Everything posted by Troy Burch
Super sheen isn't a very good resister, use a lacquer based product like Clear Lac. the antique is meant to highlight the cuts and low lying areas, the tooling burnish takes care of the rest. I use the Feibling gel, work it in good then wipe off excess, no drying time. After the antique drys buff it with something soft before the final finish to get rid of what little streaks you might have.
- 10 replies
- antique
- resist failure
(and 2 more)
I looked on Tandy's website and couldn't find anything but the saddle lac spray, which I was told took the place of neat lac spray and was basically the same thing (they're both lacquer finishes). I couldn't find any liquid lacquer product at all. I'll look in my shop tomorrow and see for sure what it is. I used neat lac for years and really liked it but I can't tell any difference in the two. Long story short any laquer finish will work good.
- 14 replies
- eco-flow
- waterstain
(and 5 more)
Are you in the USA?
Water Stain Woes
Troy Burch replied to keithpip's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Rewet it and if you can't rewet the whole piece feather it out away from the stains, works most of the time. -
You said you have a local Tandy store, you can save shipping cost buying saddle lac there it also comes in liquid form. Saddle lac and clear lac are the same thing as the old neat lac, just sold under different brand names.
- 14 replies
- eco-flow
- waterstain
(and 5 more)
Doctor's Bag And Tote
Troy Burch replied to opus56's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
nice -
How big are these? lol, never mind It helps when I read the header.
In my experences Saddle Lac is by far the best, I use the spray can and spray two light coats about 30 minutes apart and let cure over night. I was using top coat but it's not much better than super sheen and it will give what you want resisted a slight yellowish brown tint. I use tan antique gel alot works great.
- 14 replies
- eco-flow
- waterstain
(and 5 more)
Springfield leather co.
Wet the leather then let it dry back to almost normal color, then put in a bag in the fridge overnight. This will make the moisture content even thruout the leather not just wet on top. The way you were wetting your leather the beveler cant do its job on the middle and bottom where its too dry. uncover just enough at a time that you can tool that area before it loses its moisture. no need to recover what you've finished tooling. do the decorative cuts and back grounding last as they need less moisture.
You don't have to cut deep to have plenty of depth in the tooling. The beveler will bevel deeper than your cuts if the moisture is right. If you've cut thru the leather with your beveling before your probly cutting too deep. I don't know of any way to fix it, but if it's ruined anyway properly case it and try to rebevel. If I were you I'd get some scrap and cut different depths and see which works best.
I was taught to cut about a 1/3 into the leather. I had similar problems years ago when I started carving. Your moisture content is not right, to dry or to wet will cause you to see the cut lines after beveling. How deep are you cutting your leather? The pic seems to show alot of cut lines after you have beveled, I don't think you need to cut deeper because the cuts are still there, maybe you didn't bevel all the way to the bottom of your cuts.
I don't know what kind of carving your doing but if it's figure (animal) carving you'll be wanting the smooth bevelers also.
If you haven't used one much the 1/2 inch barrel will feel more comfortable for sure, but if you plan on doing any carving you'll want a smaller barrel because as you follow your lines you'll be needing to roll the barrel between your thumb and finger when on the curves. With the bigger barrel you'll be stopping to regrip because you can't rotate it as much as you'll need to. the quality of the work will be pretty much the same but you'll save lots of time not stopping to regrip or turning your leather constantly.
Brand New Pro-Line Euro Style Pricking Irons 3.38Mm (Full Set 10+5+2)
Troy Burch replied to JanC's topic in Old/Sold
That's very nice stitching, would you mind telling me what size needle and thread you use. Thanks Troy -
sent you a pm -
Nice work and very nice stitching. Look in the tutorals for Hidepounder's how to burnish edges, it will improve the final apperance. Troy
Ox Blood & Ox Blood And Black
Troy Burch replied to Rohn's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like the black contrast best but the ox blood is nice as well. I think it would really pop if antiqued with mahogany. Very nice Troy -
I have to say the beer can holder with a belt loop is my favorite. lol
No, It's been sitting on a shelf unused for years. I find it easier to prepunch my holes before I start sewing than to wrestle with the damn thing.
I have the same problem. I have a stitching pony but can't use it as intended. I as I'm sure you do need my forearms or one elbow resting on something when leaning forward. I don't awl one hole at a time, I'll do 20 or so then pick up the needles and sew then do it again until I'm done. I've been intending to modify the pony and c clamp it to my table but to be honest I've gotten so used to it I don't believe the pony would be much faster. I've watched sewing videos where they use the stitching pony and I'm pretty much as fast as they are. But I've been doing it this way for 10 years, I think you'll find as you did learning to live in a wheelchair once your used to doing something it becomes a "normal" smoother process. I know this doesn't help much but as you get back into leather work you'll notice things will get easier and more natural as you go. Good luck Troy
If your talking about patterns you "bought" along with a how to video, pattern pack, or kit you can certainly use them on work that you sell or give away. However you can't resell or post the patterns for someone else to use. Well I just noticed camano ridge already said this.
- 8 replies
- leather patterns
- purchased patterns
(and 2 more)
In addition to what Ray said, Springfield leather company has free videos on their website showing how to use tools and stuff.
Best way is pick a project and do it. Your going to mess up some but you'll learn more in a couple of days than in a month of videos. We ALL have a trash pile. The marble slab is for tooling on for better impressions. Lots of tutorials on this site, stop worrying about ruining something and jump in and have fun with it.
