Everything posted by Dwight
Look on Google . . . ask for Tandy Leather . . . find the closest store . . . go ask them. Some are knowledgeable . . . some are sales people. But it is a good starting place. May God bless, Dwight
Badhatter . . . the best advice on stretching the leather for a belt. Don't. 10 oz leather will be ruined and wasted if you attempt to go thru some ill defined process attempting to stop leather from doing something that it will do anyway. Even junk grade vegetable tanned leather makes an acceptable belt . . . But then again I've only made and sold several hundred . . . over the course of 20+ years . . . so what do I know? And not one ever came back because it stretched. May God bless, Dwight
Looks more like a nut cracker . . . can't figure how one would cut leather on that. May God bless, Dwight
- 10 replies
how to cut a LONG strap for a tracking line?
Dwight replied to SoMoKraftworks's topic in How Do I Do That?
And when you go to figure out how big a piece you will need . . . remember that if the strap were 1 inch wide . . . in one square foot . . . you would have 12 feet of 1 inch strap. Since you are cutting it at 1/2 inch . . . that doubles the strap length to 24 feet . . . if you want a 30 ft strap . . . you can start out with 1 1/4 square feet. Cutting it in a square piece is impossible so you at least have to look at a circle as the first possibility . . . and you don't want to have the last few inches sorely bent . . . Cutting an 18 inch circle . . . using a strap cutter set at 1/2 inch . . . you would wind up with a 30 ft strap . . . and roughly an 8 inch diameter piece left over in the middle. Again . . . soak it . . . stretch it . . . let it dry . . . viola . . . STRAP . . . May God bless, Dwight (provided I did my math correctly . . . ) -
I've got a 36 by 60 mat on the same sized table . . . the mat is about 15 yrs old . . . I finally cut a couple small holes in it . . . so I had to pull it off the table and re-orient it 180 degrees. It self heals . . . mostly . . . and is wonderful for layout. Probably . . . and 79 yrs old . . . will just let this one out live me . . . bought off the floor at Joann Fabric May God bless, Dwight
Looking for a Blue Gun S&W mod 28
Dwight replied to Dwight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks, Paul . . . that dude's on order . . . May God bless, Dwight -
Don't laugh . . . but this works beautifully. Dampen the piece . . . on the hair side . . . lay it outside on a board in such a manner as it is like a solar panel . . . kinda angled so the sun hits it directly . . . and let the sunshine work on it. I have just about quit dying light tan . . . just give it the "suntan" look . . . did that for a young boy a few months back . . . he wore that belt prouder than if he had been given one by the Lone Ranger . . . And if you leave it out there for 4 or 5 days . . . it will get fairly dark. The key is to go out every now and then with a sponge . . . re-dampen the hair side of he object. Oh . . . and it works on cloudy days too . . . but only about 2/3 as well. But it is cheap . . . predictable . . . no VOC . . . May God bless, Dwight
Or you can download Adobe Photoshop Elements 2.0 off the net . . . you can resize them . . . crop them . . . re-orient them . . . and if you play with it long enough. . . . you will think you have found a long lost friend. I use it all the time . . . it's wonderful May God bless, Dwight
Cartridge Belts: Curved or Straight?
Dwight replied to ZARDOZ the GREAT's topic in How Do I Do That?
This is how I do the loops on a curved belt. The little tool that looks like a T is simply two pieces of 1/4 " plywood glued together at 90 degrees. On it . . . there is an arrow you can see jut to the right of the up and down bar. The distance from the bar to the arrow is 5/8 of an inch . . . the proper spacing for 44 and 45 cartridges. On the up and down bar are two lines that come out to the edge . . . they indicate the length the hole needs to be. I take an ink pen and draw a line from one line down to the next . . . while my arrow is pointing to the line I drew last. When I get done marking the lines . . . I get my slotting tool . . . and go to work. The line is made just the length of the slotting tool . . . so I put the top of the slot at the top of the line . . . bring the bottom down so it is centered . . . and I hammer a hole in the leather. Repeat until the proper number of holes are done. For modern six shooters I usually do 24 . . . for the old fashioned ones without a transfer bar . . . I do 25. The punch is made from a piece of 1/2 inch EMT conduit . . . smashed in a vise . . . and a 1/8 inch piece of flat stock steel forced into the hole to make both sides parallel . . . took it to a belt sander and sharpened the outside . . . took a round file and took off the burrs on the inside . . . have no idea of the number of cartridge holes this rascal has punched. But anyway . . . that is how I do it . . . never any complaints so far. May God bless, Dwight -
John Bianchi has for me the last word in gun holster making . . . seeing as how he more or less invented the fast draw concept . . . In his video he shows to cut the blanks out of one piece of leather . . . with the curve cut in it. He also shows that on I believe it was about a 42 inch belt . . . that the curve was a bow about 6 inches deep at the center . . . with the two ends of the belt being the ends of the bow. Those who make straight belts don't take into consideration that men generally wear their britches belted at their lower waist . . . and the gun belt goes below that on their hips. Many guys don't like the idea that they have a curve in the profile of their butt . . . but they do. They are a lot bigger around 3 inches below the belt . . . than they are at the belt. Hence . . . thee curved belt which makes up for the butt curve. Wide belts cut straight will be tighter at the bottom than the top . . . and if not cinched up . . . one good sneeze and the gunbelt is on the ground. Cut em straight if you want to . . . I've followed John's directions for over 20 years . . . never had but one come back . . . he ordered a 53 inch . . . it took a couple months to get it in the system and out to him . . . by that time he needed a 56 inch. Thankfully I was able to just barely change the tongue and he was happy. Never had one problem with them falling down. Your attitude may vary. May God bless, Dwight -
Contact Toledo sewing machines . . . they are one of our sponsors up there at the top . . . Bob is very knowledgeable . . . I get my cowboy bobbins from him and my Tippmann bobbins from Tipmann. The tipmann bobbins are smaller . . . but in a pinch, I can use them. His number is 866-362-7397 Give Bob the dimensions . . . I'd bet he'll have an answer for you. May God bless, Dwight
I had a beautiful old saddle brought to me to repair the sheep wool on it. It was just plain rotten . . . touching it at all with the least force and it came off in chunks. I took it all off . . . pulled out the old stitches (talking about a job) . . . then I cut new wool to go on it . . . glued it in place with weldwood contact cement . . . put the piece with the wool down . . . played with my Tippmann Boss machine . . . and was able to re-sew it using the original holes. Customer was a bit unhappy because he wanted it repaired . . . but came around when I explained it was the only way. May God bless, Dwight
I make key fobs from scraps left over from other work It is a timeless pattern made all over . . . well recognized . . . and you can do a lot in that little space There is one picture of a finished fob . . . and the image of our church I can put on others using a laser engraver. The laser engraver can also cut them out very quickly and efficiently. May God bless, Dwight
No . . . I had to buy mine extra . . . whoever (besides Temu) sells you the handle . . . should carry the dies as well. Ask for the ones for line 24 snaps. That is all they will fit too. I actually got mine from an Amish sewing store. Amish use a lot of snaps . . . and would probably grab up that one you showed. May God bless, Dwight
Etsy, Ebay, Amazon, Temu . . . they all have them. Be careful with Temu . . . theirs may be a knockoff . . . buy somewhere else. May God bless, Dwight
Hammering requires holding one piece of leather . . . sometimes two . . . a top snap part . . . a bottom snap part . . . a snap tool . . . a mallet . . . the snap anvil . . . over a small anvil or other very hard surface 5 or 6 items . . . having to be held with two hands. Sometimes it works . . . sometimes it doesn't. This tool works first time . . . every time. Simple as that. I don't have time to take a pair of side cutters . . . wiggle it between the snap part and the flesh side of the leather . . . cut off the bad snap . . . and then dig out the parts again . . . re install the snap . . . and hope the second time that it works . . . when using the exact same leather . . . it didn't the first time. May God bless, Dwight
Been using snaps for 20 + years . . . from Tandy . . . basically have never had any serious problems with them. I find when I do have a problem . . . it is not the snap . . . but the installation. If they are done right . . . they work. Best snaps in the world are not worth a dime if they are improperly installed. Take the time to learn to do it right . . . and you will be good. The picture enclosed is THE snap tool . . . almost impossible to not do it right . . . 35 bucks for the handle . . . 20 for the set of tools to go with it. You have to change tools from the male piece to the female piece . . . so I bought a second handle . . . don't have to waste time changing the tools. One of my better investments. May God bless, Dwight
Sandal mid and strap opinions
Dwight replied to okiwen's topic in Shoes, Boots, Sandals and Moccassins
First . . . I am not a sandal person . . . but I can be talked into something similar so to speak. PERSONAL OPINION: I will NOT buy a product like that with a stiff sole. The idea of them (for me) is comfortable . . . My favorite pair of footgear in the whole house is a pair of wool lined . . . suede . . . moccasins . . . and they have the very same leather on top as on the sole. OTOH . . . as I am sometimes an actor portraying a Roman Centurion from the days of Jesus . . . I wear a similar piece of footwear called a Caligae . . . which is a sandal made of three pieces of leather. The first is a piece of serious cowhide or horse hide or buffalo hide . . . it is the sole . . . maybe 14 or 16 oz if you can get it. The middle part (for the ones I make) are sewn to the sole . . . with the sole being heavily gouged for the stitches around the edge. This middle piece forms the pieces which go up around the foot . . . holding it on to the foot. The third piece is simply an inner sole . . . cut to fit inside the middle piece . . . it is the piece of leather on which the foot rests. There are no heels on this footwear . . . flat soles . . . no arch support . . . nothing but leather and the stitching. And yes . . . they are very comfortable. Spend an hour or so on youtube . . . use Caligae as your search word. They often show the sole part as being several layers of leather . . . this accomodates the hob nails they used. You don't want the hob nails . . . just one or at the most two layers for the soles. May God bless, Dwight -
First off . . . you are not Ford or General Motors . . . so the wide social presence is seriously not needed at the moment. But you can put up a very simple website for about 150 bucks the first year . . . show really good photographs of your product line . . . and invite questions. Don't attempt to do a JC Penny web site . . . remember the old axiom about keeping it simple. Second . . . by your own admission . . . you have little experience . . . and what you do have is not popular. You need to develop a style and product line first . . . something that YOU can do . . . that you are comfortable with . . . and truly like to do. For me . . . I will never develop a line of men's wallets . . . but belts and gun holsters are my forte. You also have a community . . . where you live . . . there are VFW . . . ladies aide's . . . other "gathering" places. There are also weekend community yard sales . . . etc. You are looking for a place where people congregate and have bulletin boards . . . or have walk thru customers. Post pictures on their bulletin boards with your name and phone number. MAKE SURE TO GET THEIR PERMISSION TO DO SO FIRST. I have some friends who run a gun shop . . . anyone asking about a gun holster . . . gets my phone number . . . and the usually become another customer. What you are needing is LOCAL traffic that will give you instant opinions on your product . . . good / bad / OK / bad stitching / wrong color / etc. . . . The necessary word is INSTANT . . . something a "social presence" will not give you. Selling on Etsy may generate sales . . . but feeback is long coming . . . and you cannot have a personal conversation about the product . . . like you would have at a community yard sale. You also can make a couple dozen items of what you want to make . . . and see WHAT sells . . . toss the stuff you have carried in your inventory to 6 months worth of sales . . . and it is still there. Get new stuff. It took me a half dozen weekend sales . . . I drove 75 miles one way to each . . . but it made all the difference in the world for my product line. Also . . . try to find something you have a natural affinity for. There are all too many "leather workers" on the interrnet . . . who have to have someone else make a pattern for them for every belt . . . every purse . . . every holster . . . every sheath . . . In short . . . they have no ability to imagine and define . . . do this first . . . then that . . . then that . . . etc . . . and come up with a completed product that you are proud of . . . and your customer is happy with. They could produce good looking leather Walmart bags . . . and not much more. Last of all . . . most important of all . . . don't be afraid of Ebay . . . it is a real good place to "try out" your idea of a product. If it does not sell in 90 days . . . kill the listing and try something else. And while you are on Ebay . . . figure out the average price to ship your product to your next door neighbor . . . and the person living in the most distant state. Add that to your asking price . . . and advertise "Free Shipping". Don't advertise 100% satisfaction guaranteed . . . but when you get even a half reasonable complaint . . . have them ship it back to you at your expense . . . and when it gets there . . . replace it with the complaint addressed. You will build customer satisfaction that you cannot build any other way. Make that Ebay listing for 1 single product . . . don't aggravate the problem with check boxes for size . . . shape . . . length . . . color . . . etc. If it is a 36 inch man's belt with rosebud stamping . . . put a really good picture of it on there . . . and advertise it as such. You can then use the same picture for one you advertise as 38 inch long . . . another at 40 . . . one at 42 . . . etc. That also prevents mistakes on size . . . color . . . etc. But last of all . . . have fun as you start out. Don't start in a product line that causes you grief making it. If you are not having fun doing it . . . find something else to do . May God bless, Dwight
I have one that is 20 years old . . . have no idea how many things I made on it . . . paid the 1K for it when I got it. I would consider it a stingy insult from you if you offered me 500 for it. I would probably take 800 . . . but there would be extenuating circumstances for otherwise. May God bless, Dwight
Maybe not . . . safety and mag disconnect are always on left side . . . can be on the other side but are not always. May God bless, Dwight
I gave up on that idea years ago . . . I use a glass jelly jar . . . unscrew the lid . . . use it . . . screw the lid back on . . . just make sure you don't get any glue around the mouth of the bottle. I use throw away "acid brushes" . . . little metal handled things from Harbor Freight . . . about a nickel apiece or so . . . start out the day with one . . . usually pitch it before starting out the next day . . . but sometimes it is still useable . . . especially if I did something late that last evening. Anyway . . . that's my system . . . and I have to toss a little thinner in it every now and then. May God bless, Dwight
You simply take the one side of the last piece of the puzzle . . . sand it with some 80 grit sand paper . . . and Weldwood contact cement it where it belongs. OR . . . put a concho on top of the cup . . . threaded into the last piece of the puzzle . . . hidden in it's lodging place. May God bless, Dwight
