shoepatcher
Everything posted by shoepatcher
  1. great price. Efka did not manufacture to many 110/120 volt motors. glenn
  2. can the needle clamp be rotated 180 degrees? glenn
  3. Check the Consew 744 and the Juki LG-158. One or both should be compatible with the Singer 145. glenn
  4. yes A white one which is the later model. Is it motor single phase 220 or 3 phase? It has all the toys!! glenn
  5. Durkopp Adler had 2 different screws for the tension spring and 2 different for the attaching screw depending on serial number of the machine. Seems like they made a running change sometime in production. Here are the numbers via the parts list I have. tension screw #992-10-746-8 or #992-02-351-0 attaching screw #992-12-255-8 or#992-02-350-0 Call Durkopp Adler Pfaff in Georgia and order from them. They take credit cards. glenn
  6. The 767-FA-373 was Durkopp Adler's top medium duty flat bed walking foot machine until they came out with the 867. Both were the best machine made in their class. Not cheap new. The one you are looking at has thread trimmers and probably most of the toys, i.e. auto foot lift, back tack speed control, high lift knee pedal, etc. I have a 767-FA-573 which is the XXL bobbin. Great machine. Smooth as hell. more powerful than the Tecsew. You need air to run the functions unless it has been stripped. Very smooth. 1/2" lift under the foot minimum. Max. stitch length is 6-10mm depending on its age. Let's see pics if we can. glenn
  7. very good machine!!! glenn
  8. Very nice C. Great job on the rebuild! Electrolysis tank? No name on the press? glenn
  9. System 88 shank dia. 1.9mm, 332 LG shank dia. 2.0mm glenn
  10. You can actually run #207 on top on these machines. It will sew 10 mm depending on the hardness of the leather or material. I have sewn 10 mm items on them before. Again, this was not saddle leather. glenn
  11. contact Puritan Industries in Connecticut. They are still in business 1-860-693-079 glenn
  12. You get the motor from Cobra? If so, call Steve. glenn
  13. C, Interested to see how you progress goes on this machine. I have not started on mine yet. Adler's to do first. Take lots of pics. glenn I
  14. C, Interested to see how you progress goes on this machine. I have not started on mine yet. Adler's to do first. Take lots of pics. glenn I
  15. Contact Ryan Neel at Neels Saddlery. They are the US distributor for Cowboy machines. he should have copies of the manuals that he can email you. Looks a lot like the Cowboy 2500 glenn
  16. What color is he machine? I can give you a rough age based on the color. If you are looking for the knurl screw that you can lock the butterfly from turning, it is called a stop screw. I need the color of the machine to see which one it needs. i may have some. glenn
  17. Pics of the machine? glenn
  18. WIZ. 29-4 did not have an eccentric for timing the shuttle. glenn
  19. They are rare. No reproduction made to my knowledge. You could contact Seiko and see if they still make the extension plate. glenn
  20. Needles available on line or from Toledo Sewing. You need to determine the class first. The 1 and 2 use system 81 needles, the 3 uses system 88. Can we see a pic of the machine? glenn
  21. New the machine head only is a t least $2500.00 so no $900.00 is not a bad price. They may have cannibalized it for parts which I never do. It is great that you can get the parts. I have a Juki 1508. Had it for over 20 years good machine. it replaced the LU-563. Get all the books on it if it did not come with it. part list, operations manual, engineering manual. You will need them. glenn
  22. Is there any numbers on the cover on the horn? It would either be an 81 0r 88. Also, max. stitch length should be 7.5mm glenn
