fredk
Contributing Member
Everything posted by fredk
  1. Have either of youse thought of using a one-handed clamp? They don't tighten up as much as a regular C cramp but tight enough for the embossing https://www.ebay.co.uk/itm/Quick-Grip-Ratchet-Vice-Bar-Clamps-4-Inch-100mm-Rapid-Clamp-Spreader-Freepost/231842810316?hash=item35fae889cc:g:L0kAAOSw0PBdAQkz
  2. Well, thank you Mr Tandy. I do like a lot of their patterns and tip sheets
  3. yeah but, no but, yeah but. . . . . look how many more you can get for nowt. I'm now adding up a list of pages which were on the extreme verge of interest but worth getting now I think it took me about 5 hours last night. Started about just after 22:00 hrs and ended shortly after 03:00 this morn
  4. Hang-on in there. Keep trying. It may be worthwhile for you I've tested my link again and its opening ok
  5. Tandy keeps an on-line digital resource of thousands of their old template/patterns, tips sheets, ideas from some of their tutors eg George Hurst. They even have digital copies of some of the Al Stohlman books and other books. Prices ranged from Free and upwards, many in the 99c and $1.99 brackets Recently I was keeping a load of these patterns and tip sheets in my 'basket'. Cost was to be about $40. I was waiting on a decent $ to £ rate before buying. Last night I went to buy them and found the system had deleted the 'basket' contents. I put the patterns I wanted back in, but the Library pages were slow in loading, up to 1 minute to change a page! But I discovered as I went along the hours [literally, hours] to go thru the Library and put the ones I wanted, plus more, was well worth it. All the patterns et ectrea are FREE, ~ as of the time I write this. (15.25 BST August 10 '19) I've no idea if this a temporary offer or what. Check it out for yourself: https://www.leathercraftlibrary.com/ But remember the website is running very slow right now, but after you buy the download of the pattern is as fast as your own computer allows
  6. This is true, even for day to day. Yesterday I cased some leather, it took almost all day until it was ready, today it took less than a couple of hours, due to weather changes - yesterday was very wet and cool-ish, today is very warm and dry
  7. I picked up on this. Tandy leather can be very inconsistent, even hides in the same 'batch' can be very different Whenever you buy some leather and you think you might want to tool it, cut off a couple of those sticky-out bits, cut them down and see how each of those bits does with different wettings. It will give you some indication how that hide will do
  8. Tan Kote is not a final finish sealer. Its just another top coating. For sealing after work, some thinned coats of Resolene or Super Sheene. At least 3 coats of either, thinned with water 1:1. For further protection of the paintwork put on two or three coats of 'Pledge with Future Shine' or whatever it is currently called**. Its on the supermarkets shelves as a floor 'polish' but its actually a water thin acrylic varnish ** the makers keep changing its name
  9. Its essentially the same as a Mexican Loop pistol holster. Wet the rear piece which forms the belt loop and it should be flexible enough to stretch and fit the sheath down thru. When it dries it'll stiffen and shrink a bit to hold the sheath tight in place
  10. I sew with 1mm thread. for that my JJ Harness needle pack says 2/0 and my Osborne Glovers needles are Gauge 17. Both are about the same diameter and a tad too big for 1mm thread but it was the closest I could get
  11. slim chance I reckon. OP hasn't been on for nearly 5 years. Last posted September 6 '14
  12. I had a 2cm wide brass stamp made. I use it with a Tandy press. This press; https://www.tandyleather.eu/en/product/craftool-pro-hand-press dampen the leather, set stamp in place, cover with a 3" square of 3mm steel plate, use press to press the stamp into leather, viola. . . .volia. . . . err, roberts your mother's brother brass stamp: Impression on leather; (bottom right)
  13. Brand: dunno, I got them from Le Prevo many years ago. I got 1000 so I'm still using them up Material: they are nickle coated steel (despite them looking like brass in the photo, they are nickle silver) On the shield they go through; 9mm of laminated board and about 4mm of the leather tab. There is just a tad over 3mm of the stem left for the head. I just give the rivet a great big whack to set it and it countersinks itself a wee bit.
  14. The post of the rivet should stick out by about 3mm (minimum) to 4mm (maximum) Any less than 3mm and there is not enough of the post to crush into the head, any more than about 4mm and there is too much post crushing into the head and the rivet head will be deflected to one side. Both make poor joins, but the short one is worse. As for strength; the guige strap on this shield is held by a single 11mm head rivet on each end. The shield weighs about 8kg and the users of these shields flung them about by the guige strap. Never a fault happened,
  15. First place I'd check are the feed dogs/teeth and see if they are clear of accumulated fibres and dust
  16. Could it be that its a cobbler's stitching clam and the shortened tail, which looks like its been shaped, goes into a hole on the cobbler's pony? Interchangeable with lasts et cetera
  17. yeah, wot he says. One time some of our goats got out of their field. I found three of them on top of my Caddy. Not too much damage done tho.
  18. inside-out construction? turned right side out to finish?
  19. The broken-cross symbol was a particular favourite of the Native Americans of the South-West area of the US and of the Navajo. afair the Navajo generally gave up using it during and after WW2 because of the symbol's association with the Nazi regime and the general public could not be bothered to differentiate. btw, the broken-cross features in every ancient culture around the world
  20. partly optical, the pencil slides in and out easy enough. The eraser/sharpener unit needs sliding down a bit to allow the pen to slide out to the left. Initially there was not going to be anything to the left of the pen holder, then it was just going to be an eraser, a lot smaller of what went in. On the Mark 2 I might slope the pen holder, left side low, right side high. Its also been suggested to put the pens vertically (and allowing them to poke up past the end of the board) where the eraser is and put that next to the stop watch. I'm toying with the idea of having two map clips; either one top & one bottom, one top & one on left side ~ in an open car one needs to hold the maps and papers well or they take off and away. PS. On Thursday 1st Aug I received a nice letter of thanks from the recipients
  21. welllll, I think, its for stretching painting canvas over a frame. This is to pull the canvas over the frame and the holes in one jaw are used to tack the canvas in place. Or for pulling chair webbing over a chair frame
  22. umm, mike, pardon me but I think you're not thinking straight. Lay a zipper down, the closed tag end to the right, the pull has to go left to right to open up the zip. Now turn that zipper 180*, with the closed end on the left. The pull has now to go right to left to open up the zipper same zipper orientated in different directions. pardon me if I'm getting your message wrong I should have made it clear in my previous posting that the zipper was pulled left to right to open it.
  23. yeah but, no but, yeah but, no but, yeah but, the ones in my motor club are a tight-fisted lot. They'll spend ten of thousands on a vintage car but wont spend £20 on a new jumper or trews
  24. Thank you once more folks. This was handed over at one of our club events on July 20th. The couple were rather pleased with it. Time will tell, and so will they, if it serves its purpose. There is a club event this coming Sunday, 4th August. I do not know if the couple will be out for it. If they are it is an event in which this board will be useful to them Secretly I'm hoping a few club members might ask about having something similar
