fredk
Contributing Member
Everything posted by fredk
  1. I found my poly mallet was too light so recently I invested in a 24oz dead-blow mallet. I've not used it much but it has made a difference
  2. The two ends look different sizes. I'm thinking this is a home made tool to have two commonly used straight screwdriver blades handy on one tool
  3. yes it will. I find that a belly stretches more from back-bone to centre of belly than along the belly from leg to leg. Laminating it with a less stretchy section reduces the stretchiness
  4. The chap I was talking to who showed me the metal parts soaked the parts in cellulose thinners. He did not explain why though. But that might have been to dissolve the plastic
  5. You can 3D print with metals. I've seen aluminium and brass
  6. A member posted this up; I have not used it so cannot vouch for it
  7. Eagle looks good, Marine looks subtle. A wee tip/idea, if you can't paint really neatly, do it deliberately rough. EG on the Arizona, don't try to fill the rays with colour, do it sort-of child-like scribble, not right to the edges
  8. More information required
  9. Its not something I really looked for. But my 1.5mm thick c/t is harder to hand sew than 1.5 or even some 2mm veg. On these I use a glovers needle and just sew with no pre-made holes
  10. @AndrewWR thank you. I'm waiting on an investment dividend to be paid and I might buy some of this 'ere Kanga hide What ever would Poo think!
  11. Another late reply. I dunno how I missed this until now That is really some bag/holdall (we call a different style of bag a 'duffle bag' ) I'd be afraid to use it out in the real world!
  12. That looks very nicey indeedy Your design sounds like the style of bag I'm supposed to be making for no.1 dottir Where did you get the kangaroo hide from?
  13. I'm a little concerned about what you bought. It sounds like it has a cheap sprayed on top finish. All the chrome tan I use, and I do use a lot, is dyed thru and will not scuff at all, one of the main reasons I use it on certain projects. Certain areas on the projects will buff a bit through wear on that area, but that's after several years of use. You say Neat-lac took 'out that scuff mark and it doesn't seem to scuff as easily'. The Neat-lac is giving a harder top surface but the problem of the weaker top finish is still there. I would try to remove that weak old top coating and put a totally new top finish on the leather. To remove top finishes on dyed/finished chrome tan I use cellulose thinners, aka lacquer thinners. Then I can re-dye and refinish These hats are made with chrome tan. I have several Kilos of it brown but I wanted some hats in black. I did as above and re-dyed in black with several coats of black resolene to seal it In the brown chrome tan; In black, from the same stock of chrome tan Just my $1 (inflation!) on it
  14. These days you can no longer reckon that more expensive = better, cheap = poor. Nearly all my oval punches are from China. They each were a modest price. And all are perfectly ok. Some needed a wee bit of sharpening first but nothing too bad. Buy some modest priced punches. Buy just a couple of different sizes from one place. If they are ok, then buy more from them, but even that is no guarantee the next ones will be as good
  15. all of the above
  16. The buckle tongue goes thru the hole at an angle and in use it deforms the circular hole into an imperfect oval hole, which eventually looks not-nice. If you start with an oval hole there is virtually no deformation and the hole will still look better after much use
  17. Does the 362 'diamond' shape look better than the 361 'square' shape? Personal preference obviously, but what do youse think? Edit; PS, I've found larger versions of these stamps in Sergey's catalogue. They are 361B, 362B, and 362BB
  18. Sergey has an advert at the top of LW pages
  19. I got a message back from Sergey. The square stamp is 10 x 10mm
  20. I've bought at least 2 stamps, perhaps more from that chap. afair it took about 1 week to get to me in UK. All the stamps are of 1st rate quality edit to add; I checked my records, it took 12 days. And oddly, he has not put the sizes of these stamps. On nearly all the his other stamps he has put the size, so I've messaged him asking the size of the square one
  21. This; https://www.ebay.co.uk/itm/333549358924?hash=item4da9174f4c:g:VgsAAOSwoQlecQwl or this; https://www.ebay.co.uk/itm/333549359609?hash=item4da91751f9:g:l-MAAOSwmwhecQxz
  22. Nfo will soften the leather and make the gloves easier to pull on but not make them stretch to a larger size which the OP wants
  23. I had a thought on this; try wearing several rubber or latex gloves. That should build up the size of your hand easier and quicker
  24. Don't use nfo. Wrap your hands and fingers with a layer or two of duct tape or similar. Soak the gloves in water, really soak them. Then pull on and let them dry out on your hands. Wet moulding them. Then when they are dry take off, take off the duct tape and the gloves should be a bit looser
