Everything posted by LeatherLegion
Sorry , I was a bit vague. Call your local Tandy store. I assume since the Montreal location is closed , Markham or Mississauga location is who you want to call for any alcohol based dies , finishes or contact cements.
Call your local store for Fiebing's dies (pro or regular) and order them over the phone . I am also sure they might be able to answer some of your questions too
Dog collars - always worked flat?
LeatherLegion replied to Klara's topic in Collars, Cuffs, Leashes and Leads
I've been making dog collars for a long time...this is an interesting design that I've never seen before -
When you say padding , is that some kind of foam inside your soft leather ? I am only using 3-4 oz soft leather for my "padding" nothing stuffed inside ...it is more for aesthetics . If needed , the softer rolled edges are more than enough protection in my opinion -
I think the padding is way to thick. With or without the top strap attached , a padding that thick will wrinkle regardless , when bent into a circle . If I am making a collar using two ply , I am always gluing them together around a form. My padding is not nearly as thick of yours and I still get a bit of wrinkles . I am using different size PVC pipes as forms ... helps me with collar sizing too . -
Did you called your local Tandy? The website shows "out of stock" but some stores might actually have it
Make round holes around curves...you are not gonna have that problem anymore..especially in small radius curves. Also start making your holes from the center of the curve and work your way up on both sides..this way your last stitches , left and right side, will be equally distant from your key ring
I drove all the way to Toledo from Toronto Canada...never regretted it...Bob was great Dealt with Cobra and their customer service is impeccable ...they went the extra mile to help me when they didn;t have to Either way , you can't go wrong
Anyone used a Tandy Craftool Pro Rotary Strap Cutter?
LeatherLegion replied to Catbalou's topic in Leather Machinery
It does the job. I like the portability , easy to set up, cuts through 8-9oz easily -
I've been looking for one of those for more that a year with no luck. Best option is to order a brand new one if you have the money
- 3 replies
- table
- sewing table
- (and 3 more)
2800 not 4800
I have a Nakajima 341 using the singer 111 feet...they don't fit the techsew 2800...the setting screw holes don't align
Hi there Would the 335 presser feet work on a Techsew 2800 ? Are there any other accessories interchangeable between the two machine ? I just want to make sure before placing an order on ebay . Thank you
I believe we're overthinking the whole Tandy "situation" . This is one of the biggest companies out there when it comes to leather , leather tools and hardware , leather dies and pretty much everything else needed to get you into leather craft , all under one roof . They got rid of their membership fees , dropped prices and some of us took that as a bad sign. They are rolling out a new web-site and closed down less that 10% of their stores during a pandemic and that's somehow a bad sign...unless those were the overperforming stores bringing in huge profits They've been around for 100 years taking pride in interacting 1 on 1 with their customers , offering classes in pretty much all of their locations ...i think it's unlikely Tandy will switch to an online business model. I've been shopping with Tandy for about 20 years and my good experiences, overshadow the bad ones by a mile . As far as i am concerned , i am not ready to write them off yet , based on their current situation.But than again , bigger companies out there went under , some of them even without any warnings . I guess time will tell but i am not gonna waste my time "reading the signs"
I am looking for a 3.85mm Crimson Hides stitcing irons set. Please messege if you have one willing to sell Thanks !
6 coster set
LeatherLegion replied to LeatherLegion's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Not really. As i said , this is one was more of a prototype. I mght actually sell ths set as kit that can be dyed , stamped , carved by whoever might be interested in it -
6 coster set
The main pieces are die cut , the slits are cut by hand. The suport is actually cut with one of my card holder dies.For the 2 retaining pieces i cut 2 strips 1in wide and use the coaster die to cut out the curved edge. The joint cut outs were done with an oblong punch. I just have to find a better way to cut those slits easier and cleaner -
Quick little project on a Saturday morning...more of a prototype than anything else. The whole thing is made out of veg-tan 7-8 oz leather. As always , critiques are more than welcomed
That was probably one of the funniest things i heard in a while
- 9 replies
- quilting
- walking foot
(and 2 more)
