Dwight
Everything posted by Dwight
  1. THAT is one good looking belt . . . would be proud to wear one like that. I'd also love to have the pattern . . . it would definitely make a "distinguished" looking pair of suspenders . . . May God bless, Dwight
  2. Take a look at this one https://pragmaticartisan.myshopify.com/collections/animal/products/quail-1119-engraved-metal-hand-stamp May God bless, Dwight
  3. If you don't find one to suit you . . . I've been successful getting some very much customized stamps from a couple of vendors in China . . . they do solid brass ones . . . and while I'd a liked to do it here the states . . . nobody here in the states would make them . . . They're on Ebay . . . but you need a picture of what you want . . . as well as the dimensions. May God bless, Dwight
  4. I'd like to see a bunch of pictures of it May God bless, Dwight
  5. Did someone get up from the wrong side of the bed today?? May God bless, Dwight
  6. Dwight
    Face warmer
    Ain't he one of them Star Wars guys . . . black cape and such . . . May God bless, Dwight
  7. But at the same time . . . if it is wax . . . water may not make it do anything . . . but heat will . . . I'd be very careful . . . but with a heat gun and some serious care . . . I'd bet you can mold it. That would be double if you had a top and bottom mold you could squeeze it into . . . after taking it out of a pan of reasonably hot water. May God bless, Dwight
  8. With so many lasers out there . . . you would be hard put to find one just like it . . . But for those . . . I usually make a pancake . . . mold it so that the inside piece is almost flat . . . and add a piece of light cardboard around the laser . . . as you do not want the holster to turn the laser on . . . draining the battery . . . and pointing a dot on the floor beside you. They're not fun. May God bless, Dwight
  9. Welcome Loren . . . Loren . . . not everyone can view images posted as you did them. Use Adobe Photoshop or some photo program . . . cut them to about 1000 by 1000 size and no more than 500 kb for the best results here. Load them into a "Leather photos" file on your computer . . . save them all as *.jpg . . . go down to the bottom where it says choose files . . . click that . . . it'll take you to your storage . . . select the picture(s) and we can see them here. May God bless, Dwight
  10. If you are dead set on using snaps . . . there are "one way" snaps available. You would put them on so that you would have to separate the two pieces of leather starting at the buckle and working your way back. Pulling on the end would not allow the snap to come undone . . . and while I very seldom use them . . . I do have them . . . and they do work. May God bless, Dwight
  11. You'll need a better definition than that . . . full quiver . . . cheek wrap for the butt stock . . . handguard wrap for foend??? May God bless, Dwight
  12. Belts can get pressure applied to them . . . and snaps can come apart. I quit using snaps on belts some 20 years ago . . . I only use Chicago Screws now With a dab of blue locktite or fingernail polish . . . they do not come loose. Only way I go now. May God bless, Dwight
  13. It's only illegal if the law finds out about it . . . Not encouraging illegal actions . . . Just stating the fact . . . May God bless, Dwight
  14. If you find out the answers . . . let me know . . . May God bless, Dwight
  15. My favorite peeve is buying a beautiful piece of leather (regardless of where) . . . grabbing it later for a project . . . and finding a "hard" place in it . . . just exactly in THE wrong place for the project I've already started cutting for. I work around it . . . but it burns my gizzard. May God bless, Dwight
  16. That's it . . . have run May God bless, Dwight
  17. Take em one at a time . . . yes . . . everyone will have dye rub off. It is the dried physical pieces of the dye that did not penetrate. Rubbing with an old wash cloth or tee shirt or flannel shirt is how I get rid of it. USMC black is one I will not use . . . it is no more "black" than the pro dye . . . but it will rub off till the cows come home from the back pasture. I use resolene on the backside . . . sometimes I will use a glass slicker with a tad of water . . . then resolene . . . but I try not to buy leather that forces me to do that. I generally line a western gun belt . . . all of my CCW belts . . . all of my western holsters . . . and by lining . . .I make the product out of two pieces of the same hide . . . I don't use other leathers and I don't use two different thicknesses . . . but it is just MY habit . No . . . I do not special mix. Have never found a "need" to do it. The shades I offer . . . folks find one they like . . . all are Feibings Pro Oil dyes . . . mixed 50/50 with Feibings thinner. Hope this helps . . . holler if I can do more. May God bless, Dwight
  18. Yeah . . . that one is simple Cut . . . tool . . stamp . . . dye ASSEMBLE AND STITCH Finish . . . Doing it in that order . . . you will be able to dampen . . . not slurpy wet . . . just dampen and bend it around a form and allow it to dry there. Stitching two pieces together and then bending . . . will 99 times out of 100 cause wrinkles on the inside and you will usually wind up with a shape you can live with . . . but it may not be "just what you wanted". Forming . . . mating to gether after formed . . . then glued and stitched will give you THE SHAPE you wanted. May God bless, Dwight
  19. Chiefjason as a good process . . . and it'll work fine . . . On something like you are doing . . . because I have a sewing machine that will do it . . . because of the heavy duty curves . . . I would wet the quiver body . . . wrap it around a form that will give it pretty darn near the final shape you need . . . As it is drying I would wet the outside pieces . . . and form them to the outside shape of the quiver . . . and set the whole magillicutty off somewhere to dry I would then contact cement the outside pieces to the quiver . . . then head for my Cowboy sewing machine . . . take off my flat table . . . and sew the patches on. Then just finish it all up. But either way will work . . . my way is just a tad harder. . . but when you get the patches on . . . there will be no tendency for the quiver to want to go back to laying flat. Makes the final sewing a whole bunch easier. May God bless, Dwight
  20. The Tippmann machine is very easy to use . . . https://www.tippmannindustrial.com/content/Manual-Boss-5-9-14.pdf will allow you to download the instruction manual. Just click it . . . check your "download" file . . . double click the manual there . . . and you're good to go. May God bless, Dwight
  21. I've had a Boss since basically 2000 . . . could not guess how much I've sewn on it . . . belts, holsters, purses, knife sheaths . . . etc. The others may have a good warranty . . . it will not be better than Tippmann . . . from my experience. I live close enough to be there in a couple hours . . . for less money than I could ship it . . . so for the few times I've had trouble . . . I've loaded it up and taken it there. Ben or one of the others cleans off a work bench . . . and go to work on it . . . I bring it home . . . and go back to work . . . and have never been charged. Hard to beat . . . especially since they did have to replace a part here or there. May God bless, Dwight
  22. I've never really found any other than you need to touch it up now and then. May God bless, Dwight
  23. Good job . . . I had a 365 for a while . . . sold it to my son . . . never ever could get used to it . . . been a 1911 guy since 1966 . . . just cannot get the hands to say "Alright . . . this one is OK" They always put up a fuss and ask where the gun is. Ahhhh . . . such is life. May God bless, Dwight
  24. That's basically 7/8 oz . . . my usual holster making material . . . I double it . . . contact cement the two together . . . and mold the holster from that. I also make a lot of other stuff out of it . . . probably my favorite thickness . . . makes great CCW or cartridge belts . . . Vacuum forming rig helps out. May God bless, Dwight
  25. ST leather in St Louis . . . or Tandy Leather . . . both sell on line . . . https://stleather.com/ https://tandyleather.com/?utm_source=GMB&utm_medium=Yext&y_source=1_MjM3NjIzNTItNzE1LWxvY2F0aW9uLndlYnNpdGU%3D I buy from Tandy . . . have no complaints on the stuff I've gotten from them. May God bless, Dwight
