Everything posted by fredk
The copper & washer rivets you don't want to or cannot use
I'm in Donaghadee. About 20 miles east of Belfast. Just on the north-east edge of the Irish Sea and almost where Belfast / Carrick Lough opens. I know both Mayo Bridge and Stroke-City. Never lived in either but visited often enough I had to look up Lisdoonvarna. I reckon I've been through it at some time. I've been through most places here. I was once a car rally photographer so I spent a lot of time chasing cars and going thru middle-of-nowhere places No festivals or car rallies, no nothing, anywhere here this past year.
Use your 'cleaner' to dilute the Resolene. The 'windex', if its like our 'windowlene', will slow the drying of the Resolene a bit, meaning not so much drying on your needle tip Also consider a needle-less spray brush. I have a few different types of spray brush and for larger areas, quicker cover and more available fluid I prefer a basic needle-less type. Like this one; a Badger 250 It can be bought complete for under $20. Other makes of similar style are available, the cheapest I've seen costs about $10 It works on a simple venturi effect of air causing a suction and atomisation* of the fluid. No needles to clean, just that tube and nipple up from the jar. The spray pattern can be adjusted from about a Quarter (25c) size upwards * I'm probably wrong describing its working
Ask Le Prevo about DC 11-15 on this page http://www.leprevo.co.uk/rivets.htm I have some of these and they're brass metal, plated nickel in my case. But I bought them a long time ago and the newer stock may be different
B701 is a beveller with a fine check pattern on it? I prefer smooth bevellers. B200, is about the same size as the 701, and a B935 is good for small tighter areas. Its about half the width of the 200 If you want to keep to the checks then a B936 would be the smaller size, just about half the width of the 701 To go any smaller you'd need to grind a beveller down with a dremel type motor tool Also, have you tried tipping the beveller to the side to avoid any other work?
My oldest Singer is a 15K from a block of January - June 1915. Next oldest is a 15K-30 from a block in June 1937, then comes my 99K from a block in October 1956 Whilst not 'pure' leatherworking machines they sew the thin stuff I work with.
Yes you can Depending on your arbor press ram you may need to adapt it. Usually a hole of about 3/8 inch (9.5mm) needs drilling into it to take the parts, then you can use the parts meant for just about any press
Have you access to a lathe? If you have, mount up the head and reduce its diameter or cut a slice off the length
I use 'embroidery' scissors, bought in a knitting shop years ago. They are super sharp I also have some pairs of snips for occasional use and for cutting thin leather lace. like these https://www.ebay.co.uk/itm/Thread-Snips-Scissors-Yarn-Sewing-Cutter-Craft-High-Quality-Seam-Ripper-Each/142076493897?hash=item21146b4049:g:aX8AAOSwi2lZjYJv when I bought mine I got 3 for £1, so I bought a load and distributed them to friends
I think you are looking for a 'draw' or 'plough gauge' strap cutter https://www.amazon.co.uk/Professional-Leather-Cutting-Machine-Aluminium/dp/B07WWDL7PY/ref=sr_1_6?adgrpid=58616271092&dchild=1&gclid=EAIaIQobChMIiZ-Tkt7D7QIVkWDmCh1THgReEAMYASAAEgK9W_D_BwE&hvadid=259095674075&hvdev=c&hvlocphy=9046454&hvnetw=g&hvqmt=b&hvrand=15844784943665506087&hvtargid=kwd-297398175991&hydadcr=28176_1821089&keywords=strap+cutter+leather&qid=1607614747&sr=8-6&tag=googhydr-21 https://hwebber.co.uk/shop/c-s-osborne-leather-working-tools/leather-knives-sharpening-stones/knives-sharpening-stones-leather-knives/draw-gauge/?gclid=EAIaIQobChMI6dDH_9_D7QIVqujtCh25XgclEAQYBiABEgKF6fD_BwE
I once made some medieval type kit for a chap, belt, knife sheath, belt pouch, drawstring bag, wrist bracer. He insisted on raw fresh leather, no smoothing of cut edges etc and it had to have chicken fat rubbed into it. The leather darkened nicely over time but about 6 months later it all smelt very rancid. Stooopid guy reckoned 'thats what they would have used' I got paid so what do I care if his stuff was so stinky that no-one would go close to him.
Round my way kitchen fitters do not use real granite or marble. Grave stone makers use concrete internals faced with a thin veneer of granite or marble. So getting a new reasonable sized piece of real granite is not easy. All of which is odd as one of N.I.'s main exports is granite! But: I dropped into a local B&Q on Friday to see what they had in 'paving'. They have pavers of granite, about 30cm /1ft square. about 25mm /1 inch thick. Polished on one side, rough on the other. £4.64 each. However, when I checked with a B&Q chap they are to 'order' only. The order being 80 pavers! The chap, ever helpful, used his phone and checked and found another branch not too far away (8 miles) had 56 for sale individually, so I headed there and got one. The rough side doesn't bother me, I'll give it a base of scrap leather glued on. https://www.diy.com/departments/silver-grey-paving-slab-l-295mm-w-295mm/5015111965204_BQ.prd If you search B&Q for 'granite' these don't show up.
Make 1 piece for going around the sides and back of the waist. Make it wide, say 1 3/4 inches, then make two shorter end pieces, maybe 1 or 1 1/4 inch wide and sew to the wider piece.
I've only ever seen them in copper. But you can get a chemical which blackens brass and copper. I'll see if I can find my bottle of it and get the name
Newbie query on lining billfold and making ID pocket
fredk replied to PhilDimashq's topic in How Do I Do That?
In N.I./UK/Ireland we do not have Id in the way the US or mainland Europe has where every citizen needs to have an Id card. The 'Id' window in our wallets are usually used to show bus passes, or works id, ie passes needed by your employer etc. I put photos behind my plastic window, others I know put their bus passes there. Mr.Plod in N.I./UK /Ireland accept our word on our Id and only insist on something more in a serious, very serious, incident eg a road traffic accident On the mater of RFID blocking. Plumber type people use an thin aluminium tape to cover pipes. I've tested it and I use it sometimes in card wallets. A roll of this tape will cost you about £/$ 5. The roll is usually about 2 inches wide and 50 metres long. -
The hole is in the middle of the clear plastic window so the Id can be removed? Use a very sharp punch and smooth the edges with some fine grade wet & dry grit paper -
Eco flo is a water based acrylic. It can be re-constituted by adding water. But add a wee bit of alcohol to it as well. Something like methylated spirits or rubbing alcohol will do. If the Eco has not gone too far in its thickening, about 1 alcohol to 3 water should do it. Add small amounts, shake vigorously and then let sit awhile, do this till you get it as fluid as you'd like
Whilst searching ebay for a cheap airbrush I came across this https://www.ebay.co.uk/itm/Mini-Action-Air-Brush-Airbrush-0-3mm-Kit-Gun-Compressor-Paint-Art-Nail-Art-/402246944638?var=&hash=item5da7c9477e An airbrush with a mini rechargeable compressor. Seems to charge through a USB port. ~~ I have a few items which 'charge' off a USB but I run them off a USB adapter plug which goes into my mains electric socket Potential as a starter set? Handy to have around the leather work area. No need to dig out the bigger compressor and the hoses There are a great many of a variety of this set up currently on ebay, different types of airbrush and styles of the compressors
yes, I've noticed that too. I glue, clamp up, sometimes tap with a rubber mallet then sew it up. I leave a margin for cutting off so after sewing I use a good sharp knife and straight edge to cut that allowance off, which cuts thru the glued section and if I've done it right the leather there is well glued. I bevel the edge corners then slick it up.
- 10 replies
Its a block of crepe rubber material. Sometimes it can rub off contact or surface glue. Remember crepe? shoe soles were made of it in the 1950s - 'brothel creepers'
Made a Newb Mistake
fredk replied to garypl's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks nice Right hand carry, trooper's twist draw? -
Important Customs news for UK/Eu leatherworkers
fredk replied to fredk's topic in Marketing and Advertising
You'd need to put a 'Custom's Declaration' label on it declaring it a present. Without the label the package will be opened and examined and HMRC will decide if taxes are liable. If they think you are cheating they will inform Oz post who will prosecute you for fraud. The US IRS are novices at collecting taxes compared to HMRC, who have several hundred years head start Its seems the answer is almost yes; Amazon and ebay, but not etsy which is a sales window.
