Everything posted by JoeSnuffie
From the album: Leather Things
This is the inside. -
One side stitched and the other side glued. The gap in the middle was folded up and stitched. After stitching the other side I'll fold the liner up and stitch the sides. -
I got a little more time and did some stitching. This is prepped to stitch the bottom of the liner / slots to the shell. -
It's been a while but I'm finally able to get back on the bench and take some requests. This is for a merchant marine friend who requested 'something nautical and rustic'. I've got a couple accent pieces I'm wanting to add and hopefully I'll get some time to finish it up this evening. I guess I need to bend and squeeze it a little, too. I was thinking I might put some wear on the shell before I seal it. I think it would make the compass rose really stand out. -
I use a mixture of water and mop n glow to seal stiffer leathers like belts. There is usually a little rub off when I apply with a cloth or sponge. In the past few months I've been airbrushing the sealer on and buffing after it dries, with hardly any dye rubbing off. After the sealer dries there isn't much rob off unless it gets wet again. My expensive cowboy boots and my favorite comfy shoes still have some dye rub off when they get wet. For the rivets, make sure the posts are the right length. I will often cut them to the right length if I notice any drift. I have a crimping tool that allows me to cut and reform the end of the post easily. When it's the right length, there is no drift.
What Next?
JoeSnuffie replied to stelhrse's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I use neatsfoot on all veg tanned belts. I didn't on two early belts I made myself and both started to crack where my holster sits because of the additional stress. This hasn't happened on any belt treated with neatsfoot. I haven't treated any belts made with harness leather because they're already oily and waxy and I haven't had any issues with them. Someone who makes more belts than me may have a better answer. -
Kilt Belt
JoeSnuffie replied to AndyL1's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That's pretty manly. Great job. -
Robot Wallet
JoeSnuffie replied to JoeSnuffie's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
No airbrush, I used a stencil and weak vinegaroon. I used a cotton swab to dab it on, barely damp so there's no bleeding especially around the edges of the stencil. It takes a few passes but if you're careful, you have a wonderfully crisp image. I did it this way to prevent any rub off or bleeding because I knew I'd be rubbing it pretty rough to give it a distressed look. It also has a really cool raised effect, I guess caused by the chemical reaction. You can't see it but the inside of the shell has two robots as well. -
I do the same thing barehandcustoms does with sponges. You pay a couple dollars for a large sponge and turn it onto a bag full of tiny sponges. I try to cut them into about 1x1x2 inch pieces.
She actually came to my man room and handed them to me. Honest! I swear they were freely given. Each one is about 15 feet long so there is a lot to work with.
Sorry, I've been out for a couple weeks. Camerius, that is the seller I have been using. I've ordered 3 times now and am very pleased with my orders. JohnD,I've never used Tiger Thread but someone who has used both mentioned once that the Chinese thread stretches more and they wouldn't use it for things like horse tack where a little stretch would be a big problem. I'm using it for wallets, small bags, sheaths, bracelets, etc., and it's perfect for me.
- 88 replies
- braided polyester thread
- tiger thread
(and 1 more)
I use Weldwood contact cement and once applied properly, fabric or another piece of leather is stuck. You need to make sure the flesh side is smooth, though, without a lot of fuzz. Once cured, pulling the pieces apart, more often than not, will tear either the fabric or the leather. It's often a bond that's stronger than the material you're gluing together. There are probably plenty of ways to lay out the fabric lining and taking apart commercial wallets will give you some ideas. I make taco shell like pieces and glue them in place for each pocket. You glue one side above and one below the slot and it hangs down. I glue the 'back' of the pocket first - this is the piece that glues above the cut. After this cures I glue the 'front' of the pocket - this is the piece that glues below the cut and glues on top of the 'back' piece on the slot below it. I do it this way because a cheap Chinese wallet I once bought was assembled in a similar manner. Make sure you use a fabric not prone to fraying. Suit lining material can be found that's really classy looking and I also use sari's that my wife donated to my hobby. She wears these in weddings and never wears them again. This is enough fabric to make thousands of wallet liners I'm sure.
How Can I Reduce Thickness Of Leather Without A Splitter?
JoeSnuffie replied to thekid77's topic in How Do I Do That?
How large a piece do you need to split? I do long strips of soft leather with a belt sander. The safety skiver works and I've used it on wallet shells successfully, but my hands were sore when I finished. I've had a lot better luck with a round knife but I just got a splitter and I won't be wearing out my hands like that again. -
Macbook Air Case
JoeSnuffie replied to Stitch Dex Holsters's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I really like how you did the buckle. -
Black Snaps That Don't Turn Copper?
JoeSnuffie replied to jtron5's topic in Leatherwork Conversation
I'm not aware of any product like this. All snaps I came across in the Army needed to be blackened from tint to time and all of my holsters with regular use have wear on the snaps as well. -
Bifolds And Long Wallets
JoeSnuffie replied to KGV's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice. I prefer a thicker thread like you used. For wallets I use 7.5 SPI with .8mm flat braided thread. The only thing I'd change is the thread color. I'd use a slightly off white color. Bright white makes me nervous, like I'm going to get something dirty on it and ruin the look. But that's just personal preference and if you and the person paying for it like it, then it's the perfect color. I've used many color combinations that I think are bad but the person with the cash overrides my opinions.- 19 replies
- chromexcel
- horween
(and 4 more)
75% of my cuts are straight and the curved cuts I do are pretty mild, consisting of bag and case flaps and and the curve in wallet pockets. I don't think I'd be able to manage sharp curves with it but I'm not a pro and don't have experience.
This is a pretty common style but I've only seen shiny, decorative pieces. I often see then called 'Fold Over' clasp or buckle. I make a lot of bracelets and see these a lot, though I've never used one. https://www.google.com/search?q=fold+over+clasp
I get a bit of a craft glue smell from it. I wonder if there's a study that tells what our impressions of the smell reveals about us. Also, I haven't used super shene as a finish in a few years. However, I use it at least one a week to reinforce the hole for a Sam Browne button. Makes it snap it pretty securely and lasts a long time, more than a year on a daily use bracelet.
I've been using 0.8mm from China that's similar to Tiger. Less than $10 shipped per 250m spool and discounts for buying more. It just takes a couple weeks for delivery.
- 88 replies
- tiger thread
(and 1 more)
Leather Splitter Sharpening Help Video
JoeSnuffie replied to NewYorkerInSydney's topic in How Do I Do That?
I just got my splitter and have only had to sharpen it twice. I haven't had to hone it yet but if you do, just be careful to keep the same angle if you can. I just drag it over my strop a few times until it easily cuts hair again. Unless you hit it with a hammer the blade can be made sharp. I treat the blade like I do my straight razor. -
I'm certainly no pro but this thing is perfect for me. It's the right length, width and the handle fits my hand. Might not be pretty, but it does the job well.
Since I can't afford to buy 15 sides of chrome and oil tanned leather, I buy scraps that yield 3 - 6 wallet shells each that only cost me $2 - $3 sqft. They're often too thick and I've been skiving them down to a good thickness by hand, and that isn't fun for anyone. I bought the Cowboy splitter knowing I'd have to tweak it, but I wasn't expecting it to be so easy. The first modification was a super high tech tension device that's fully adjustable and allows me to grip the leather with both hands. It's a bungee cord wrapped around the handle and attached to the bench with a screw. To tighten it, I just give it another wrap around the handle and I can pull it towards me to release the pressure and insert the leather. The second modification was brass shims that allow the steel roller to move a little more freely. I made the shims from 2 pieces of .45 Colt brass (seriously, is there any better way to shim a 'Cowboy' splitter?) The biggest problem when splitting the oil and chrome tanned leather is the grain side. It sticks to the roller and the roller shaft isn't free spinning. In less than a minute I had split about 1mm off of a 9x4 inch wallet shell. The picture shows the 'before' leather on top of the 'after' leather with the portion that was split off resting next to the 'before' piece.
I make long strips for wallet ID window borders by running calf skin over a belt sander with 120 grit belts. It goes pretty fast and it's easy to get a nice even thickness. I'm making them around 1/3 mm. The company where I buy my calf splits it to about .75mm and it's very consistent. I believe he uses the band saw style splitter.
