CowboyBob
Contributing Member-
Everything posted by CowboyBob
Hello Kate, I remeber you bought some parts from me a couple of yrs ago f/your Landis. I get a few calls a year for a shuttle for these #1 & they are very hard to find,I know an Amishman that has one once in a while & can check w/him & let you know. Bob
New here with 29K vs Mach1 questions
CowboyBob replied to olroper99's topic in Leather Sewing Machines
Katy, When I was talking to Russ about a roller foot I was refering to the Mach1 which has the feed dog on the bottom & will leave marks on most leather.I'm not bashing the 29-4 as they are great little machines & very handy,we sell quite a few of them every year,I also know about loosening the foot tension but you have to be careful as it's a fine line to keep it where it'll still feed & not skip stitches & not mark & if you sew thicker it will need to be tightened alittle more.There's the fact that some leather have a harder finish & are more tolerant of the teeth on the foot. Bob Kovar -
Art, your correct it's a 144w,at least it has reverse. Bob
Sam, Your Welcome,We are a Consew Dealer & have alomst all the parts in stock for it too,along w/needles & thread. So let me know if you have anymore questions. Bob Kovar
Yes,it'll handle thin leather like you want to sew,there is some things available for it like a nylon foot & a roller foot that will help feed the leather through,we also have leather point needles & it will use#46 & #69 thread. Let me know if you have anymore questions as we are a Consew Dealer. Bob Kovar
Wiz, I have some needles in sizes#2,3 & 4 @ a good price. Let me know if you need any. Thanks, Bob Kovar
We sell a D.C. Servo motor w/a builtin reducer that is alot easier to put on then a separate reducer & servo motor & lower price too!(it fastens in the same holes as a clutchmotor) .A few people on the board have bought them & can't believe how slow they are,one stitch @ a time if you want. Bob Kovar -
Donnie, The price isn't to bad & they are a handy machine to have around but they are not good for sewing what you want as they won't take heavy enough thread & sew as thick as what you need + they have a top feed which means the foot has teeth on the bottomside that pulls the leather & it'll leave some nasty teeth marks on the top of what your sewing. Hope this helps. Bob Kovar
There's 2 screws on the bobbincase & it's the one on the left that adjusts the tension. Bob
Leighton's is correct about the small bobbins on the 29's most of them will only sew to around 8mm use 138 thread max & alot of tack uses 207. We sell the same machine as a Mach1 they will use up to 346 thread the bobbin is probably 10x larger too & will sew to 10 mm or more.They have a feed dog that can mark the bottom but it'll probably look better than the marks a 29 would leave on top. We also have a roller foot available that helps the feeding on this machine. Let me know if you have anymore questions. Bob Kovar -
New member needs identification
CowboyBob replied to Rolling Stone's topic in Leather Sewing Machines
Singer never made a big single thread chainstitch like this machine,I'd say look to Puritan for more info. Bob -
Hello, We used to rebuild them yrs ago to sew to over 3/4" & also would put reverse in them too. You should be able to sew an easy 1/2"+ with it,We still have alot of parts so let me know what you need. Thanks, Bob Kovar Toledo Ind Sewing Machine Sales 1-866-362-7397
I don't know what brand machine that is but can tell you it's a single needle chainstitch used in collar making,luggage making.It's alot like a Puritan. I probably have needles & awls for it. -
If it has the long beak type of shuttle they aren't being made anymore,but I think I know where I can get some used ones if needed.Some machine might have a round bobbin. Bob
The thread needs to be between the 2-discs that why it gets tight,how tight it is supposed to be is best checked by test sewing,a few weeks down the road you'll be better able to test tension by pulling. And the tope tension does need to be tighter than the bobbin. HTH Bob
Singer 281-3 for sewing holsters?
CowboyBob replied to dailywarren's topic in Leather Sewing Machines
I'll have to agree w?Art,It's a high speed machine that can be slowed down for more$$ & then I doubt if it would handle making holsters.We do have some customers using them for chaps & we do stock the 135x8 needles w/a leather point.The 281's will use #46,69 & 92 nylon thread. Bob -
This Singer 29-4 has been completely disasembled,cleaned,repainted & put back together with any new parts that were needed & it sews like NEW. It will come with 1-thread wire, 2-packs of needles,5-bobbins & operators manual.The price w/stand as pictured is $650.00 picked up in Toledo,Oh. We will crate for shipping f/$25.00,and you'll have to pay the shipping charges. We do have discounts with alot of trucking companies. Bob Kovar Toledo Industrial Sewing Machine Sales 1-866-362-7397
Dave, Yes,this machine has a spring loaded foot,the outside swings back with the feed dog.This machine will use up tp 346 nylon w/a #26 needle,277 w/a#25 or 207 w/a #23 we always changed them to a 135x16 just alittle shorter needle that is very easy to get. Bob
I'll bet your right when he got the Adler he found it it would sew alittle heavier & smoother too. Just thought I'd mention we stock thread,needles & anything else you might need fot it. Let me know if you have anymore questions. Bob
I've sold a few of these models over the years & yes they will sew to maybe 5/8" or so thickness,they have a needlefeed,there's not much available for feet other than buy a standard foot & modify it buy cutting off one side or the other.It will take #277 thread easy & use the Schmetz 794S leather point needles that we stock. Bob
Info. about a Singer 17-41 cylinder sewing machine
CowboyBob replied to jmpete's topic in Leather Sewing Machines
I should mention that I can't find shuttles for the 17class machines,they are alittle smaller diameter than standard. Art, I think your right about the 17-41 having rev I thought I had one here & was going to check the # but can't find it.I do have a 11-36 that feeds up & down the arm,reverse parts on it look just like the 17's do Bob -
Well since you can't get gears for the 29k51 I'd say keep the Adler, parts are much easier to get & some Singers parts will fit saving some $$ since Adlers parts are very expensive. Bob
Art, I think your getting the little 17 class mixed up w/a 11 class,the 17's will sew maybe 1/4" w/69or 92 thread. Bob -
I need input about Adler 204-374 FB machines
CowboyBob replied to Wizcrafts's topic in Leather Sewing Machines
Bob, I consider myself lucky to sell one HD Flatbed like this a year.So I'm not real interested in it,maybe you can try ebay. Sounds like that Union is missed,they are pretty good machines as long as you know how to adjust them.
