Everything posted by billybopp
I totally get it with doing your best possible work, but consider that you do sometimes need to work to a price point. It's the same with just about everything on the market today. VERY few people have an unlimited budget, but some are much bigger than others. You don't want your less expensive products to taint people's opinion of your more expensive ones. One way to do that? Branding! Release less expensive, plainer, perhaps even less durable products under one brand, and then higher end more expensive products under another brand name. It happens in the business world all the time ... Sometimes everybody knows about it such as GM with Chevy, Buick, Cadillac, etc ... Other times, brands that you buy every day are owned by the same parent company but few people know it!! Just a thought - Bill
When I started doing leather stuff, I bought some Tandy kits. It was good to get a feel for how to put things together. Since then, I've bought others but the first thing I do with them is to make a pattern from them! I put the kit together to learn where the "sticking points" are in assembly and other details, and also use them to try out my first thoughts on decorating and colors. They generally come out OK, but what follows is usually much nicer when I use the templates to cut out my own version, use proper chisels to make sewing holes, and any other changes! The kits they sell tend to be attractive, nicely proportioned, solid designs that are then buggered up with huge stitching holes, the simplest possible way to attach hardware, etc. There are a lot of relatively simple improvements to be made by anybody with some experience under their belt. - Bill
Keep the handle, maybe! - Bill
Has anyone used transparent/translucent leather?
billybopp replied to SUP's topic in Leatherwork Conversation
I was tempted to order a sample, but shipping is $10! -
... I see what you did there! LOL - Bill
Roller diameters do differ some, but there are limitations on how big machines will take. -Bill
That's definitely Dan Akroyd, but that must have been edited in by somebody. He would have been around 10 years old when that episode came out, and there also wouldn't have been a cassette player at the time. - Bill
Gremlins show up on airliners too ....
Roller embossers and plates both have their place. Rollers are generally easier but are more or less limited to patterns that repeat at up to about 4 or 5 inches or so (depending on the outer diameter of the roll). If you want a more varied pattern, you CAN use rollers and switch them out for different sections, but that is a huge pain to get things lined up right. For those more varied patterns, embossing plates are a better choice. It's relatively easy with plates to mix and match patterns for a wider variety of items. - Bill
I suspect that those are not embossed with a roller, but rather embossing plates. Look at the topmost blue belt and you can see a slight separation between embossed sections. It's noticeable with some of the others as well. Also, agree with @GatoGordo they are likely dyed the base color and then block dyed black after that. - Bill
211G165_166_265_266.pdf
If you have 50 TONS or so of lard ... You can launch a battleship! Before oil became civilization's main source of lubrication, animal fat of one sort or another was used to lubricate. Everything from wagon wheel axle grease to steam engine bearing surfaces. I have no doubt it was used to build the pyramids and great cathedrals too! P.S. At least for me, Bacon fat does a wonderful job lubricating my cast iron skillet for the eggs that are cooked after. Just don't tell my doctor that I do that, please. - Bill
- 193 replies
- saddler recipe
- diy conditioner
- (and 4 more)
It all depends on how you do it - but you need a good amount to run leather through. I dilute about 50/50 with denatured alcohol. Afterward, however, most of it goes back into the a bottle for use another time. Most things don't get fully submerged, and don't stay there for long. Belt straps, for example, just get held under with a gloved hand and pulled through - so not TOO much dye needed for that. - Bill
Dyes do not need to be diluted to be airbrushed. They are quite thin already. If you want finer control over the color, however, thinning can be helpful for building up color slowly. I've often used sponges, daubers and wool as well. All work fine. Dip dying can be a good option as well - but I do prefer diluted when dipping. - Bill
I've used sewn on velcro on similar straps. Glue alone would probably be fine, but I prefer to sew as well. - Bill
Merry Christmas!
That is a plough gauge. You PUSH it through the leather, like a plough. Below is a draw gauge. You PULL (or draw) it through the leather.
Best lining for wrist cuffs for long term wear.
billybopp replied to stevepaxton's topic in How Do I Do That?
You might want to go with an undyed veg-tan leather for the cuffs and a little bit of neatsfoot oil to keep it supple. Consider an undyed sheep sheerling liner, sewn in at the edges. -
Happy Wife = Cost of Doing Business. I bet they don't include THAT equation in the business accounting books! - Bill
It looks great! Don't show it to Ratty and Badger, tho. They'll want one too!
Sizes for ladies belts
billybopp replied to PAMuzzle's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Consider that 1 1/4 will fit both smaller and larger belt loops. 1 1/2, not so much! - Bill -
What is Mycelium Leather? Does it exist?
billybopp replied to RobertoDR69's topic in Leatherwork Conversation
Some years ago, I stopped by a sandwich shop on my way home from work for a cheesesteak hoagie. Before they started my steak, the cook carefully emptied the grease tray at the front of the grill into a bucket and put a lid on. I asked what happens to all that grease, and he told me that somebody comes by every week or two and buys it for a soap maker! So who knows, you might be bathing with cheesesteak! - Bill -
Well done. Looks great, and I'm sure it'll work even better! - Bill
spring flowers and good food
billybopp replied to chuck123wapati's topic in All About Us and Off Topic
