Dwight
Everything posted by Dwight
  1. I like it . . . good idea . . . but my boresight is bright red . . . I also have a backstop made of railroad ties . . . red shows up on it real well. But if I were you . . . I just might refine that thing a bit . . . Put it on etsy . . . I'd just about wager you'll sell a few of them. May God bless, Dwight
  2. I'm no "all leather" professional / professer / know it all. But if you are using veg tan . . . belts . . . holsters . . . knife sheaths and the like . . . Make the project with the exception of some snaps if you can put them on later . . . or buckles . . . etc. Take a bristle brush and give the project a light coat . . . hair side only . . . of genuine neatsfoot oil. Let it dry 24 hours. Then dip / dunk dye your project with feibings pro oil dye . . . diluted 50/50 with feibings reducer. You should like the result . . . I generally always do . . . I finish it with Resolene after a good buffing . . . May God bless, Dwight
  3. Well . . . if you have a picture of one . . . it might go a long long way towards the understanding. I use 20 penny spikes for woodwork . . . railroad spikes on my forge . . . but do not spike my hair. Wouldn't make any difference any way . . . but none use a rivet . . . or screws. May God bless, Dwight
  4. Some years ago I needed a couple of small stamps . . . wanted brass . . . Went on Ebay . . . wound up buying from a Hong Kong dealer for one . . . mainland China for the other . . . would rather have used US . . . but could not find anything here. Their detail is absolutely excellent . . . I sent them a picture . . . one had to have some detail removed by me . . . but I was seriously happy with both that I still have and have used for years. May God bless, Dwight
  5. I did one . . . once . . . don't wear it often as it is kinda heavy on the noggin May God bless, Dwight
  6. Take your tools to a auto parts store . . . tell em you want some black rubber tubing . . . Check the size with your tools . . . couple feet of it will last you almost forever. I have a bunch of tools with rubber on the handles . . . whole lot easier for 79 yr old hands to handle May God bless, Dwight
  7. From what I could see . . . it all looked like it was there . . . only thing we could not see . . . the back was not shown . . . with the cover on it. Need to see the back with the cover removed. The real deal though . . . have him show you a piece of stitched leather . . . preferably two pieces of 8 oz glued together . . . flesh to flesh . . . sewn with 277 or 307 nylon thread. That should tell the tale. I would suggest that possibly the person bought it and never really used it much . . . maybe didn't even ever learn how to use it. The little plate and wire hook for the thread spool is missing . . . couple of inexpensive parts . . . but you don't sew without them. Plus he has the original shoe on it . . . one that for belt and holster and wallet making . . . is useless. Just a quick opinion . . . but google "image: tippmann boss" and you'll see the backside upper left where the thread goes . . . along with a wire that takes it up in the air and allows it to come down vertical to the machine. May God bless, Dwight
  8. What he said is right on the money . . . no compound for me either . . . I saw the formula one time . . . don't recall the ingredients . . . but I voted against it. May God bless, Dwight
  9. If you want to follow the advice of John Bianchi . . . one of THE top holster makers of the last 50 years . . . When you cut the piece for the outside of the holster . . . turn your pattern over and cut another piece . . . that is the inside liner. Been doing that for over 20 years . . . never been a problem yet . . . and I don't have to stock two different leathers. May God bless, Dwight
  10. I've been lately able to get the thickness I like for belts . . . but when I can't . . . my little splitter I bought from Tandy some 10 or 12 yrs ago . . . is the go to route. I cut the blank long enough that I've got the ability to grab the end with vise grips . . . and I run the whole thing thru the splitter . . . gets as good an edge as any of the more expensive veg tan you might buy. The only thing is . . . ya gotta keep it sharp . . . and you need to grease it after using it . . . then wipe it down and run a 6 inch piece of scrap thru it before your belt blank . . . to take off any grease you missed. Slicking and sanding works . . . but THIS is so much better and easier. You will have to learn how to sharpen it and how to strop it though May God bless, Dwight
  11. Here is what I did . . . simple . . . quick . . . no real big engineering involved. I sit down . . . each side piece goes under my leg . . . the middle piece comes straight up . . . stick in the piece . . . tighten the wing nut . . . stitch to your little hearts content. May God bless, Dwight
  12. Can you take a micrometer and gently check the diameter of the thread ?? Looks awful big to me . . . but that may be a perception problem as I have nothing to measure it against. May God bless, Dwight
  13. OK . . . did you laser that bird on first? Looks good either way . . . but I'm just a wondering. May God bless, Dwight
  14. I've done a ton of holsters in my 20+ years of leather working. Never had anyone want one for a derringer. This is a double barreled 410 / 45LC . . . over and under . . . double barrel. If you've done one . . . or have a pattern . . . I'd love to see your design . . . because basically . . . I'm stumped May God bless, Dwight
  15. I did this successfully . . . ONCE . . . and that was several years ago . . . and it was for a personal item . . . for me. I took (I believe) . . . saddle tan dye . . . thinned it 50/50 like I always do . . . to make the saddle tan correctly first. I then took the black dye Feibings oil base black . . . thinned it 50/50 with thinner . . . THEN . . . I started adding the black to the saddle tan . . . then do a test piece . . . until I got the shade I wanted. Again . . . only did it once . . . was happy with the results . . . which was a medium grey color. The tan / brown disappeared once I got where I wanted with the grey. BUT . . . I mistakenly left the holster / gunbelt . . . hanging where excessive sunlight could hit it . . . and it bleached most of the black out. I'm still happy with it . . . but I did like the original grey I had better. May God bless, Dwight
  16. Saddle tan . . . my favorite color for any pretty stamping. May God bless, Dwight
  17. From one transplanted (partial) Frenchman to another . . . welcome and glad to have you aboard. I am baasically a belt, holster, knife sheath, and gun case maker. I've done a bit of saddle repair . . . and a few spur straps . . . as well as chaps and chinks . . . but it is only an extracurricular activity for me. Most of my work follows the plain / practical idea . . . but if someone wants something fancied up a bit . . . I'll usually comply with his / her request. May God bless, Dwight
  18. Thank you . . . made my day . . . May God bless, Dwight
  19. I've never had anyone ask me to make a glock holster in anything but basic black . . . Just my experience . . . May God bless, Dwight
  20. Looks good from here . . . May God bless, Dwight
  21. Thanks guys . . . May God bless, Dwight
  22. Just one quick note . . . when you go for example to Tandy's or other leather shops . . . the cheap stuff will be Neatsfoot oil "compound" . . . which is a conglomerate of oils. Buy the pure neatsfoot oil . . . it's a bit more expensive . . . but it's the good stuff . . . May God bless, Dwight
  23. Got a friend who needs a metal stamp made . . . The circle diameter needs to be 5/8 (maybe a tad on the plus side) He wants to stamp walking sticks with it. Anyone out there up for a job like this?? May God bless, Dwight
  24. Good way to go is find something you need to do . . . and do it . . . post pictures . . . ask for comments. Generally speaking most folks here are gentle . . . but honest in their admiration and / or criticism . . . The old saying goes something like . . . "most of our good decisions come from experience . . . and experience comes from bad decisions" My first holster I made . . . no one on here has or will see . . . it was that ugly . . . but looking at others . . . I was able to see what I did wrong. It's at the bottom of my holster box . . . rarely eve sees daylight. Jump in . . . join the fray . . . and "glad to have you" May God bless, Dwight
  25. A few years back I was having trouble with my light tan dyes . . . not being even . . . especially saddle tan. I don't recall the impetus that moved me to try oiling first . . . I did . . . have NEVER had another problem like that since. I use a cheap pig hair brush from Harbor freight . . . put on a very light coat . . . just enough to make it look wet . . . Let it "dry" for 24 hours . . . the dye goes on perfect . . . every time. I don't always oil for black . . . it depends on the leather . . . But if it is anything other than black . . . it ALWAYS gets oiled first. That is for all my holsters . . . belts . . . sheaths . . . and gun cases . . . which is mainly what I do. May God bless, Dwight
