Everything posted by OLDNSLOW
Video: Swing-down edge guide installation on a Cowboy 4500
OLDNSLOW replied to Uwe's topic in Leather Sewing Machines
Uwe has an ebay listing where he sells them take a look at his posting again you should see it. -
also use some oil on the drill bit and the tap die it will help cut the metal a little easier, great video none the less!!! -
I sent an email yesterday with my IPhone asking for a catalog as well but in the event it got lost in the shuffle would you please send one to ronpadilla1@hotmail.com Thank you very much.
I am not really adding anything here but, it is a horizontal mag pouch if that does help any and Blackhawk and another company sells them on amazon for like 25 bucks. I was going to buy one to dissect it but never did.
Digital printed holsters
OLDNSLOW replied to justingschneider's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Eric, did you ask any in depth questions on the printer? I had an Epson 7200 many years ago that use pigment dyes, it would print on canvas but don't know if it would do 8oz leather. -
There has to be a method to the madness, I have not seen any of Savoy holsters in person but it seems like it might be a similar fashion, and if that is the case maybe a printer will be in more holster makers shops in the near future. Maybe something could be looked researched and shared with the group!!! -
Leather Heresies #1: Does Neatsfoot Oil Go Rancid?
OLDNSLOW replied to LeatherNerd's topic in Getting Started
I think as long as you keep the bottle closed it will prolong the life of the oil, I have bought some from a local guy who gets it in 55 gallon containers and it is ok. Now what I realized here lately is that there is 2 different types so to speak of Neats foot oil, one is the oil the other I think is called neats foot oil compound, the compound I found out gives the leather a very nice buttery look after 2 light coats. -
yup what I thought, all kimbers are built on the 1911 like frame from subcompact up to full size, so just figure out the size then the pancakes you guys have should work for the builder. Ron Padilla
just need to figure out if that is a full size, mid size, compact, or subcompact 1911 frame then use that holster. lemme check what it crosses over to and i'll be right back.
heck isn't that a basic pancake for a 1911 type gun all the Kimber's I thought are basically a 1911?
there is nothing wrong with the belly specially if a guy has a bunch of cash it'll stretch out to carry it and when its all gone it'll pull back in, but on the serious side it is because of the stretching that workers wont use it, except maybe a few saddle makers as there is a few spots where the leather needs to stretch when making a saddle. but when you dye the belly section it will harden up like any other leather because you have drawn out more oils from it, so if you don't over oil after dyeing it might not return to a soft mushy state. That's my take on it anyway and I am gonna stick to it.
the odor of fresh leather is almost better then your wife when she's fresh out of the shower, it aint something you want to admit to, that could lead to death call.
a photo would help in proposing an answer for you and try and make it a close up. What you could try is some saddle soap and water on the area that is showing the dirt then once dry you could try and reapply the super sheen and it might fill in the scratches.
First project - holster
OLDNSLOW replied to mbelmores's topic in Gun Holsters, Rifle Slings and Knife Sheathes
If you want the inside smooth you can take gum trag to it and that will smooth out the leather and also act as a blocker when you go to dye the outside. -
if it is for burnishing the edges anything up 1700 rpm is good I wouldn't go much faster than that.
like mentioned above if you take some gum trag and slick it down real good then seal with what ever you use on the front side you shouldn't have any problem at all.
What you have pointed out will work for all things that you are thinking of, you can always glue 2 pieces of 8oz if you want to make a heavy duty gun belt, and for that you would need a skiver or the small skiver splitter that tandy sells. I use one of those on heavy weight gun belts on the ends so that they will go through the buckle and keeper with out any problems.
Long Wallet
OLDNSLOW replied to Mattsbagger's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks for the info -
Long Wallet
which pattern did you use for these? I am starting to do wallets my self and have not settled on a long wallet pattern to buy. -
How to make a linesmans pouch and use a Cowboy 441
OLDNSLOW replied to RockyAussie's topic in How Do I Do That?
Thanks -
the A3 is a larger format than what we here in the 48 normally use I am not sure 8x14 is close in size, but can always cut and tape together or redraw out section if need be. -
great job nicely done please put up the pattern when you think it is time for it PDF works, and also the type of leather used!! -
Seeking Quality Sponges, or new finish application technique.
OLDNSLOW replied to maritimemoose's topic in How Do I Do That?
I have three, two of them have had so many different colors running through them it's unbelievable and these are the spirit dyes cause in reality that all of what is in all the dyes. There has been no degradation of the sponges, the third is for resolene and no problems with it either, after use they all get a good get a good rinsing with liquid hand or dish soap and very hot water and no problem. Now the cheap ones ya get at the grocery store fall apart liggidy split.- 10 replies
- dye application
- sponges
(and 1 more)
Are talking about the very dense orange I think is the color of sponges that tandy sells? The one that they currently sell is very good and if they had a better one then it must have been great!- 10 replies
- dye application
- sponges
(and 1 more)
