Uwe
Contributing Member
Everything posted by Uwe
  1. Can you? Maybe. Should You? Probably not. A 441 class machine is not the right tool for the task. Even if it were, trying to sew thin fabric with #346 thread may be an exercise in futility. It probably won't look right because the fabric is too thin to bury/hide the thick knot.
  2. Go for it! Those are really nice machines. Coming across an nice used machine locally is a lucky break.
  3. The flatbed bed size of the Durkopp 239 looks to be a standard industrial bed size and should be the same as the Consew 225. The hinges can be found online at College Sewing in the UK : https://www.college-sewing.co.uk/229-58052-RUBBER-HINGE-ASSEMBLY-JUKI-DDL There are slight variations in the rubber part of the euro-style hinges. It's perhaps best to get the hinges first and then make your cutout fit them. The hole locations where the metal hinge part plug into in the back of the machines bed should also be standard. For my table I plugged the hinges with rubber part into the back of the machine and took precise measurements to get the hinge pocket locations and depth just right in the cutout. Don't expect to get it right the first time. I recommend using cheap plywood for testing before you cut precious wood. Once it fits one machine, it should fit all the others with the same bed size. In order to separate the pedal from the table, you'll need to get a servo motor that has discrete parts (Motor/Controller/Speed-Input) . This way you can extend wires to make a flexible electric connection between the pedal speed input and the motor controller, instead of the usual rigid mechanical link, similar to this:
  4. That sound may be me wheezing. I actually had to turn down the sounds of the original video almost entirely because the step motor makes and infernal racket at slow speeds right now. It's dead quiet when stopped, and has an agreeable hum at high speed, but low speeds are a very disagreeable racket right now. The motor is just clamped to the table top for testing and every slow step it makes acts like a speaker coil with table top pretending to be a sound board. The programming is indeed a big part of how the button (or any part of this motor drive system) behaves. Arduino programming is fun in a very geeky way. I just knew those engineering, math, and computer science degrees would come in handy some day! I plan to add a little touch screen to allow changing parameters and such. I actually LOVE how well the speed pedal works. I'm using a modified Ernie Ball brand musician's sound effect pedal to control speed input: Not exactly cheap at around $70, but it's by far best, most gradual and precise low speed control I've had so far. None of this weird optical gradient hacking, just hundreds of usable, gradual steps of speed input. I initially bought the pedal to control a Variable Frequency Drive controller, but those 3-phase inverter class motors are wicked expensive,huge, and heavy. The pedal works perfectly as an Arduino input device and it's beautifully made, almost carved from solid aluminum.
  5. I've been wanting to install a retrofit thumb control knob for needle positioning on one of my machines ever since I saw it on that new Adler 969. My Tacsew T1563 made a good candidate to try a few things out, and it actually works! The entire project of installing an Arduino controlled high-torque precision step motor drive is rather complex and I'll post more details later. This video is just about how the thumb control knob works:
  6. We really have no idea whether a particular machine is any good or not by looking at the ebay auction post. Nearly all brands and models of sewing machines that are suitable for leather work have been discussed on this forum before - usually at length. Do a quick basic research on any machine you're considering on this site to see what has been discussed before. It'll take you just a few minutes to decide if it's a desirable kind of machine or not. Use the "site:leatherworker.net make model" template to search. For example, type "site:leatherworker.net adler 69" into the Google search window to see what folks have said about that model of machine before. If nothing pops up, that's also a sign that you're looking at a machine you should avoid. As for individual ebay auctions, you are pretty much on your own. We can't tell you whether or not, or how much to bid at an auction.
  7. What does "directly through Cobra" actually mean? Are you referring to the "Home of the Cobra" Leather Machine Co. in Los Angeles? Not sure how they relate to the Cobra brand, really, other than being one of the vendors for the brand. Toledo Industrial is "Home of the Cowboy" according to their website, but they're not exactly "directly through Cowboy" either. You're located about as far away as you can get within the continental U.S. from pretty much all of the usual vendor suspects, so anything you buy will need to be shipped. Talk to the vendor candidates and find out how many levels of redirection are involved to get to the source of the brand and "the buck stops here" kind of support.
  8. Check out this Juki Lu-563 - it's one of the cleanest and most honest looking machine on Ebay UK in your price range, I think. The flatbed part has been repainted, but the top looks totally original and very clean. The Juki LU-563 machines are great machines, easy to maintain and adjust, and they have good specs and parts availability.
  9. I would approach obviously repainted machines with a healthy dose of caution. I always view machines with crude stickers that say "Adler" (or whatever the brand name is) in the wrong font as a sign of a poor lipstick-on-a-pig type rebuild. That cylinder arm machine falls in that category. I'm also still not sure how Kochs Adler ever allowed authentic machines to leave the factory with their company name misspelled on the type plate. The type plate on the Adler 167-72 says "Kochs Adlernähmaschinen Werke AG" when it should say "Kochs Adler Nähmachinenwerke AG" I would advise against buying a machine on Ebay unless you can inspect it in person to make sure it's in good working condition, or you REALLY trust the seller. Adler machines in general are good machines as long as they're authentic and not worn-out factory zombies with a quick repaint. A machine with lightly/moderately worn original paint is preferable to a machine with questionable re-paint in my mind, because is gives a more authentic picture of the past life of the machine. The Adler 167 (and many other makes/models) came in various subclasses and configurations with varying specs. Read up on the model brochures like the Adler 167 Brochures to make sure the model you're considering is suited for leatherwork. The Adler 167-72 is okay, but not the best version in that model line for leather work (the 167-73 has more desirable specs). Big needles and thread capacity, large stitch length and foot lift are usually a good sign, as are certain model number extensions like -73, -373, -370 for certain Adlers. All three machines in your list are repaints with various issues. I'm not sure any of them are a really great candidate. The whole "which model" topic is quite complex, I'm afraid.
  10. Thanks for sharing! I had used a chisel tool similar to this one to chip off the old paint from the flatbed part of a machine a while back. The chisels are nice and narrow to get into tight spots and corners they work great on flat surfaces, not so much on curved surfaces. Looks like it's just about ready for new coat of paint on the flatbed. Do you mask off the little spring balls in the oiling holes to keep paint off them? I was worried about getting paint in there and my last paint project got messy around the oil holes.
  11. Just turn it over by hand to make stitches until you figure out what's going on. When I make major changes or adjustments I always check everything out first with hand-turned stitches before I even attempt to run it under power. A lot of bad things can happen under motor power that won't happen if you first turn the wheel by hand and observe, listen and feel how the machine works.
  12. Does the Twilight Zone Theme play while this is all happening? That exact double stitch length in reverse is just too freaky. Make a video of that. The only real explanation of that would be a stitch length mechanism that's WAY out of adjustment. Is your feed dog movement correct after re-installing the cam? Check feed dog movements without any material and verify they make sense, both forward and reverse. Test sew a piece with NO thread, forward and reverse. If stitch length still changes it's clearly not the thread that's causing it. Does the material slip a little when the needle is above the material? That's the only time it really can slip. Perhaps the outer presser foot is not holding the material down with enough force to keep it from slipping. Thread tension does play into this to some degree. If thread tension is too high it may yank the material towards the needle a little as it's pulling the knot tight and pulls more thread from the spool. If the material is not slipping, perhaps the transport mechanism or linkage is slipping when the going gets tough or reverses. Make sure all the screws and bolts involved in the stitch length mechanism are tight. Does the stitch length lever move when this happens? That level should stay wherever you put it and it should not move as you sew.
  13. Uwe
    Consew 225
    Something like this Yamata FY5318 setup on CL might be a good candidate in your area. Nice looking garment class machine, table and a servo motor. You should be able to swap heads without major modifications (other than removing the Yamato's oil sump pan, which often just sits in the opening).
  14. Uwe
    Consew 225
    To make a complete setup, you'll need a tabletop with a suitable cut-out, K-legs with a pedal, a motor, and a belt. Most people who consider buying just a machine head already have a few machines and want to upgrade, or they've built or mixed/matched a few heads and tables and are not intimidated by the task. I wouldn't recommend going that route if it's your first machine. It's not that hard if you're handy and once you've done it a few times, but I can imagine it being very frustrating starting from scratch without a reference point. On the plus side, the industrial tables and motors are interchangeable to a large degree. The whole system is designed for the factory where if a machine fails, the tech stops by and quickly swaps machine heads to keep the worker productive, while the tech works on the faulty head in the shop. Motors are compact and easy to ship, they run about $130-$150 shipped for simple, good servo motors like the FSM-550 series available from the banner vendors. K-legs (or H-legs) are also easy to ship when they're in pieces inside a carton, like an erector set. Those run perhaps $80-$100 shipped. The table tops nowadays are cheap laminated particleboard affairs, but they're big,heavy, awkward and relatively expensive to ship. You're looking at $100-$120 shipped. Make sure you tell the vendor what sewing machine it's for so they know what cutout you need. The belt can come from your local hardware store or automotive parts store. Just about any "3L" type V-Belt will do as long as it's about the right length within a 2"-3" range. Getting the right length can be tricky and you won't know for sure what length you need until you have the table set up, the motor installed and the machine sits in the table. Lucky for me my local non-chain hardware store has a large selection of cheap ($6-$9) belts in 1" increments from under 20" to over 50" in length. I bought one belt at an automotive store and the poor clerk was utterly confounded after I couldn't provide a year and model of my car, and "I need a 3L V-belt between 40-42 inches long" did not compute with him. The total table+motor setup new from scratch runs about $300-$400 shipped. Not exactly cheap if bought separately. Package deals from vendors usually lower that cost to some degree, since everything gets shipped on one pallet. If you have a local-ish industrial sewing machine dealer, you can save a lot on shipping costs and probably get a complete table/motor setup for $200-$250. You can also scan local craigslist for a complete, cheap setup ( I saw a vintage $150 Singer, and a new-ish $350 Yamato with servo motor in your area listings) and then swap out the head and sell the original head again on CL ("Works! Sews everything!") I bought one machine simply because the table was beautiful and the whole setup was only $150. Again, I wouldn't recommend going that route if it's your first machine.
  15. That Pfaff 467 is a strange design and you may have a very hard time finding parts for it. The Juki 563 and Adler 167 are very common with lots of parts available, both are very good designs with nearly identical capabilities and comparable quality. My advice would be to avoid the Pfaff and toss a coin between the Adler and the Juki (if they're in similar condition).
  16. The common naming of the two springs adds to or creates much of the confusion, I think. My topic title doesn't help either, come to think of it. The springs and corresponding adjustment screw really should be referred to as big/major/rough adjustment for the big leaf spring in the back and small/minor/fine/incremental adjustment for the small coil spring because both springs affect foot pressure for both feet. The big beefy leaf spring in the back of the machine provides the big/major/rough pressure. It changes pressure for BOTH feet by about 4 lbs (~2kg) of pressure with each full turn of the adjustment screw on my machine as measured by the scale. The comparatively small and weak coil spring inside the head provides small/minor/fine/incremental adjustments for fine-tuning. It changes pressure for BOTH feet by about 4 oz (~100 g) with each full turn of the adjustment screw. So if either of the feet leave marks, you need to adjust the pressure of the big leaf spring before fiddling with the small adjustment spring. The generally smaller inner foot will show marks before the outer foot mainly because the inner generates a higher pounds per square inch pressure due to the smaller contact surface. Most people can probably safely ignore the fine tuning spring adjustment knob entirely.
  17. I posted this on another topic in the Sewing Leather sub-forum, but I think it also belongs here since it relates to sewing machines and applies to most walking foot sewing machines. Also to open it up to discussion without hijacking the other topic. Here's my original post (with minor edits): Geek alert! I've been giving this some thought because that foot pressure business has baffled me for a while and the inner foot spring setting never had any noticeable effect no matter how I adjusted it. I've concluded that the inner presser foot spring has only little, incremental effect on how hard the inner presser foot presses down on the leather during the stitch cycle. Changing the spring or cutting a bit off will also have minimal effect. This sounds weird and counterintuitive but the OUTER presser foot spring ALSO determines how hard the INNER foot presses down when outer foot lifts up. The pressure of outer and inner foot are NOT independent of each other, in fact they're closely and quite literally linked. This is because the outer foot actually uses the inner foot as leverage via linkages to lift up, against the spring that controls outer foot pressure. If you remove the inner foot entirely, the outer foot will not lift up at all because it needs the inner foot as leverage to press against the material in order to lift up. I believe the main purpose of the inner presser foot spring is to ADD incremental pressure to the inner foot on top of what the outer foot spring already provides. Adjusting the inner spring will never allow you to lower the inner foot pressure below what the outer spring dictates. I just now did a little experiment to back up my claim with some proof. I put a kitchen scale under my presser feet bars and moved the needle bar up so as not to interfere. I dialed the outer pressure foot spring low enough to get below the 10 lbs weight limit of my scale. I removed the inner presser foot spring adjustment knob entirely, so the inner spring was not pressing down at all. With this setup and the inner foot spring totally out of play the outer foot bar pressed down registering 7.2 lbs: and after turning the wheel a little the inner foot bar pressed down with 5.5 lbs: The difference is likely due to linkage angle and lever lengths, but the two are proportional. If I dial up the outer foot spring pressure, so increases the inner foot pressure (all WITHOUT the inner foot spring involved at all) Adding the inner foot spring control knob and cranking it all the way down for max inner foot spring pressure increased the inner foot pressure an additional 2.5 lbs over the initial value. This is the max the inner spring can ADD to outer spring. The inner foot is also more likely to leave a mark because it has a much smaller footprint than the outer foot and exerts higher force per square inch with the same spring pressure (the skinny high heel of a shoe is more likely to leave a mark than the bigger front of the shoe, but your weight does not change as you walk.) So the small inner foot even at 5.5 lbs is much more likely to leave a mark than the bigger outer foot at 7.2lbs I'd try dialing back the outer foot presser spring until it just barely holds on to the material when you tug on it and see if it makes a difference. Help guide the material with your hands as you sew to allow the machine to move the material easily and consistently with minimal foot pressure. Don't push or pull as it sews, just allow the machine to do the work with minimal force. Sorry about the long and geeky post, but I hope it adds some clarity to this confounding foot pressure business.
  18. You can use an online service like http://www.picresize.com/ to resize photos without any image editing program. You need to state a price per for-sale forum rules.
  19. Geek alert! I've been giving this some thought because that foot pressure business has baffled me for a while and the inner foot spring setting never had any noticeable effect no matter how I adjusted it. I've concluded that the inner presser foot spring shown in your picture has only little, incremental effect on how hard the inner presser foot presses down on the leather during the stitch cycle. Changing the spring or cutting a bit off will also have minimal effect. This sounds weird and counterintuitive but the OUTER presser foot spring ALSO determines how hard the INNER foot presses down when outer foot lifts up. The pressure of outer and inner foot are NOT independent of each other, in fact they're closely and quite literally linked. This is because the outer foot actually uses the inner foot as leverage via linkages to lift up, against the spring that controls outer foot pressure. If you remove the inner foot entirely, the outer foot will not lift up at all because it needs the inner foot as leverage to press against the material in order to lift up. I believe the main purpose of the inner presser foot spring is to ADD incremental pressure to the inner foot on top of what the outer foot spring already provides. Adjusting the inner spring will never allow you to lower the inner foot pressure below what the outer spring dictates. I just now did a little experiment to back up my claim with some proof. I put a kitchen scale under my presser feet bars and moved the needle bar up so as not to interfere. I dialed the outer pressure foot spring low enough to get below the 10 lbs weight limit of my scale. I removed the inner presser foot spring adjustment knob entirely, so the inner spring was not pressing down at all. With this setup and the inner foot spring totally out of play the outer foot bar pressed down registering 7.2 lbs: and after turning the wheel a little the inner foot bar pressed down with 5.5 lbs: The difference is likely due to linkage angle and lever lengths, but the two are proportional. If I dial up the outer foot spring pressure, so increases the inner foot pressure (all WITHOUT the inner foot spring involved at all) Adding the inner foot spring control knob (the one in your picture) and cranking it all the way down for max inner foot spring pressure increased the inner foot pressure an additional 2.5 lbs over the initial value. This is the max the inner spring can ADD to outer spring. The inner foot is also more likely to leave a mark because it has a much smaller footprint than the outer foot and exerts higher force per square inch with the same spring pressure (the skinny high heel of a shoe is more likely to leave a mark than the bigger front of the shoe, but your weight does not change as you walk.) So the small inner foot even at 5.5 lbs is much more likely to leave a mark than the bigger outer foot at 7.2lbs I'd try dialing back the outer foot presser spring until it just barely holds on to the material when you tug on it and see if it makes a difference. Help guide the material with your hands as you sew to allow the machine to move the material easily and consistently with minimal foot pressure. Don't push or pull as it sews, just allow the machine to do the work with minimal force. Sorry about the long and geeky post, but I hope it adds some clarity to this confounding foot pressure business.
  20. That thread ZAP 2 thing looks neat! A soldering iron with an adjustable heat setting may work, too. I find a lighter hard to control, especially when I try to melt thread in a tight inside corner. With the lighter flame method, my white polyester thread occasionally turns an unsightly brown as it melts/burns, and my leather got burn marks on occasion as well. Polyester thread melts at around 450ºF (230ºC). Most soldering irons are designed to melt soldering tin at 700º or more and leather will get burn marks at that temperature, too. I bought this adjustable soldering iron to test with because it can be adjusted LOW enough to just melt but not burn polyester, but I haven't really had a chance to try it yet:
  21. My sofa has french style seams and the arm rests almost look like a tote design with a gusset to give it some useful depth. All the corners are rounded to make the french seam practical:
  22. The straight seams are easy enough it seems, it's the corners that get you. I'm having a hard time picturing how this seam would work on a 90 degree corner like your tote bag. If you're using a flatbed machine you'll be wrestling that material pretty well to make it lay flat as you move along the seams near the corner. Cutting the bottom "corner" with a radius rather that a sharp 90 degree corner may be a feasible solution. Then you can sew the entire seam in one relatively smooth line with soft curves rather than sharp corners. I did a test piece for a french seam recently. It's just a flat T-seam, but at least it shows the concept of this style seam:
  23. Uwe
    Consew 225
    I still have it and my confidence is waning that the original buyer is in the position to follow through on the purchase.
  24. Yup, belts are a different story. A 441 class machine would be a great, well supported and capable choice. The 441 class of machines is based on the Juki TSC-441, which is still available new for around $6K. Copies include Cobra 4, Cowboy 3200/3500/4500, TechSew 5100, Weaver Master Lockstitch, and a few others. The copies run about $1,600 to $4,000 depending on brand and accessories. Pick the best tool for the job. Your hands are the best tool for those shields. The 441 is among the best tools for the belts.
  25. All better now. I took the timing belt off one more time and advanced the bottom hook drive shaft one notch. Then I re-timed the hook for the seventh time today - I'm getting the hang of it. Here she is sewing as well as I had hoped for: I'm gonna give her (and me) a rest before I tackle that confounding reverse mechanism to balance forward and reverse stitch length.
