Everything posted by billybopp
Antiques are generally meant to be used as Monica said: To accentuate the detail and shading in carved and tooled leathers. Usually, you'd finish your tooling, possibly dye, apply a clear finish as a resist or an actual resist product selectively and then put the antique on thickly rubbing it into nooks and crannies and excess wiped off to allow the antique to remain behind in the low spots to dry there. A final finish is applied after all is dry. That being said, the Eco Flo gel probably makes a better leather stain than it does antique. It tends to discolor resist too much for my taste. I also seem to have a hard time sealing the eco flo gel to prevent dye ruboff with wetness / sweat. I've swtched to Fiebings antique pastes for my antiquing, but the gel still has it's place. In the end, it's all about what you like and what works for you! Hope that helps Bill
Sharpening Awl--Point So Fine It Bends--How To Remove?
billybopp replied to thekid77's topic in How Do I Do That?
That's normal, and it's a good thing to have that little rolled up edge when sharpening. A very fine stone is the way to remove it before stropping. Check out this video on sharpening a round knife ... Same idea. https://www.youtube.com/watch?v=i9NvllVNGcM Hope that helps Bill -
Ranger Style Work Belt
billybopp replied to Colt W Knight's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
The belts all look really great! I think I may have to make one for myself. But I have to ask: Where the heck did you find those fancy Chicago screws!? Bill -
If it were possible to make the process shorter, don't you think they would do that? It's a HUGE amount of money sitting in the vats not making money for a long period of time. Other tanning methods are quicker, with different results. Look into brain tanning.
Keep in mind that the faster the motor runs with a given wheel, the more friction you create with the wheel. If you create too much friction, you may burn more than burnish. A smaller diameter wheel can help to compensate for a faster shaft speed. If you want to do the math, using pi*d for the circumference, an 8" wheel @1750rpm moves surface past the leather at 733 inches per second. A 4" wheel at 366 IPS, or half the running speed along the leather being burnished. While I can't tell you what an appropriate speed along the leather should be, it's something to keep in mind when you purchase a wheel. Hope that helps Bill
Need Some Lacing Advice
billybopp replied to Dwight's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Conditioner and / or saddle soap might help. Then again, it might just be crap lace. I've run into a spool or two. Bill -
Tandy Hand Press Conversion - Foot Press?
billybopp replied to Richard Wasnock's topic in Leather Tools
That's how I'd do it, Glockinator ... Except that I'd mount the press beyond the edge of the table so that the lower skinny part sticks out. That greatly helps getting into tight places when needed. Bill -
When I'm mixing dyes for a particular color, I use some plastic disposable eyedroppers that I bought at a hobby shop. I use a different one for each color of dye so that I don't cross contaminate the dye in the bottle...Even one for the dye reducer. I then use a small ceramic bowl or paint flower to mix them in. Just count the number of drops to get the ratio you need. The droppers are good for a couple dozen uses before the plastic is done in. But they're cheap and do the job! You might also see them labelled as "transfer pipettes". Can't wait to see your finished piece!! Hope that helps Bill
Edge kote is more of a glossy flexible paint than a dye. About the best use for it is putting a finished edge on leathers that do not burnish well. Bill
Roll Top Version 2
billybopp replied to Hi Im Joe's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I wonder if something like clear nail polish would be good to prevent corrosion? Bill -
I sometimes dye the back, and sometimes not. If you do not want dye on the back, you can put masking tape on the back to help protect it, or frisket film for larger pieces. The adhesive from the tape/frisket can sometimes pull up the grain to leave the back a little "hairier", but that can usually be resolved with some gum trag or tan kote and a glass slicker for larger pieces or just a regular wood slicker for smaller ones. Hope that helps Bill
Marvin The Martian Vambraces.
billybopp replied to xStarkweather's topic in Collars, Cuffs, Leashes and Leads
Marvin looks awesome! But it looks like he's missing the Illudium Q36 explosive space modulator!! Seriously cool. Marvin has always been one of my favorite Looney Toons characters. Bill -
Couple More Padfolios.
Great work as always! Bill -
Roll Top Version 2
For my part, I think I like the burr showing on this bag, especially since Joe did such a good job making them look smooth and even. It just adds something visually interesting to the bag. Perhaps a different bag design with more happening visually would do better with the head out. I wonder, does anybody know if the copper rivets will oxidize to green with time? If so, how would you prevent it? Also, has anybody tried "machine turning" or some other method to give these rivets an interesting texture? Just some thoughts ... Bill -
Exactly 23 1/2 more parts and you have an entire machine. Bill
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
Fenice Edge Kote. How Do I Buy It? Whats The Technical Name?
billybopp replied to greekgod's topic in How Do I Do That?
I just put in an order with Tandy for some stuff that I need in a hurry, and included a bottle of the Neutral Pro and Gloss. I'm not usually a fan of edge paint, but I'm curious how this will look! Bill -
All three of the Stohlman case books are pretty good. They are best read in order, as they somewhat build on skills presented in previous volumes. Many of the demo projects are outdated (Polaroid camera case, etc), but the skills taught are still very much valid and useful. All three are downloadable from Tandy's Leathercraft library for $9.99US each at the moment. https://www.leathercraftlibrary.com/c-79-ebooks.aspx?pagenum=1 Hope that helps Bil
Something I've always wondered .. Do you line a corset like this the entire interior area? Would you mind taking a photo of the interior, Raven? It looks great. I love the colors, and never would have thought of using the silver that way!! Bill
Be aware that temperature controlled soldering irons have a thermistor/thermocouple in the tip to sense temperature and send it back to the power unit. Hence, you are limited to the tips made for that iron, which are pretty small. A proper fileteuse edger has a pretty broad surface. Not to say that it will not work, but it's not exactly the same thing. Bill
Doug, just a few of things to look out for with the Chinese irons: 1. It looks as though there are machining marks on the teeth that may make it more difficult for the tool to go into / out of the leather. Is that a problem? 2. Is the orientation of the slant the right direction and pitch? 3. Is the metal hard enough? For the first two, it might help you if somebody on here that has Blanchard or Dixon punches could post some close up pictures of the working end of their punches. For the third, there's only one way to find out. It begs the question of whether many times the price for a lifetime tool is better than paying for a tool that will last a few years. Hope that helps Bill
Am I Just Too Much A Newbie Or Am I Dealing With A Nutjob?
billybopp replied to CyLee's topic in Leatherwork Conversation
Is this friend by any chance a salesman? Just wonderin'. Bill -
Looks great! I need to make one o' these for myself!! Bill
Roll Top Version 2
Looks really good! The copper rivets work really well with that color. I love the way the roll-top strap snap attaches so that you can get ahold to snap/unsnap it! The stitching is looking good too. Well done! Bill -
Is There A Way To Lighten The Color Of Leather?
billybopp replied to Buddahcjcc's topic in How Do I Do That?
If you really need lighter, you may have to buy it. But extra leathers is a lot like leftovers in the fridge. Keep 'em around. They'll turn up in something! (to paraphrase George Carlin) Bill -
I wasn't even thinking about westerns. There aren't so many of those as there used to be, but heck yeah! Great leather gear there too. Gun belts, saddles, and about anything else that you can think of. Bill
- 6 replies
- movies
- television
(and 4 more)
