shoepatcher
Everything posted by shoepatcher
  1. Your following gear teeth are chewed up. I have them. Make sure the set screw holding the drive gear onto the shuttle carrier shaft is all the way in. If it sticks out any at all, it will stop the gear from turning. glenn
  2. You have a part number? glenn
  3. It's what applies pressure to the outside foot and will effect the feeding of the material you are sewing. glenn
  4. bar should be remove to determine the length and the diameter of the bar. Consew made a copy of this machine. glenn
  5. Double needle walking foot machine. H3 so 11mm height of foot. 6mm max. stitch length. glenn
  6. The Bell crank made today is for the later 29K models. The one you get today will not fit your machine without a lot of grinding. Just so you know. glenn
  7. Use a sized wrench instead of a crescent wrench. Works better. glenn
  8. I do not use one but it should bring more. If you can get it for $400.00, grab it. My expertise is in sewing machines. glenn
  9. Worth a lot more that. New they can approach $2,000.00. Italian made they were. glenn
  10. give MJ Foley a call and ask for Give MJ Foley a call. Ask for Luke. They were the largest Pfaff dealer in the US at one time, glenn
  11. You want to use a penetrating oil on it. WD40 is not it. The best you can buy Is Kroil Oil. But NOT CHEAP!!! glenn
  12. I would call Consew and see what a genuine needle bar #10530 bar cost. Then I would call Henderson Sewing in Alabama. They showed a generic one in that catalogue. Price and availability will determine whee you get it. Also, check your bobbin supply and if you need any, order them as well. glenn
  13. Use Greased Lighting and sewing oil to clean up the machine. Call Consew direct and sew what the prices are for the part. The needle bar part is indeed #10530. see if they changed it. glenn
  14. The needle is not in alignment with the feed dog hole . The clamp screw to undo the needle bar in the rock frame is behind the little plate next to the reverse lever if I remember correctly. Loosen that screw and then you have to slowly by hand turn the wheel towards you which will make the needle descend. You then center the needle in the feed dog and tighten the clamp slightly. Turn the wheel again by hand and check the alignment. If good, tighten the clamp. However, you have to make sure the feed dog is correctly positioned before doing any of this. glenn
  15. I have the parts list and the operations manual for the 105-64. Only in hard copy though. glenn
  16. Consew 226 just like Singer 111W 155 but with reverse. Timing the same. glenn
  17. Yes the 29x 3, needles basically the same as the 135 x 17, which is the same as DPx17. All round point. The 29x4, 135x16, DP x 16 are all leather points. glenn
  18. Great. Make sure you sew on it before buying it. Some parts for it are hard to find just so you know. Glenn
  19. if you want to use heavy thread, the 105-64 would probably be the machine you want. Still they cost more than $1000.00. More like $1500.00 You look and wait for something to come up. glenn
  20. Round point for sure. Not sure what machine you are using. Truck toe lines out of 3"-4" webbing are usually sewn with at least #277 thread. I have seen them sewn with up to #415. Try Shelton Reynolds in Wisconsin. They use to carry huge amounts of webbing in all different weights. Seconds and over runs. glenn
  21. I forgot to add the 669 classic or gold edition as I call it has a different hook because of trim knife. Plus, instead of the narrow slot, there is a 1/4" box hole in the needle basket to allow for the bigger needles. Just be aware of that if you go with the 669 Eco because it has a horizontal hook. The 869 has a vertical hook and will sew a little heavier material. Both are great machines and the Cadillac in their respective classes. glenn
  22. Ok I have a 669 Eco. One thing you have to know about the Eco model. The largest needle you can use on it from the factory is #150. I sew mostly with #138 thread and prefer the #160 needle because of deflection. I sew a multitude of of materials so the #160 needle is paramount to that thread. I solved the problem by removing the bobbin basket and enlarging the slot in it that the needle goes thru with a combination of carbide bit and diamond bit and carbide Mitchell card. That metal was hard let me tell you!! It now will handle up to a #180 needle. Fixed my buddie's 669 the same way. Adler in their infinite wisdom uses the same hook in the 669 Eco as they did in older 367-373. Why they did not make it to accommodate the #180 needle is beyond me because the 669 Gold edition with toys lets you run up to a #180 needle. Go figure! When you order one, specify the 9mm stitch length vs. the 6mm stitch length. Better to have in and not need it than need it and not have it!!! glenn
  23. You need to post a commentary about each machine and picture. All I got was up to the 144 as to pics
  24. Check out Kwok Hing. they make some pretty good parts including binder for 205. Not sure on the Cowboy 4500 which is a clone of the Juki 441 glenn
