf - Good, premium import, excellent tooling and embossing, occasional blemishes and brands, fine hand carving leather Craftsman Oak - Economy, imported, medium firm temper, stamp, carve and dye well, low cost, may have brands, blemishes, insect bites. Tom -
Check that your leather scraps are vegtan leather. Depending on the bag of scraps you got, there may be leather that isn't suitable for stamping. If you haven't cased the leather, read up on how to properly case leather before carving and stamping. See http://leatherworker.net/forum/index.php?showtopic=19121&hl=%20casing%20%20tutorial&st=0 casing tutorial by Hidepounder (Bob Parks). Dry leather doesn't take impressions well. Tom
It would be great if people would read the last few posts in a thread instead of just the first one or two. Look at post number 88 immediately above your post. Tom.
Try applying very light layer of glue to both pieces and let set a little before pressing them together. Or use contact cement, but still keep the layer of glue thin. For very porous surfaces, you may need two coats if the first coat soaks in and dries to quickly. Two thin coats are far better than a heavy coat. Remember for contact cement to let the glue set until almost dry (very little tack) before assembly. Press together with a roller after you have positioned the seam correctly. With most contact cements, you have little chance of repositioning the parts if you aren't lined up correctly. Avoid getting any glue on surfaces that are to be dyed and finished. Will show up after the dye or finish is applied. Tom
Try using a deglazer to remove anything on the surface that may be impeding the dye soaking into the leather. Also try using some oxalic acid to remove any stains. Otherwise, a lot of posts recommend thinning the dye, then building up the color in layers, allowing to dry and buffing well in between. Airbrush has also been recommended. Not too expensive so might be within your budget. Lots of info on airbrushing here if you want to do a search. Great job on the hat, and keep testing different ideas for dying the leather before actually doing the hat. Too many of us are in a big hurry and jump right in without any testing or practice. Tom Edit: Some do dampen the leather slightly before applying the dye. Some also give the leather a very light coat of oil (Neatsfoot or Extra Virgin Olive OIl (EVOO)). Neatsfoot will darken the leather more than EVOO.
Found a 270 page PDF called Bush Leather Work by Ron Edwards. http://blog.survival-goods.com/LIBRARY/Manuals/bushcraft%20leather%20work%20PDF.pdf Lots of info on lace cutting, plaiting, making pouches, bags, belts, etc. Hope you enjoy looking through it. Tom
Go for it. You may be able to work through a local college's continuing education program to help look after the logistics. Though that could lock you into a lower hourly rate for your time. Some high school con-ed programs may do the same. Also consider libraries. Tom
Descriptions and pictures might help you sell these kits. Reminds me of an old saying about "buying a pig in a poke" or something like that. Your location and shipping might help too! Tom
Personal Gallery Picture Problems
Northmount replied to LNLeather's topic in Feedback and Suggestions
This is one of the best places to be! Happy New Year to Joanna and the rest of the crew that makes the site work, and Happy New Year 2013 to all the rest of you leather workers out there! Tom -
Great job. Almost too good to give away! He should really appreciate it. Tom
I agree with Wiz. Need to be able to look down on your work. I have a neck and shoulder problem so becomes painful to work with arms raised. I dropped my table to as low as it can go. Recently obtained an old piano stool with screw height adjustment. So can easily adjust for what I am working on. A stool is better than a chair, nothing in the road of your elbows when sewing or reaching for something. The table needs to stay above your knees ... obviously! Tom
Card Wallet
Northmount replied to Spincycle's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice, also practical. Tom -
Files are okay for axes. Haven't ever used them on my leather tools. Tom
- 11 replies
- sharpening
- stones
(and 3 more)
Or are you really looking for rectangular holes? I've seen them on some designer belts somewhere, where the buckle tang is wide and flat. I did a Google search and found some rectangular punches for watch straps, but that is small! There is a thread posted here, again about watch straps, but with some ideas. Also a link to a 2 x 4 mm pliers type punch in post number 8. http://leatherworker.net/forum/index.php?showtopic=30979 Tom
Pretty great job for first time. I don't think I would even try it. I think your client will be very happy. Tom
