Everything posted by Troy Burch
Sounds like you need more advice than one post can give you. There's a lot of leather working how tos on youtube that will keep you fascinated for days. Good luck Troy
Sounds like you want a creaser tool, look it up on youtube.
George, that's a good looking knife but I have one question, with the handle shaped like that does it feel awkward to use the opposite side of the blade because of the handle being upside down?
Croco Print Change Purse
Troy Burch replied to Rohn's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I've never had the desire to make a billfold even though I get lots of people asking for them, but I gotta tell you thats beautiful and has me thinking I may have to change my mind. Troy -
Strap End Template, Am I Doing It Right?
Troy Burch replied to taintedelephant's topic in Patterns and Templates
All these appear to be the same except the widith of the strap. Your pattern doesn't show how far apart the holes are or how long the buckle slot. The bigger the buckle the longer the buckle slot will have to be, the tongue holes will be spaced differently depending on what its used for and the size of buckle, the belt keeper width should vary proportionately with the strap width. I don't have exact measurements for you for each size maybe another member can give you better advice. Troy -
You can get large plastic mats that have a nonslip underside made just for protecting floors. I don't know the exact name to search for but it shouldn't be that hard to find.
I don't think they are talking about veg tanned leather, more like upholstery leather. Veg tanned leather will tan in light and it doesn't have to be in sunlight to happen. I ask to have my leather boxed or wrapped in brown shipping paper even when I buy it in person. If you come up with a solution please post it. Troy
don't adhere it to your work station, you'll be needing to turn the piece often. rubber glue it to some cardboard or some kind of backing, or use one sided tape on the back. when your finished just pull the backing off. don't pull the leather pull the backing.
Anyone Tried 'metal' Alphabet Stamps On Leather?
Troy Burch replied to braden's topic in Leather Tools
Yes I've used them when I've needed small letters and they'll work fine. I've got a 1/4'' set of craftool stamps also. -
2015 Keep Making Stuff Monthly Challenge
Troy Burch replied to thefanninator's topic in Leatherwork Conversation
Thank you for keeping it simple. Troy -
Leather Craft Video: Shop Talk Series Episode 2
Troy Burch replied to Jess Jones's topic in Leatherwork Conversation
Thanks Jesse, I've heard alot about them servo motors but that's the first i've seen in action. I'm now convinced I gotta have one. Lokking forward to your next video. Troy -
Ray, Is the mini saddle the little 5 inch or so? I think it's used for a small lamp base, if so I'd like to buy it. I will probly want it reguardless, if not too much trouble maybe a pic or description. Thanks Troy
deglazer or alcohol
Thank you, If it gets to be a problem let me know and I'll step out. -
Is this just for people that will participate in all the projects or can anyone play at any time? -
Hi Ray, you can get steel tubing at a hardware place. I have some 3/8'' and 1/2'', it's very sturdy and should hold up nicely for that. I don't think the brake line will hold up but the steel tubing is strong enough to be driven into a piece of wood without bending or blunting.
For Sale Craftool Assorted Stamp Tools And Stohlman Books
Troy Burch replied to sheridanman's topic in Old/Sold
I have almost every Al Stohlman book made including that exact one, I bought it new about 8 or 9 years ago for $9.95 are you telling me it's now worth 4 to 6 hundred? -
Go to an auto parts store and get some rust remover, soak 12 hours (depends on how rusty) and the rust will be gone. Bruce Johnson told me about this, Evaporust or Metal rescue is a soak that will remove the rust and leave the good metal. Then put some light oil on it.
Looking For An Industrial Machine... Questions
Troy Burch replied to C Schomer's topic in Leather Sewing Machines
Welcome to the forum, I was born in Buckeye. You've already been given good advice, so good luck. -
The reason for casing is for a good burnish when tooling and a crisper and better 3d effect. The drying time will depend on the temperature, humidity and thickness of the leather but it's not uncommon for me to wait 6 to 8 hrs before putting 6/7oz in the fridge. If you put it in the fridge before it's ready then your stopping the drying process. I always case the day before I intend to start carving. If I'm doing a project I can complete in a couple of hours I do NVLeatherWorx method, If it's a large project I do the long casing version because if the moisture is consistant thru out the leather there is less rewetting and the less rewetting the better for the carving.
I think I have that pattern in an old book. I'll go to my shop in a little bit and check for you.
Here's My Shop, Let's See Your Shop!
Troy Burch replied to texasfireleather's topic in Member Gallery
- 29 replies
