shoepatcher
Everything posted by shoepatcher
Where did you get them? glenn
I found a Ferdco/Juki Pro-2000 but I need some parts
shoepatcher replied to JJN's topic in Leather Sewing Machines
Genuine contact MJ Foley in Detroit. largest Juki dealer in America. Generic Bob Kovar at Toledo Sewing or Steve at Cobra in California. -
Help! I'm reaching the end of my tether!
shoepatcher replied to Cymro29k3's topic in Leather Sewing Machines
Timing out. glenn -
The adjustment on the back of the flat tension spring is set at its lowest position meaning that foot has almost lift. As Folker stated, Loosen the wing nut and move the block clamp to the left like in Folker's pic. That will raise the walk height of the foot. A lift lever from a 29-4 machine should fit yours. glenn -
A 29K3 is a lot like a 29-4 in that it has a solid horn. The problem with these machines is the area in the horn around the bobbin case wears and the only way to fix it was an insert put into the bobbin case area that took up the wear. I looked at doing this years ago and then the clones came out so why bother. The other problem as Folker mentioned was this: there was no adjustments to take up the wear on the parts. Once they wore, you had to replace them. With Pilgrim Shoe no longer in business, the source for parts for these early model machines has dried up i.e., pinions, needle plates, screws, etc. glenn -
The one thing you forgot to mention is what weight of thread you be sewing with. That has a baring on which machine to get. glenn
That looks like a copy of a singer 211. Maximum thickness to sew would be about 3/8". These machines were designed for the auto industry upholstery and seat covers. maximum stitch length was 5-5.5mm. glenn
I prefer to use round needles on soft leather. That's just me. Wiz might have better insight for you on that question. glenn
I forgot to tell you I have drawers for your Singer stand. I had then made here in the US by an Amish drawer maker. These are to the original specs, dovetailed and unfinished so you can either seal or stain it. Your choice. glenn
Steve, I wish I had known you were looking for parts. I have most of the parts you are seeking as well as the original stands for Adlers. You can use big bobbin hook and bobbins from Singer big bobbin machines. I new genuine hook from Adler is about $234.00 and change. Generic Singer hooks will work in this machine. A lot of pats for the 30-1, 5, 7, 15 are no longer available. Let me know if I can be of any assistance. glenn
What should I look out for when buying a Durkopp 291?
shoepatcher replied to MrBurns's topic in Leather Sewing Machines
Isn't that that Pfaff 145? If so, a good machine -
I would agree. Get a simpler machine to start with. glenn -
Rather than try to explain it, I think UWE or Wiz has a video on how to adjust it. I would try that first. Take your finger and see if the take up spring which is to the left of the tension adjustment nut and flick it up a couple of time to see if it hangs up at all. That is sometimes and indication if the spring is not functioning correctly. glenn
Black always stiffer. I still think the take up spring needs to be adjusted a little more. Tension not always just top and bobbin tensions springs. Take up spring can cause or correct some problems. glenn
Weaver indeed coming out with the machine in the spring. Will have the hand crank instead of the pull down handle. This should make it easier to use than the Cub or Boss. I do not know about reverse. As I know more, I will post. Glenn Miller
Adler 105 with extras on CL in MD
shoepatcher replied to SilverForgeStudio's topic in Leather Sewing Machines
Nice machine for the price. Looks like a 105-64. glenn -
You can get parts from Adler but be prepared to pay handsomely. glenn
C, From what I hear, surgery cures for a while but it comes back over time. My late aunt had it done years ago and went back to work in about 3-4 months. Two years later it was back and she had to retire on disability. Not fun.
Singer 108W20 - My New Binder Setup
shoepatcher replied to Constabulary's topic in Leather Sewing Machines
Costabulary, Great job on the Singer 108. Really looks good. glenn -
Contact Bob at Toledo Sewing or Luke at MJ Foley in Detroit. You can get a generic hook by Hirose of Japan or Cerliani of Italy. Both make very good generic hooks and will be cheaper than an original Adler. I have used both manufacturers for years. glenn
Can anybody identify this Consew?
shoepatcher replied to strathmoredesigns's topic in Leather Sewing Machines
Looks like a bottom feed machine. older. may be good for light leather. glenn -
How long is the reverse stitch? glenn
The 367 has a horizontal hook. Weaver sold them for a while but had trouble with them sewing heavy leather. Horizontal hooks with the exception of the 3200, 441 and 205-370 do not sew as well as vertical hooks in heavy leather. The aforementioned have barrel shuttles which is different. Those are proven. Don't get me wrong. The 367 is a good machine but not for sewing heavy type leather. Adler only had the machine out for about 5 years is I remember. just my 2 cents. glenn
- 16 replies
- durkopp adler
- 767
(and 1 more)
Yeah, But believe it or not, I found less problems with machines with the toys vs. without the toys. With the toys, the machine cuts the thread and holds it to start the next stitch. To many beginners have problems holding the thread when you start sewing. The machine helps eliminate some of the other problems. Just my 2 cents. Figure out which machine you want first. Then check dealers around for best price. if you are buying a new machine, buy the 867 Adler Eco or look at the 2810 from Juki. That is Juki's copy of the 867. I hear good things about it and it is cheaper than the Adler 867. Adler's are the best, no questions asked. Contact MJ Foley in Detroit and see what their prices on both machines are. I always contact multiple dealers for prices. Like buying records, who can give you the best price and service. glenn
- 16 replies
- durkopp adler
- 767
(and 1 more)
