dikman
Everything posted by dikman
  1. There's a lot of lint there!! You could probably start with a pair of tweezers and pull out as much as you can, then a fine brush and a vacuum to finish off.
  2. The biggest problem you may have is finding suitable screws to attach the plate!
  3. Try using very fine wet and dry paper, used wet, on a piece of glass, you should be able to get them very smooth and then finish off with metal polish. Unless you have a buffing wheel, of course.
  4. If it was me I would temporarily fit a piece of cardboard, plastic or whatever I could find and then do some test runs (needle only, no thread). Measure the stitch holes and mark the strip accordingly. In my limited experience these marks are generally only a guide and not to be relied on if you want accuracy.
  5. Sorry, tt, but that's exactly what you asked in the first post. And as a result we now know that there's no such beastie. Mike, I'm well aware of your ongoing battle with spell-checkers, I was just rattling your cage. We may not have any alpha predators on land here but we do have some very nasty spiders and snakes (and drop bears)!
  6. Tony, you are faced with the same unpalatable truth that many who start out with industrial sewing machines soon discover - there is no one-machine-that-does-it-all (unfortunately). Many want to start with bags, dress belts, purses etc - oh, and maybe the odd knife sheath, and maybe a holster or two. Which is why people end up with a minimum of two machines (and generally more!). In my case I have to hand stitch holsters as I have nothing that can handle them. I recently came across a nice used 3200, unfortunately it's 3 days drive away so I'll just have to keep looking.
  7. "capitol A.." You missed that one, Mike. Sorry, I couldn't help myself as you are usually very meticulous when it comes to posting.
  8. Fascinating stuff. I never knew a spokeshave could be used on leather (but I don't think I'll be modifying mine). As for using a normal wood plane, it's obvious that it won't cut it. (Sorry about that ).
  9. My mistake, I thought it was the leather that was developing cracks. In that case I'd say it's the treatment your putting on top? Try dyeing a bit of scrap and just coating with neatsfoot oil to see what happens.
  10. I haven't seen anyone use a speed reducer pulley on a domestic machine before.
  11. I'm on holidays at the moment so not home. I can tell you that the servo is a fairly generic one that I bought off ebay, the vendor was here in Australia so I didn't have to buy from overseas. It's rated at "550w" but as you know that can mean anything! It's perfectly adequate for the machine it's on and can punch through 1/2" of veg with no problems.
  12. Very observant, jimi, judging by the horizontal banding on the sides I'd say you're right.
  13. Yes. The term refers to all the extras/gadgets/etc that you wouldn't get on a "standard" machine. In this case the pneumatic functions, which presumably require the original motor/control box to function. I guess it all depends how badly you want those functions.
  14. Ahh, ok, you didn't mention that before. The only thing I can think of is that the needle bar is bent slightly.
  15. Brian, I am more than happy to acknowledge your superior experience in these things, but I must admit I'm with Constabulary on this. The feet look the same type as those on my little 201K (domestic) and I'm blowed if I can see any advantage in filing out a notch like that. Plus, as you say they are two different type of feet, so to prove that cutting the notch makes a difference the comparison should be between two of the same feet, i.e. before and after. Of course, I could be completely wrong...... I see you posted just as I did, Gymnast. Interesting tests, but as I said you should do the comparison between two of the same type of foot in order to get an accurate result.
  16. I'm confused, you said the problem is that the needle isn't centred in the feed dog. Given that the needle bar can't be adjusted laterally the only way you can centre it is to move the feed dog, as Gregg has shown.
  17. It happens, mate. Not all sellers will do the "right" thing.
  18. And it comes with a 2" pulley, which is nice.
  19. I agree about the rivets, I've always thought they make a sheath look "cheap", much nicer without them (imo). For a first effort I reckon the gunbelt looks pretty good! Could the cracking in the leather be due to the type of leather used? One way of looking at it, you've already achieved a worn, used look right from the start.
  20. It's good that they're sending you the part but I'm still surprised that they carry replacement parts. I agree with SilverForge's comments and don't forget this is a hand-cranked machine, not a motor-driven high speed unit, so oil-carrying capacity of cast compared to plain steel is pretty irrelevant in this case. As long as the parts aren't binding or too loose then just oiling them occasionally should be more than adequate.
  21. That last photo better explains how it fits, so yes, wouldn't be very difficult to fabricate a suitable replacement. ebay doesn't necessarily require you to return something, and will generally cover the cost if you have to, whereas with PayPal you have to return it first, and usually at your expense. Just for your info, much better if you can avoid having to do it, and in this case if it was me I'd just make a replacement part.
  22. I'm surprised that any parts are actually available for these things. As it arrived damaged, thus not-as-described, you can lodge a claim with ebay for a refund if you have any problems with the seller (but you need to do it as soon as possible, or at least within 30 days). DO NOT lodge a claim with PayPal, stick to ebay.
  23. I've been examining the maul and I don't think it's damp as it's quite hard if I poke it with a screwdriver. I know you can make glue from the rawhide, so I'm guessing that the moisture combined with the pressure from clamping it formed some sort of natural "resin" (for want of a better word). I'm going to be away for a while (holiday by the sea) but when I get back I think this will deserve a stacked leather handle.
  24. Seeing that you're a leatherworker, can't you make a decent cover for your chair? It looks a bit tatty.
