I have two standard 45K flywheels - if someone needs one
Trox, the POW´s in the GDR must have been South Vietnamese. The GDR and Russia supported North Vietnam during the Vietnam War. But lots of people from Vietnam worked in the GDR regularly since they were "socialist brothers". I also have been in in the former GDR in 1994 for a few month when they build up the new German Army on the former GDR territory or as it was called at that time "the 5 new federal states" or "5 re-established states". I was around Delitzsch - Halle - Leipzig - Bitterfeld and that really really sucked - all gray, ugly, stinky, lots of rotten infrastructure.... And guess what - just recently I again drove through that era while picking up something (first time since 1994). Really a lot has changed (!!!) but you still can see the "old charm" in some areas. In some spots they really still have a lot of work to do - if you know what I mean. And back then when I was picking up the skiver (more down to the south east) we talk about here I have been in an old factory (out of business but buildings are still there) and that looked like the times have not changed since then... and the weather that day really matched the impression... let me see if I can find the pictures.... But yes, they build excellent machines, motors and stuff. I even sometime look for old GDR tools on Ebay. EDIT: Looks like North Korea nowadays
- 13 replies
- skiving machine
- skiver
(and 2 more)
ha ha - and again I have learned something So I better shut up here @ David - so forget my message regarding the disc splitter seems you don´t need it.
you have to run the thread between the discs not on top of them.... That may help a bit already...
the 45K68 was designed as a sole stitcher machine AKAIK so it may be different to other 45K´s. I actually never have seen one live so I don´t know the difference in particular but when you look at the parts list it may help you. Seems the lever is designed that way have attached the parts list 45K 68 69 71.pdf EDIT: poor quality PDF as I had to compress is the linked one is better: http://hensewfiles.com/PDFs/SINGER 45K68.pdf
sure - it´s timeless and always looks good and the hammer tone paint is covering small surface irregularities very good and - I ran out of pink and purple. Gigi - you forgot to mention "Dan the Picker" who drove this thing all the way across Europe.
- 13 replies
- skiving machine
- skiver
(and 2 more)
That really is an amazing chunk of metal. Was not always fun to restore but turned out quite good. Actually the first skiver I ever have touched and I really was impressed by the well designed gear drive system. Some sticky heavy duty grease should reduce the sound a bit. Glad it is working well.
- 13 replies
- skiving machine
- skiver
(and 2 more)
recomendations for a good heavy duty, walking foot, zig zag
Constabulary replied to mixmkr's topic in Leather Sewing Machines
Maybe an Adler 166 / 266 - just a suggestion. -
few machines to choose from, which one would you pick
Constabulary replied to beltbuckles's topic in Leather Sewing Machines
Sounds like a good deal. The 138 I´d start with a size 100 / 120 (metric) needle and the other with size 120 /140 needle (metric). Singer parts will most likely not fit - maybe a few screws or springs but within a brand some parts are interchangeable since f.i. the 69 is using a lot of parts of the 67 /167 and the 335 parts of the 145 / 545 and so forth... BTW - the 138 has gearboxes (usually 3 - 2 on connection shaft and 1 for hook driving) I´d clean them and fill with new grease -
at least closer than the 45K in Germany Who know´s maybe you start a carpet business soon. I just wanted to give a hint for a similar machine (like the Gritzner)
I´d check with Keysew.com or Toledo Sewing machines or if you know someone with a lathe he (or she) can make some....
depends a bit on the machine...
Just found this auction - Singer carpet Stitcher 35-1 - looks "quite" close to the Gritzner I´d say. http://www.ebay.de/itm/322537972364?ul_noapp=true Jimi, thats close to you
Singer 45k 21?? with table and treadle €190
Constabulary replied to jimi's topic in Leather Sewing Machines
Germany is "ADLER country" - not many folks here appreciate vintage 45K Singers (but heard there is at least one who does )... Over here you find more Adler 5 than 45K cylinders. I was hunting high and low for my 45D91 with reverse... I checked with the seller of the 45K21 - not much additional accessories included - she added a picture now. Jimi - no roller foot for you as it seems... -
They relisted it for way less later snot sure if it ever sold http://www.ebay.com.my/itm/-/121833070621 EDIT: and here it is again: http://www.ebay.com/itm/GRITZNER-PATENT-LEATHER-SEWING-MACHINE-VERY-RARE-/122352734794
I don´t hold you back - take the chance (and time - how long do you drive from ES to DE?) - could be a good deal. From just seeing the condition of the badges I´d say it could be in excellent condition. Quite small pictures though. -
I think that could be a nice one but too far away for me. -
CB4500 reverse stitch bottom loops
Constabulary replied to Zandeosaddles's topic in Leather Sewing Machines
Acrylic needle plate - EXCELLENT IDEA - not only for Cowboy 4500 -
Is it probably the shuttle race spacer where the thread keeps hanging? Aren´t there different size shuttle race spacers out there? At least the 441 parts list shows a range of spacers in the listing. Idea is when you add a thinner spacer (don´t know in what thickness they come) the hook goes in a bit deeper and then there is a bit more clearance between "shuttle driver tip" and shuttle so the thread can easier pass through. Just a a wild guess guess Or try thinner thread and check it it still does the same thing... Have attached a 441 type parts list where the spacers are listed (#44 -#50) part-441.pdf -
I don´t wanted you to remove the pictures of this interesting machine entirely. But people (too) often quote posts just because they want to notify the original poster that they have answered a post (I think) but this only works when notifications are turned on (AFAIK). That for sure makes sense (sometimes) but quoting a long post incl. all pictures just makes the threads annoyingly long. I´d recommend editing a quote text to a reasonable minimum and remove all pictures except the member has a question that requires a certain picture in the quote. Thats all I wanted to say. Just my 2 cents.
- 42 replies
- leather sewing machines
- what machine is used for leather
(and 13 more)
- professional leather sewing machine
- which leather sewing machine is best
- best machine for sewing leather
- sticky???
- sewing leather
- best antique leather sewing machine
- best new leather sewing machine
- leather sewing machines makes and models
- what machine do the pros use
- leather sewing machine reviews
- leather sewing machine opinions
- best sewing machine
- leather sewing machine question
aaaahh - well - folks - if you quote a post it would be good you´d remove the pictures from the quote - this makes a thread annoyingly looooooooooooooooooooooooooooooooooooooooooooooong w/o giving new information... I´m not a mod but I think you know what I mean... - no offense! The pictures Gregg posted now appear 3 times in one thread - does not make sense, or does it?
- 42 replies
(and 13 more)
- sticky???
- sewing leather
I see the manual w/o being logged in / signed up on google - I can download it as a ready PDF. I have no problems...
