First Project Done, And Some Questions
Northmount replied to BulletProof's topic in How Do I Do That?
They will work great on inside corners too! Didn't need to buy my big punches! CTG -
Cold Weather And Dying Leather
Northmount replied to Matt Alsaker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
If you are handling just a small amount of dye at a time, a simple fan in the window sucking the fumes out will not get to an explosive mixture. Also if you pick a fan with no starting winding (no electrical switch contacts inside the motor), there will be no sparks to initiate combustion. So most box fans and window fans that start slowly and take time to get up to speed are none sparking. If you are handling large amounts of dye, or spraying, two windows would be nice, blow air in one and let if find its way out the other. Different inflamable fluids have differing lower explosive limits (LEL). You can look up and compare alcohols, naphtha, diesel fuel, gasoline, natural gas, propane, butane and see what the LEL for each happens to be. It will give you some idea of how much risk there is. Also look at the flash temperature to see what temperature a hot surface has to get to before it will cause ignition. Like if you have an electric heater in the room!. One of the worst fluids for a wide range from LEL to higher explosive limit is hydrogen. It is explosive from 5% to 98% in air. I have seen a 99% hydrogen atmosphere in a compressor house. I asked the supervisor if he wanted me to shut of the power to the building remotely at its source. He said no, we'll just ventillate it. The fire crew brought in water powered fans and placed in the doorways. They brought the concentration down from 99% to next to zero, safely passing through that explosive zone. Then they couldn't find the source of the leak! As you are doing, it is important to consider the the risks of explosion when handling inflammable fluids. I know of many instances where serious explosions and fires have occurred due to cleaning paint brushes near an open flame, trying to repair leaking gas tanks in an enclosed space (garage), etc. Buying drum dyed makes a lot of sense! CTG -
Here is another interesting link. Shows you can get by without buying a lot of expensive tools http://leatherworker.net/forum/index.php?showtopic=42981&hl= until you know what you really want. There are many things you can do to work around not having exactly the right tool. CTG
You can get hole punches of any size for inside corners. Just bought a 1/2", 5/8", 3/4" and 1". For outside corners, take a look at http://leatherworker.net/forum/index.php?showtopic=42883&hl= CTG -
I kind of thought there was some sarcasm here considereing your past work and non-Snap-On tools. But I just couldn't let it go by. I still use a lot of different and cheaper tools in the several hobbies I work with. Some tools obviously have to be replaced, and you soon find those ones. Like a $30 impact wrench that won't undo wheel nuts! CTG
Take a look at http://leatherworker.net/forum/index.php?showtopic=40461&hl=starting#entry251728 and follow some of the threads. The advanced search function can be your new best friend too. CTG
Do All Sewing Machines Give A "lock Stitch"?
Northmount replied to Tallbald's topic in Sewing Leather
Flour and sugar sacks that are sewen closed are done with a chain stitch. As a kid, I used to collect the string from them for other projects. If you start on the right end, you can "unzip" the whole thing with one good pull. So like on boots and shoes, the needle/thread has to be sized tight in the leather, and bees wax, etc. to lock it in place. And layers are usually glued, so if the surface thread is damaged, it doesn't fall apart. Like TwinOaks says, no machine does saddle stitch or anything close to it. CTG -
Tools and toys don't make the man! Some tools definitely make the job easier, and that is one of the reasons we buy them, often starting out with the cheap ones until we see their short lifespan or other problems. What makes the man is what you do with them. And as you have done with other work, how you have done work-arounds to get the job done satisfactorily. Some people buy tools and toys just to show them off. Others really use them. CTG
Where To Find Tree With 20" Seat ?
Northmount replied to 15mules's topic in Saddle Supplies, Tools & Trees
Try Denise http://leatherworker.net/forum/index.php?showuser=5669 Or their business site http://www.rodnikkel.com/content/index.php/contact-us/ CTG -
Making Molding Card Case
Northmount replied to hunio's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Divide Korean price by 1000 to get approximate US/CAN $ price. Google translator will do some translation, but you need to sort of read between the lines. Single words translate different than sentences or phrases, but will give you some idea. CTG -
A Few Questions On Stitching With Linen Thread
Northmount replied to kwelna's topic in Sewing Leather
Some of the stitching in your examples is pulled way too tight so it is cutting into the leather and causing puckers. Were some of these wet when they were stiched? On others, the taughtness of the thread seems to be random. Practise trying to pull up the same taughtness consistently. Thinner leather has to be treated a little more tenderly than thicker. If holes are too close together on thin leather, it is very easy to cut through the leather when pulling the thread tight. How are you punching your holes? If using an awl, the awl should be angled so the little slots aren't point to point. I can't see from you pictures will enough to be sure what your method is. There have been a number of stitching questions in the past couple weeks and some really good advice given by the Old Grump and others. Do a couple searches to see their comments and instructions. CTG -
A piece of 1/4" hardboard will work in place of your marble/granite. (Obviously not as good, but will do for most beginners until they get serious.) You can laminate it to a piece of 3/4" plywood if you want to give it a little more substance and reduce the noise level. And I agree, get the kids to work on the floor. Fewer things to break and push around or tip over. CTG
Keep your bench area clean. Especially oils, dyes ... If your bench area is used for other work where you can also pick up contamination from sawing, filing, working on other stuff, clean the area well before you bring leather back to it. Vacuum up filings, dust, dirt, etc. And as mentioned above, keep your hands clean, use latex gloves, etc. to reduce chances of contamination. Also realize that some marks or what appears to be stains show up after the leather has been cased. If your water has high hardness and minerals, consider using demineralized or distilled water. CTG
Molding also affects the way the dye is absorbed. Forced drying in a cabinet stiffens/hardens the leather and will affect how it accepts dye. As already mentioned, slighly moist leather accepts dye better. From other threads here, if memory serves correct, some people are lightly oiling the leather before applying dye ... but you should search and see if I remember correctly. You can also do some test pieces to see what works the best. For your test pieces, if you are dyeing molded leather, do everything the same with your test pieces, including molding and using a piece from the same hide. CTG
Looks like a gouge used in wood carving. Looks like I didn't need to buy large hole punches for inside corners, should have brought in the carving and lathe tools. I will definitely use the gouge for the outside corners instead of making another similar tool! There are a number of woodworking tools that can be used for leather! Just need to wake up and see the possibilities. CTG -
See attached http://leatherworker.net/forum/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=66250 Very good book by Bob Park on designing your own patterns. CTG
Need Help With Making A Winter Hat Pattern
Northmount replied to johnggrg's topic in Patterns and Templates
Did a search for orange peel pipe layout and got this result, should be something in it you can use. https://www.google.ca/search?q=orange+peel+pipe+template&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a Was going to scan a page out of a pipe trades handbook, but decided to search instead. CTG -
Really great! CTG
I agree with you about lemon juice. There are others here that use it rather than track down oxalic acid, or that seem to be uncomfortable using something with acid in the name. Oxalic acid has always done a nice job for me. If you can't get it in a good paint supply store, then order it through a local pharmacy. Cost less than $20 for about a pound. CTG
It's possible. Maybe a few filings stuck to it past your stroping, or maybe even on your fingers. So yes, wipe down your knife carefully and wash your hands before handling the leather. I was just wondering if some hand creams would do this, but not likely as dots, more likely as finger prints. What about your water source for casing? If you have iron pipes in your area, it could be from some rusty water. Does your tap run muddy red first thing in the morning sometimes when the first flow of water stirs the sediment in the pipes up? I was in an old city (Belfort France) one day when they had done some work on the street water main. After the water was turned back on, it ran muddy red for a couple hours before it got flushed through. Didn't feel like showering in it! Some people will only used distiller water or demineralized water for casing due to there water possibly being contaminated with minerals. Lots of water wells in rural locations have high iron content. CTG
Try with cloth. There should also be examples on the web with segmented spheres or hemispheres, like peeling an orange. Or find a cheap baseball cap and cut it apart for the triangular orange peel shapes. CTG -
Glue together before triming the edges and before punching holes for lacing or doing your stitching. Don't glue the liner at the bottom fold, the liner needs to be shorter than the back so it doesn't pucker up when folded. If I use a one piece liner, I cut the edge back to miss the lacing or stiching at the bottom fold. For a one piece liner, the wallet won't open out flat. A 3 piece liner that allows the center piece to float can lay flat and can fold without puckering. See the following threads for some help with wallets. http://leatherworker...let#entry265281 http://leatherworker...60881.  There http://leatherworker...=0 Good luck. Wallets shouldn't be hard to make if you take a look at how the liner and the back have to interact as the wallet is folded. CTG
The dots look like contamination with iron filings. The tannin (tannic acid) in the leather plus iron make these dots. Check out the vinegaroon process used to dye leather black. Need to keep all metal filings away from your leather working area. You can use lemon juice or oxalic acid to bleach the dots out. Some people use a q-tip or paint brush to treat just the spot. You can bleach the whole surface if necessary. Do a search for oxalic acid here and you will find lots of posts. Good luck with your big project. In about 1961 I got into leatherwork because my grandfather gave me an old saddle that needed a lot of repair. The saddle got left behind in one of our moves, so never ever got fixed and I haven't ventured into saddle making or repair. I envy you and compliment you on being brave enough to try on your own. CTG
Yup, when your hands and fingers get sore enough, you'll definitely accelerate your savings! CTG
How To Distinguish Various Leather Weights
Northmount replied to samcolt45's topic in Leatherwork Conversation
There is a thickness table here. http://www.tandyleatherfactory.ca/en-cad/home/infoandservices/leatherguide/leatherguide.aspx CTG
