Everything posted by Dwight
Following up on what Renee said: do a search for Brazos Jack as author, . . . you will have to go down through the list, . . . you are looking for 4 separate posts, . . . one for the holster, then it's instructions, . . . another for the cartridge box, then it's instructions. Have fun, . . . I haven't made mine yet, . . . and the operative word is "yet", . . . May God bless, Dwight
That only works to a certain degree, . . . as the bag will mush up against the tooling and scramble it. I have come to the conclusion that I can have a formed holster / knife sheath, . . . OR, . . . I can have a tooled holster / knife sheath. Asking for both is asking for kids and peace and quiet, . . . it's either/or, . . . May God bless, Dwight
If you are waiting for the oil to soften and make the leather supple, . . . you have about 2 or 3 gallons to go. Take the belt in both hands, . . . and roll it like the little drawing. DO NOT roll it with the flesh side out, that will cause serious wrinkling. I even have a small steel rod that I will lay down on my work bench, . . . and roll it back and forth inside the belt to start breaking it in. I do this before dying, . . . after dying, . . . and after the final finish. That way my customer doesn't get a leather plank they have to try to wrap around their body. Oil alone will do it, . . . but there will be so much oil in the belt, . . . it will ooze out onto the customer's clothing, . . . will not be a happy scenario. May God bless, Dwight
- 3 replies
- neatsfoot oil
- how much oil to be applied
(and 2 more)
I've had mine for several years, . . . and have to say, yes, . . . it can be finnickey. It can be a pain. But then so can a Ford, Chevy, or an Austin-Martin. No, . . . the stitch on the back is not as pretty as the one on the front, . . . but it is a working stitch, . . . not intended to be the back side of a show piece in a museum somewhere. If you want a working machine you can take anywhere, . . . get one. If you are a whiney, grouchy, perfectionist crab, . . . probably need to get something else. As for their customer service, . . . my experience has been tops. My machine clunked on me twice, . . . both times I took it to them, . . . Ben cleared off his bench with only a couple hours notice, . . . fixed me up both times, . . . at minimum charge. Hand sewing, using two needles and saddle stitching will be a lot prettier if you are into esthetics, . . . personally, I'm not. And in all the belts, sheaths, holsters, etc. I've sent out to paying customers, . . . none of them has come back and wanted it dressed up. Anyway, . . . getting off the unpaid advertisement box, . . . good luck on your decision. May God bless, Dwight
Modern Cowboy Lawman Rig
Dwight replied to Jumpout's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That is one beautiful rig. I've got a west Texas nephew LEO, . . . I can just see him in that rig. I'm gonna email him the pictures, . . . and I can hear him wanting one even now, . . . but I'd bet that the department would frown seriously on it. May God bless, Dwight -
Expanding on Electrathon's post: go on a diet, . . . when your shape from rib cage to thigh is similar to a telephone pole, . . . your belts will no longer become "bent". Seriously, . . . your body heat, . . . sweat, . . . and the pressure of your body attempting to escape the confines of the belt, . . . all add up to a modification in the shape of the belt. Same thing happens with your billfold. Buy a new one, . . . nice and flat, fits that skinny little box like it was meant to. Put a couple hundred bucks worth of 20's in it, half dozen credit card type items, a few business cards, some family photos, . . . two days later the shape is changed. May God bless, Dwight
Modified Embossing Not Making A Strong Impression
Dwight replied to jimmy eng's topic in How Do I Do That?
The first problem is I believe, the size of the plate. That much surface area needs some serious pressure, . . . and a solid bottom under it. Foam, wood, etc. will not do it, . . . steel would be preferred, . . . cover it with masking tape to prevent rust, etc. Secondly, . . . properly case the leather. Give it a good dunk in water, . . . submerge it for a good 15 seconds in water that is warm enough to feel warm, but not hot enough that you cannot keep your hands in it comfortably. Third, . . . cut the pieces a bit bigger than the finished product you want (I assumed you are making beer coasters). It makes for a whole lot easier handling as well as the water gets into the leather where it needs to be quicker and easier when cut into smaller pieces. When they are cut, . . . put them in the water and bend them back and forth a couple of times, . . . it works kind of like squeezing a sponge in water when you want to get it wetter, quicker. After you bring it out of the water, . . . lay it on a towel, . . . flesh side down, . . . let it return in color to just almost natural leather color, . . . it will be properly cased for your job, . . . put in under the press, . . . go for it. May God bless, Dwight- 8 replies
- emboss
- drill press
(and 3 more)
To Stitch Or Glue
Dwight replied to Kanuist's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Everything I would have said, . . . has been said. Glue it, . . . stitch it, . . . go on with life. May God bless, Dwight -
Another thing you can do is add a little alignment bar to the stamping tool. Take a collar with an allen head set screw, . . . solder a piece of a paper clip to one edge of it. Angle your collar onto the tool so that it is parallel to the edge of the belt while stamping in the configuration you want, . . . that way you only have to line up the direction, and the tip placement of the stamp. Works like a champ. May God bless, Dwight
Hey, Toolingaround, . . . thank you for the update. I have stayed away from NF simply because it DOES darken, . . . and if you want to keep the shade simple and clean, . . . can't do it with that. But the fact that they advertise it as non darkening, . . . i WILL be getting a jug of it. Gonna play with it, . . . and some day, if I live that long, I want to make a saddle for a special young lady (great niece), . . . and it will be as natural as I can make it. Thanks again, . . . may God bless, Dwight
Question About Making A Rifle Case
Dwight replied to johnggrg's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Personally, . . . I can't understand the 3 piece part, . . . one piece is how I do them, . . . plus handles if desired. You can add pouches, mag carriers, handles, hanging straps, etc. But the basic rifle case is one piece of leather and either a button for an end opening one, . . . or a zipper for a side opening one. May God bless, Dwight -
Leather will be darkened over time just by simple light, . . . daylight does it, . . . look at any older saddle, . . . and there just isn't much that can be done about it. The one single product I know of that will help, . . . Resolene, . . . as it has a UV blocker (the part that darkens the leather), . . . but it's not guaranteed forever. I did some "samples" a few years ago for a show, . . . one only had Resolene on it, . . . it is still pretty close to the original veggie tan color. Good luck, may God bless, Dwight
Latest Saddle Off The Bench
Dwight replied to BondoBobCustomSaddles's topic in Saddle & Tack Maker Gallery
I think it is just awesome, . . . especially since I prefer a seat like it. May God bless, Dwight -
I sorta use Red Cent's technique, . . . but if suede is involved, . . . it goes on my belt sander, . . . suede up, . . . I then take a good sharp beveler to the veggie tan, . . . and the edges come out really nice and clean. My drum sander is an oscillating one, . . . and it don't like suede. It can be burnished, . . . but it's kinda like riding a unicycle, . . . ya just gotta learn how, . . . and the only way is to practice. Take some scraps, . . . glue em together, . . . treat it like a project, . . . and practice with it. I usually use an oversized slot for burnishing, . . . then hold the leather slightly crossways, . . . hard to explain, . . . but it works. May God bless, Dwight
PM sent
- 8 replies
- belts
- leatherworker
(and 1 more)
For the most part, . . . I use the thread I buy at Tandy on large spools, . . . about $25 a spool, . . . I use only 346, . . . and it becomes whatever color is attributed to it in the dying process. Blacks become a very dark grey, . . . and browns always seem to take on a "one shade lighter" look, . . . but it is presentable, useable, and I really don't have any serious complaints from the customers. The 277 thread simply doesn't work for the look, feel, and quality I want out of my machine, . . . a Tippmann Boss. May God bless, Dwight
It's OK, Andy, . . . I used to be razzed for being a "bird legs" kind of guy. Still so at 6-1 and 175, . . . We can ride either yours or mine, . . . them fat legged guys won't be able to. But mine is not one you slump down in and head out for a 10 mile ride like you were in a rockin chair. May God bless, Dwight
I don't know where to look on mine for a year, . . . heck, I was tickled to find out what kind it was. Pretty much have decided to leave well enough alone. Gonna clean it and oil it, . . . plan on riding the July 4th parade with it, . . . it's an office ornament right now in my leather shop, . . . lots cheaper than paintings, . . . and a whole bunch more practical. Someone added a lot of stampings to it, . . . I look at those and just have to wonder, . . . sure wish it could talk. May God bless, Dwight
How Do I Stop My Leather Stretching When Embossing?
Dwight replied to Pinky's topic in How Do I Do That?
I don't have a lot of experience embossing, . . . but the last belts we did, . . . we lightened the pressure a bit, . . . made everything so much better. We wanted really deep impressions, . . . but it gave us other problems, . . . like you mentioned. May God bless, Dwight -
Well, I suppose one could follow that line of thinking, . . . but the overall effect would I think be minimal. The down side is that it also makes the overall holster longer, . . . which can be a pain, trying to fit it exactly where you want it on a belt, considering the belt loop placement. Diagonal slots take up more belt room, . . . leaving less for adjustment. Plus, . . . I think if you look at most of the production makers, . . . they're really close to parallel, . . . if they aren't. May God bless, Dwight
Good holster for your first one, . . . the initials on the back is a nice touch, . . . as well as the model, . . . some folks need that. On your sweat shield, . . . you beveled the hair side, but not the flesh side, . . . so when you burnished it, . . . a hard lip formed on the gun side of the sweat shield. Take a spoon, . . . put your thumb in it, . . . and work out those hard lips. Believe it or not, . . . after finishing them really good, . . . they can be sharp enough to cut you. The only other thing I saw is a common one for new pancake makers. Your slots are not parallel. Both are angled in so that they sort of point toward the muzzle of the gun. It usually is not a problem, . . . but if the length of your slots is "just enough" for the belt, . . . it will put the belt on a bind behind it. It also makes it very hard to put on if the slots are only "big enough" for the belt, . . . May God bless, Dwight
Sorry, Cheryl, . . . wrong answer. Resolene goes on the front, back, edges, keeper, . . . only things it misses on my belts is the holes and the buckles. Not putting it on the back of the belt is telling your customer that you want the belt to soak up his / her sweat, . . . get all grungy, grimy, gooky, wear out, and be useless sooner so they can buy another one. it is a sealing product, . . . meant to seal the dye in, . . . keep the belt looking greater, longer. It also seals most liquids out, including sweat. I cannot think of a project I would not do, . . . inside and out with it, . . . unless I lined the inside with suede or veggie tan to protect the weapon on a holster, or the blade on a sheath. Those are the only exceptions in my line up. YMMV May God bless, Dwight
If you only have a few, . . . or have some extra time on your hands, . . . and / or are VERY picky about your spots: take one, . . . slide it into your spot setter handle, . . . then pull up on the sleeve so that just the points end sticks out, . . . take a piece of masking tape, . . . tape the sleeve in place. Then use the spot setter as the tool to mark where you need the holes, by pressing down with it on your leather. Take a narrow awl, . . . make your holes. Push your spots through with your thumb, . . . turn the piece over, . . . put the spot in the proper dome in the tool that fits it, . . . push the spot legs over to the center of each spot with a flat blade screwdriver, . . . after all spots are set, . . . turn the piece back over, . . . lay it on a hard surface, . . . use the spot setting tool to then complete the job by tapping them until they are set down in the leather a bit. I set all of mine this way for a long time, . . . then went to the poundo board method, . . . do most of them that way now, . . . but for very special projects, . . . still come back to this. May God bless, Dwight
Handmade Holsters
Dwight replied to JBLeatherworks's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I really like your work, JB, . . . and as a pastor, . . . I share your enthusiasm. I am more into the "watering and keep alive" rather than planting, . . . but we all work for the same cause, . . . so that's great. Just one caution though, . . . the first post, . . . center holster, . . . looks like a Glock. I would never get the trigger guard so deeply boned. Glocks have no external safety, . . . just that little dipsy doodle thingy in the center of the trigger, . . . the owner shoving his piece in the holster in a hurry might get an unintended discharge, . . . which would not be a happy affair. I'm extremely careful of boning the trigger guard for Glocks and similar plastic fantastics that have no real safety on the weapon. Again, . . . not a criticism, . . . just a caution. May God bless, Dwight
