shoepatcher
Everything posted by shoepatcher
  1. that cover should fit!! glenn
  2. I would also try the clones for the 1341. Those caps should work. glenn
  3. There has to be a way to move the left saddle for the hook. Take the left hook out and send us a few close ups of the left saddle. glenn
  4. Machines that fit the bill: Older machine Adler 205 and clones Juki 441 and clones Cowboy 3200 Artisan 3200 need more specifics thread size, arm length,
  5. pics???
  6. Let me check. The red paint does not look cool in my opinion. I will check this weekend. Too busy today. glenn
  7. You also need a drip pan unless you plan to get oil on your knees while stitching. glenn
  8. Looks like a narrow throat champion needle and awl stitcher.
  9. Anybody got a copy of an operations manual to a Singer 132K6. All I have is the parts list. Thanks. glenn miller
  10. Should be able to. Binders normally built to specs.
  11. Can you send us a video on you threading the machine? We might be able to tell something from that. glenn
  12. Contact Luke At MJ Foley. He should be able to get you the bar in either genuine or generic. They were and are still Pfaff dealers. glenn
  13. I have done the same with most of my machines C including the new DA669. I have not problems. glenn
  14. The smallest needle size that will accommodate #138 thread is #22/140. A size #20 needle will not sew #138 thread! If you are using a #160 needle, you have to enlarge the hole on the feed dog and move the hook as to left and right. I did this on my Pfaff335 and the machine sewed fine on materials. However, I do not sew veg tan leather on this machine! glenn
  15. Those were the last Singer shoepatchers made at the Kilbowie plant. Production moved to Japan and the U series after that until about 1985. glenn
  16. That machine has not been built in at least 70 years. parts are not easy to come by. A few people on the is forum have some parts. Probably better luck in England finding parts. glenn
  17. It should handle depending on how hard the leather is. glenn
  18. The large balance wheel looks like what Ferdco used> glenn
  19. Sewing Bill. I think the largest stitch you can get on a 111W156 is 5mm. or 5 spi. glenn
  20. The 206RB-1 was made in Japan by Seiko. The 206RB-5 is made in China. Keep that in mind. glenn
  21. Can you read the model number on the plate? will help us advise you. glenn
  22. Cannot believe no one in Germany beside Constabulary can help you with this problem! That is Adler home territory!!!! glenn
  23. 1/4" to 5/16" depending on the type of leather. glenn
  24. Yep Pfaff 483. glenn
  25. The Singer 111W155 will sew #138 all day long. However, no reverse and G size bobbin. Certainly in the $500.00 budget. glenn
