oltoot
Everything posted by oltoot
  1. Take pics and use them to remind yourself why to never use ringshanks when making anything. Remember that you might be the one who has to repair whatever it is that you make
  2. The blade will end up being more important. And IMHO hollow ground is the way to go, all other things being equal, and you must have properly cased leather to start with.
  3. If you can get a hold of some saddle catalogues from the teens and twenties, that might help some.
  4. I would offer this perspective: think about a naked man on a naked horse and then fit the necessary stuff in with the least possible interference with that beginning relationship. Smooth out some things by softening some angles. And remember, when it's right it feels good and not strained
  5. could be as simple as skipping when work is crowded or pushed a little.
  6. All the notes prove the complexity of the topic. One easy way out is by using the tool simple little available from Tandy for injector razor blades and one handed use. A little filing can change shape of the opening for different uses. For me, actual draw gauges became collectibles as opposed to daily using tools.
  7. Ditto and if it has the fiberglass covered tree, even less. Somebody might make use of it to sack colts. Just for more knowledge you might use some of the hardware to tie things down closer,
  8. Shoulder about mid way between back and belly
  9. It is fiberglass covered (cloth & resin) wood. Probably made for resale to Sears or Monkey Ward via catalog sales
  10. I think yes that in the very beginning of things, tree making and nearly mass produced saddles had to be one coordinated undertaking
  11. Prior (exactly, I don't know) to 1982, CS would hand out orders and parts to any and all takers, then buy back the finished products within a specified time frame and 'fill' the order. It got too hard to handle and they increased their in-house capability and started doing it all with employees was my understanding if that helps you?
  12. Most problems are solved by waiting twice as long as you think you need to for something to dry, the maybe some more.
  13. My combo (that's the key) was a solid (welded steel) bench, 6" thick (gravestone) granite and rawhide mauls. Result was thunk, thunk (barely discernible for most stamping to solid whack for cutting 1 3/4" or 2" pointed straps. At comparable weights poly was a little louder than rawhide
  14. FYI only, the preferred surface of old for many for cutting was aspen. Kiln dried logs milled down. With sanding and flipping, surface lasted awhile. For die cutting and punching, pieces of rubber belting from thrashing machines or paving equip. Now, I would ask a chef or butcher.
  15. The only thing that I could offer would be for the hobble hanger to be about 1" longer so that hobbles would hang down straighter
  16. None attributed to speed, though as it was going at half speed, I had twice as long to bump or jostle things
  17. Steep learning curve but real tight, smooth, pretty stitch. FYI my experience was great improvement when I started using poly instead of linen thread
  18. Little bit but, if you don't sew the cap till last, you can pull and stretch things in line a little better from an additional direction
  19. Final use of the "chinaman" (greased w/ liquid soap) and then repulling ends and smoothing before drying
  20. What you seem to want is probably old harness making stuff, most likely found in Amish or Mennonite junk piles. Would require in person looking or some sort of connection to that community, possibly via some draft horse shows?
  21. FYI and IMHO: Toward the end of my using and making era (~3 yrs ago), I went from similar design to using another screw on top and other tweaks to result in more stable arrangement with more of saddle hand hole availability.
  22. Measure around your biggest horse's neck and be sure that you leave enough extra on the end to buckle around as a neck rope, when needed.
  23. This is what I'm talkin about, unbuckled-hangs straight down
  24. Good point, with custom-ask, with stock, how about both places?
