fredk
Contributing Member
Everything posted by fredk
  1. Yes, it needs lots of waxing, every few inches sometimes. As you pull the thread thru a hole the leather is scraping off some of that wax. Put the thread on top of a block of soft-ish bees wax. put your thumb on the thread and press the thread into the wax, then pull the thread thru the wax still with your thumb pressing it onto the wax. The thread will cut a groove in the wax and get a good coating. But you need to do this several times as you sew
  2. Looks like you're not waxing your thread. Wax it as you sew. You can never pull stitches up real tight on chrome tan, its too soft Sharpen and polish the teeth of your stitching chisel
  3. I made this Hnefatafl game for #1 son for a Christmas present. I'm making a similar set for #1 dottir I bought-in the wood box. It was plain white wood so I stained and varnished it I get a lot of engraved plaques made by a certain engraver. He worked out how-to and made me about 22 of an engraved gold aluminium plaque for the top of the box Inside the box are four bags The gold bag holds the King The small linen bag holds the King's men The large linen bag holds the Opponent's men And the grey bag holds two brass dice and 4 rune stones The game board is 30cm -1ft square. The playing area is about 23cm - 9 inches square. Each square is 2cm - 3/4 inch. In my version the playing area is 11 x 11 squares The board is covered in coloured chrome tan leather, about 1.2mm thick, and the playing area is veg tan, about 1.6mm thick, and is glued on top of the chrome tan with contact adhesive. The centre and corner squares are stamped before it goes on but the lines are gouged after its on. 3 or 4 coats of 'Astonish' (like Mop n Glo) for sealing the playing area and then a tan 'antique' rubbed on into the lines. The 'antique' doesn't actually stain the squares but it does leave a tint to them just in the varnish sealer, I can clean this off if I want to but I liked the toning down the tint gave The game pieces close up. I first carved these about 20 years ago. I carved a few originals in polymer clay (aka Fimo or Sculpey) then I made rubber moulds of them. Every so often I have to make new moulds. After one of my first casting sessions I had a few mis-shaped men but I took moulds of them and add them into the sets so that not all the men are identical, like factory made. I cast them in a special plaster called Keramin. Then hand paint them. Other sets are just plain ivory and plain brown. But this set is special. The soldiers are about 1 inch tall. 36 soldiers and one King are need in my game, King and 12 soldiers and 24 Opponents. In each set I add in a couple of each colour for spares The game set up for play The King goes on the centre square surrounded by his army And the opponents are arranged along the middle of each side What I've not photographed, because its boring, is the 4 page instruction booklet that goes with each set Edit; I forgot to photo the underside of the board. A piece of thin stiff pigskin lining leather, glued and pinned on to hold the instruction booklet
  4. Happy Christ-mass to everyone ah, Heat, I think I remember that. Its about 2* C here and a storm blowing which makes it feel colder and heavy lashing rain. No relief until June '22
  5. I think you know the answer. You've already set out your points. Put the ties on first, then the lining. Can you put the ties on without the conchos? then after the lining is on tie up the conchos
  6. Here's an idea, I used this method 1. cut the pieces over wide, on each side which is to be sewn 2. on the inside, draw a line for the actual width, where the excess will be cut off 3. cut just outside of the actual size line and bevel the edge, trimming back to the actual size line 4. mark your stitch spacing on the bevel 5. use a round scratch awl to poke holes at your stitching points, in the centre of the bevel but angle the scratch awl so that it is at a right angle to the bevel surface It should come out on the grain side/outside of the piece about 2mm (= half the thickness of your leather) further in, or further in if you desire 6. After doing #3 on the next piece I put it up against the other piece to mark the stitch spacing, to get them the same. I use a pen to mark the two edges to go together, eg, A & A, B & B etc. I mark this on the bevelled surface so its hidden when all is glued up 7. When I glue up the edges I slide a straightened paper clip into and through a couple of sets of holes to keep it all aligned 8. with the holes premade I use a curved sewing awl to open up the holes and curved saddlers harness needles for the sewing
  7. excellent may you have the joy of applying your new brand to many nice items
  8. What was used in 1900 and what can be used now I think you could use one of these types of creaser Which leaves a bead/raised curved edge But used internally and in two opposing runs will give you a valley with a raised bead on each side
  9. A couple of things that really surprised me when I first got into making 'medieval' shoes & boots 1. not much has changed in 1000 years. Get a book with images of medieval & Viking shoes then get down to the shoe shops in your High street. You'll see many of the same styles in the shops 2. They are really comfortable A man and wife in my 'medieval' circle made their own shoes and wore them everyday. PS. if you can, sell that piece of yours on ebay. You'll get a top £ price for it on there
  10. I'd try using a fine tri-square file to chase the threads first
  11. yes, unlined. There were three soles; the outer walking surface one, an inner sole that the outer was sewn to and then a third inner-sole for foot comfort. That one was usually glued in. Gluing leather together goes right back to at least the Roman Bronze age
  12. I used to make shoes and ankle-length boots* of medieval style for myself & family and some of the members of my medieval presentation group. I only ever used veg tan except for some 'slipper' type shoes for my dottir when she was a toddler. Those were made from upholstery grade chrome tan and made in the 'turn shoe' style and method. Veg tan leather has been used for eons for boots and shoes. If it was good enuf and suitable for the cordwainers of old who am I to argue with centuries of experience? * just once I made thigh-length boots in 17th century style for a chap, never again ! Thickness of leathers used? afair, vamp & heel 2 mm, sole, inner, 1.5mm, outer sole, 2.5 mm, outer heel, stack of 2.5mm depending on 'client'. Worked and sewn dry but wet formed over a wood last. Sometimes wet formed over a 'client's' foot (one chap had a misshapen foot) Then the leather was sealed with beeswax mixture
  13. Thats how I've done my tool rolls, but with maybe more stitches and occasionally a ready-rivet at the top of each pocket And this reminds me I need to make a tool-roll for my dottir's archaeology tools
  14. I still think your best option is just to buy another piece. And mention to the seller especially what you want it for and what temper you want. When you work up a good working relationship with a leather supplier they'll get to know just what you want and like I also think you should use veg tan leather. You can change the temper of veg tan by adding or removing its natural oils
  15. Two options I'd go with; 1. if its not too much difference, live with it 2. buy another piece of the correct thickness. That would work out cheaper. You'll pay almost as much to get it split as it would to buy a new piece
  16. fredk
    Le Prevo ?
    I just spotted Le Prevo's Christmas message; Merry Christmas and a Happy New Year! This year, we will be closed from 5.30 on Thursday 23rd December and will re-open at 9.30 on Tuesday 4th January. Note that it says they will 're-open' on January 4th There is hope yet
  17. Not unless its being sold to you as 'damaged' and priced accordingly. All leather suppliers should be treating their leathers with care. With Le Prevo I've bought 2nd quality, or damaged or leather with scars from them in their discounted list and I know what I'm getting. All other leathers were first rate, blemish and damage free
  18. In my wax mixes I use carnauba wax, which does the same job. Better than paraffin wax? I dunno, but carnauba wax is the more traditional wax to use and mixes easier with the bees' wax Sometimes you just gotta mix it yourself. Its very easy to do
  19. most excellent If, if I did this I'd use some sort of backgrounder stamp to give the chap something to be walking along/on rather than be walking on air
  20. I find that statement very rude. Still no picture and still not sure if you are looking for or showing
  21. Le Prevo never boxed the leather sent to me but they did use a lot of corrugated cardboard around the roll which was inside a huge thick plastic 'bag'. Never had any damage. Leather bought from Tandy recently had the rolls inside carboard boxes I just use weights on the leather to hold it whilst I trace the pattern then cut out. I have a few 2kg weights which do the job. You can get bar-bell weights real cheap now
  22. In the UK we have a glue called Copydex. Its a latex based glue. Does what you are looking for
  23. I've checked some of my unwrapped leather. The wrapping is inconsistent. Some is flesh out and some is grain out. What is consistent is that the different suppliers put a piece of brown wrapping paper over the grain side before rolling it, both leather and paper as one, like a Swiss Roll
  24. Thats not a bad idea really. You can get silicone spatulas in the £ shop. Its worth a squid to try it. Probably work ok on thin glue but not on the thicker type I realised there are different shaped paint scrapers. I use one that looks like this; I got it in Home Bargains for under £2. The blade end is sharp for scraping but I filed some very light grooves in to the end, parallel with the sides, to help spread the glue, other wise the blade just scrapes the glue right off again
  25. An alternative to having spread contact glue over large-ish areas, consider spray glue. We can get tins of spray adhesive in the £ shop
