Northmount
Moderator
  1. There is a video for a clutch on a Singer 111W155. Yours may be somewhat similar. It is in post #90 in this thread http://leatherworker.net/forum/index.php?showtopic=43582&st=90. It has some good info for those that really want or have to delve into the insides. You may find the whole thread interesting too. Tom
  2. Pretty nice. I like the 2 tone. Lots of stitching there, hard for me to tell if it was machine or hand. In either case, really nice job. Tom
  3. Follow Cheryl's link above and refine the search to line drawings. Under the bing search bar, there is "Type". Pick it and select line drawing. Then you can use the line drawing for the pattern, and reference the photos while tooling it. Tom
  4. The logo may be hot stamped, burned into the leather. Tom
  5. There was something rattling around in the back of my mind ... finally realized what it was. Johnny Cash, Ring of Fire. Now you really have to do it! Tom
  6. Why not flames in circles? Tom
  7. Here is a link to some ideas. There are commercial products out there to do the job. Some are listed in the link. http://lifehacker.com/5897807/how-to-remove-rust-from-old-tools You can find may more ideas and methods using Google. You can even use electrolysis to reverse the action of the rust. Except for electrolysis, I would stay away from water. That's what causes the rust to start with. Be wary of any method that involves a lot of scratching like wire brush, emery paper etc. It depends where it is on the tool. Adding scratches to the face of a stamp, or abrading the pattern is not something you want to do. Brass brushes generally won't damage steel surfaces since the brass is soft. Be cautious of strong acids and other chemicals. With all the different rust removal methods out there, think about what the results are that you want, use some common sense, and you should be able to reclaim these tools without causing further problems. Tom
  8. Looks really great! How does the tab fit in? Another picture might help me see how you fit the tab to close it. Thanks Tom
  9. I have to agree. Very inspiring. Now to try something similar here! Tom
  10. You don't want to use any dye that includes red. Brown includes red. To get a lighter colour, you have to bleach colour out of it. Tom
  11. Looking good. If you shorten the liner a little more, it won't bunch up as much in the middle when folded. But the downside of that is it won't lay flat when open. At a guess, I'd take another 1/8" to 1/4" off the length of the liner. Since this is only from a photo, it's hard to tell how much it has bunched up, but you can tell better than I if you need to make any change. You do great work. Tom
  12. Here are a few links that may help you with depth of field. Mostly, get more light on the subject if you can, but there is more to it that can be done. http://digital-photography-school.com/aperture http://digital-photography-school.com/a-deeper-look-into-depth-of-field http://digital-photography-school.com/overcoming-depth-of-field-problems-in-portraits Good luck on saddle #2. Tom
  13. Try this http://www.tandyleatherfactory.ca/en-cad/search/searchresults/9132-01.aspx has a backing, somewhat resembles leather, but the backing helps with the fraying problem. They have black and brown. Tom
  14. Great job. I like old furniture. It's a shame to see it get trashed. This is the way to go! Tom
  15. Long way from North Dakota, so probably not the same clan. Tom
  16. A little more information could be of help. What part of the world do you live in, or where the purse was purchased, down to at least the city and state? How long has it been in your possession, something to help with possibly determining a rough age or time period? Better photos would help too. Try about 800 pixels wide so we can see some detail. Adjust the contrast and mid tones to improve what we can see. I can find some info on Harkness, but won't spend the time if the locations don't compare. My grandmother was a Harkness. I think I can contact some of her family's descendants if the location fits. Tom
  17. #9 wire works better for your pickup. A little harder to twist up tight, but a fencing pliers usually does the job. Lasts a lot longer on country roads and trails! Tom
  18. Thanks Bob. Great story. Tom
  19. Take a look at this thread. http://leatherworker.net/forum/index.php?showtopic=43081&st=0 There are some other threads here to with good information. Use search. Tom
  20. Lucky guy, to get Ann Sthoman's guidance. And, from a guy that can only wish to be able to make a saddle, you have done a great job. Also great mentoring comments to others. Tom
  21. Yellow woodworking glue dries hard, not flexible. So when you bend the leather items glued with it, you will hear the glue cracking. White glue dries flexible. So will hold better where you expect flexing to take place. Woodworkers don't normally need their items to flex. Tom
  22. Fantastic job. I can only wish to do that someday. For the photo #4, to get the whole photo in focus, you need to increase the depth of field by using smaller lens opening near f16 and longer exposure. The the horn and cantle can both be in focus. Tom
  23. I assume you are pulling on the bottom thread and it pulls out easily. That would mean that the top tension needs to be increased to pull the bottom thread halfway up into the leather. The "knot" should be half way through the leather. Generally leave the bobbin tension alone. There are numerous threads here about adjusting tension, and if needed, how to adjust the bobbin tension. Do a search for these threads. You can pick up a lot of good info. Most sewing machine manuals (even domestic home machines) show what a lock-stitch is supposed to look like and how to adjust the tension. Make sure the top thread is threaded correctly for your machine. It seems to be a very common problem when people get a new machine, especially if they have little machine experience. Tom
  24. Fantastic. Truly great work. Something many of us can only aspire to. And to a great cause. Tom
