Everything posted by Dwight
Iwb Holster
Dwight replied to charlescrawford's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Not meaning to bash you my friend, . . . but in a nutshell, . . . sounds like a lousy design. Try making a standard pancake, . . . then instead of belt slots like you would use for an OWB, . . . make the ears a little taller, . . . put straps and snaps on it, . . . the straps go over the top of your pants, . . . down under your belt, . . . then come up and snap on top. Tried and true design, . . . works like a champ, . . . and if you pull it out of your britches, . . . there is something else going on we just don't understand. May God bless, Dwight -
Need Help Finding A More Durable Finish For Cuff Bracelets
Dwight replied to Eirewolf's topic in How Do I Do That?
I use Feibings thinner for their dye. In reality, . . . you don't save a lot, . . . but the dye goes on better I think, . . . plus there is a whole lot less ruboff and buffing that has to be done. As for contitioner, . . . I really haven't used it enough to be competent to tell you much about it. My "conditioner" I've used in the past has simply been neetsfoot oil, . . . used sparingly, . . . if at all, . . . as most of my stuff needs the rigidity, . . . belts & holsters and the like. May God bless, Dwight- 15 replies
- finish
- rubbing off
(and 3 more)
I put this in my Google Chrome,..... youtube: airbrush dying leather I got a full page of videos. Didn't watch them, . . . but you'll probably find something there to help. May God bless, Dwight
Airbrush ! First dye the whole thing the lightest color you will be using, . . . come back and feather in the fades you want. Suggestion, . . . go practice on some cardboard or something else first, . . . get your technique down. Harbor freight has airbrushes for less than $30, . . . and they'll work for what you are doing. And yes, . . . if you want a hint of green, . . . you can add that to the clearcoat, . . . but again, . . . better practice it so you know what you are getting. May God bless, Dwight
Leather is like in-laws, . . . comes in all kinds of sizes, shapes, flavors, and temperaments. But only one can be fully and successfully utilized by most guys. In the case of in-laws, . . . it's that huntin / fishin / Ford driving brother of hers, . . . in the case of leather, . . . it's vegetable tanned. Put what you have in a box, bag, drawer, or cupboard for a while. Go get get a piece of good vegetable tanned 8/9 oz leather (buy a small hunk on Ebay), . . . get some cheap tools, . . . mess around with it, . . . see if you like it. Getting into leather working really is sorta like getting married, . . . and if you decide to bail out after 20 bucks worth of leather and 30 bucks worth of cheap tools, . . . you haven't lost much, . . . kinda like the $50 annulment, . . . May God bless, Dwight
Eirewolf, . . . I'm going to go out on a limb here, . . . but it is supported by several years of past experience: you simply are applying the dye and the resolene wrong. Especially the black dye, . . . cut it 2 to 1, . . . 2 thinners to 1 dye if you are using Feibings Pro Oil dye, . . . and let it dry, . . . 24 hours minimum. Then get an old wash cloth you never want to put on your body again, . . . and buff that piece of leather like you are shining your shoes, . . . buff hard, and seriously. THEN, . . . cut your resolene 1 to 1 with distilled water (or some water that has VERY low chlorine in it). Use a 1 inch, . . . cheap, . . . bristle brush (about 49 cents at a hardware store), . . . and lightly brush on a full coat of the resolene, . . . when it is dry, . . . 24 hours later, . . . buff it good just like you did the dye. Then add a second, maybe third coat. Experiment, . . . you may need a 4th coat. I don't do more than 2 for belts and holsters and they hold up great. Resolene and dyes are not made to be used full strength from what I've experienced, . . . so I really think that is your problem. There is another finish you can try, . . . and I really like it for some of the stuff I do, . . . it is a mixture of beeswax and neatsfoot oil, . . . it makes a very nice finish, . . . doesn't allow bleed through of the dye if it is done right, . . . but is a more time consuming finish. Anyway, . . . let us know how you make out. May God bless, Dwight- 15 replies
- finish
- rubbing off
(and 3 more)
Vegetable tanned leather is what you will want if you want to dye it, stamp it, decorate it, etc. Blanks can be purchased through Tandy Leather, or almost any of the other suppliers. Go to a Tandy store and pick it out yourself. A belt is a good project for a "first one" and the folks there can get you started out at least mostly correct. I personally use Feibings pro oil dye and Resolene for a finish on all my belts. Both are cut 50/50, . . . dye with thinner, Resolene with water. May God bless, Dwight
My wingtips are all little holes punched in the leather, . . . so get a little punch, . . . and punch holes in the leather, . . . you'll have to make the pattern to suit you, . . . mine are a couple different sized holes. Stain the whole thing brown to start with, . . . then being very careful, . . . dye the edges only. May God bless, Dwight
Mine has some very small parts to it as is easily seen, . . . and is made of a plastic, . . . someone correct me if I goof this one, . . . I believe it is called Delrin, . . . ??? Anyway, . . . white tough plastic, . . . has held up well, . . . would recommend it to anyone. May God bless, Dwight
Google Ohio Travel Bag, . . . open their on-line catalog, . . . if they don't have it, . . . I always pretty much consider it not being able to be found, reasonably. By the way, . . . if you have a slow internet connection, . . . it will take a little while to load, . . . but in the long run, . . . it's worth it usually to wait. May God bless, Dwight
Here's mine: as a pastor, and a leather worker, a guy named Dwight, who lives in Waldo, Ohio, . . . it tells all of that, . . . which is what I wanted. May God bless, Dwight
I have no idea, . . . as I don't know the designer of the pattern or belt, . . . what I can show you is how I do mine, . . . see the enclosed diagram. From what I could see, . . . it looks like a pattern for a rough out, money belt style. Is that what you are making? May God bless, Dwight
Spur Strap Challenge - Baby Steps And A Million Questions
Dwight replied to BarnHey's topic in Getting Started
I line any spur strap I make that has conchos / spots / any metal decoration, . . . to protect my customer's boots. I do not want to get a bill for a ruined $500 pair of Plesiosaurus skin roping boots. But I also don't want those boots harmed by my work, . . . if the cowboy rips off his heel doggin' a doggie, . . . that's his problem, . . . I just don't want to contribute. That said, . . . I use pig skin, . . . contact cement it, . . . sew it, . . . full covering over the back and the tongue, . . . and it is all done before the dying and staining process starts. AND, . . . I also back and sew the matching piece of the spur strap. May God bless, Dwight- 3 replies
- newbie
- spur strap
(and 1 more)
There are some "ways" of doing a saddle stitch that are easier or faster than other "ways", . . . but no matter how you cut it, . . . it is all hand work, . . . beautiful when it is done, but none the less, . . . all done by hand. May God bless, Dwight
Greyhawk, . . . I'm sending you a couple pics of my saddle, . . . and yes, . . . I've ridden in it, . . . and I love it. Bought it out of a pawn shop in Denver, Colorado. It has seen a lot of better days, . . . but it may give you some ideas if you look at it closely, . . . colors, textures, worn spots, etc. As for stamping it "after the fact", . . . it was commonly done years ago, . . . cowboys with home made stamps (from 20 penny nails and a file), . . . used a small hammer, stamp, and a piece of firewood from what I've been led to believe. Mine has that appearance, . . . plenty of places there are stamps that the original maker just did not do. Just remember, . . . it IS, . . . YOUR, . . . saddle, . . . treat it like YOU want to. I had planned to refurbish this old relic when I first got it, . . . wound up making a few changes to make sure it was sound enough to ride with, . . . and will do some cosmetic things later on, . . . but for now, . . . it is the entrance hall highlight of my leather shop, . . . and I like it. Not meaning to disparage your saddle, . . . but I would not trade with you, . . . I like mine so well. You can make yours to the place YOU like it too. May God bless, Dwight
So far, . . . price has been a non issue with my customers. It's almost one of those: If you have to ask the price, you cannot afford it, . . . type deals I guess. I have raised my prices a couple of times, . . . for various and sundry reasons, . . . and have yet to hear someone gripe seriously. A raised eyebrow now and then, . . . but that is all. One of the things I've found out about the "leather" industry, . . . these are not your typical Walmart shoppers, . . . and none of them are looking for the weekly leatherwork coupons. They pretty much are savvy enough to know leather is what they need, . . . vinyl won't do, . . . and kevlar is for plastic fantastic shooter bangers, . . . so they come to us. Good industry in my book. May God bless, Dwight
From my perspective, . . . and historical data, . . . you had fun with your dog. I've made em from about 30 inches long to somewhere north of 55 inches long, . . . but I cut both pieces (only a 2 ply belt, . . . with bullet loops sandwiched between) EXACTLY the same. Then glue em all together, . . . sew em up, . . . and they work like a champ. I'm thinking that you are very much over thinking this project, . . . May God bless, Dwight
Hardware For Vertical Shoulder Holster
Dwight replied to zookeper's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Lobo laid it out pretty good there. One thing he didn't mention, . . . and I've been successful at least once, . . . Ebay. Go looking on there for something similar to what you want. I bought a Hunter shoulder rig on there for $9 (I think ????) several years ago. I disassembled the thing, . . . got my steel clip, . . . used it, . . . and also salvaged the elastic strap, . . . pitched the rest. As long as you are not in a hurry, . . . and it is a "one of a kind" product for you, . . . you may get lucky as I did. May God bless, Dwight -
Russell, . . . an old tried and true pattern obtaining method: go to your local Goodwill or Salvation Army store, . . . buy a product that is very similar to what you want, . . . take it home, . . . disassemble it. Voila, . . . you have the best pattern you could possibly get for that project. It also allows you to try it on, . . . and if it is too long here, . . . cut it down, . . . too tight there, . . . add a little. It is also the lazy man's way of doing it, . . . but it pays good dividends. May God bless, Dwight
Some leather is sold by the square foot, . . . some is sold by the hide, . . . but there is a sneaky little way to beat both of them. Leather is generally measured as "Ounces", . . . 4/5 oz, . . . 6/7 oz, . . . 9 oz, . . . 12 oz, . . . etc. What that means is that if you cut out an exact square foot of that leather, . . . it would weigh that many ounces. Therefore, . . . if you get a $20 digital fish scale, . . . hang it up, . . . put a clamp on the bottom of it, . . . you can weigh your piece of leather you just bought from Ajax Leather Emporium, . . . when you cut off a piece for a project, . . . re-weigh the big piece, . . . subtract that from the original weight, . . . you then have a fractional figure you can use to comprehend how much this project is going to cost you, . . . down to the exact penny. It won't take long until you will have a fairly good handle on what it is costing you for each product you do. BUT, . . . the really big advantage is not in every day use, . . . it is in the "one of a kind" pieces you will do, . . . that take so much 8 oz, so much 4 oz, and a hunk of that 12 oz stuff too. The weight factor will nail your cost far closer than any other way. What Chief said is also good, . . . taking nothing away from his process, . . . but it is only applicable if you buy it by the foot. Weight will take care of all of it, . . . including different types of leather. I am in the process of finishing up a very special gun bag for a friend, . . . one which I am basically doing for cost. It has concho's, buckles, veg tan leather of two different thicknesses, chrome tan leather, and sheepskin is also involved. If I did these for a living, . . . weight would be the only way I could see for sure what my up front cost would be. May God bless, Dwight
Talc is used for a lot of things, . . . easy way to see it used, . . . put some Johnson's baby powder on your hands, . . . rub em together. Slick, . . . smooth, . . . that's what talc does (among other things). Also used in paint. May God bless, Dwight
The best way is with a punch, . . . you can use a clamp to squeeze it down and cut the leather. If you don't have a punch the right size, . . . get a piece of hard board or metal, . . . the size of the circle you want. About 1/16 to 1/8 inch thick is best. Clamp it to a table, . . . with a cutting surface under it, . . . your leather between the circle and the cutting surface. Strop your razor knife really sharp, . . . Run your razor knife around the outside. ONLY GO ONE WAY !! I know it sounds foolish, . . . but if you try going both ways, . . . most of the time you'll wind up with a "tail" on your circle. Going only one way erases that, . . . most of the time May God bless, Dwight
First Complete Set
Dwight replied to Colt Hammerless's topic in Gun Holsters, Rifle Slings and Knife Sheathes
As always, . . . good looking stuff. You could call it eye candy. May God bless, Dwight
