Stetson912
Everything posted by Stetson912
  1. For something that large I would be worried about it sitting too long. I would work in sections. For application, sheep skin is great. It's used for lining saddles but it's great for applying antique. Use paper towel for wiping it off. If you cant find any sheep skin (saddle shops might let you have their scraps willingly) just use a wool dauber in circular motions. Really work the antique in and wipe off excess.
  2. Gotta start somewhere, and you improve and learn best by messin up leather... if only it wasnt so expensive hahaha
  3. This looks great. I want to commend you for stitching in the buckle. So many designs these days use rivets or screws but I've always been partial to the stitched method.
  4. Well crap, now I have to make one haha. That's a good idea. Those mallets are kinda ugly with that bright yellow. Very clever idea I haven't seen before, and simple too. Sometime simplicity and necessity are the best inspiration.
  5. I've started carving my flowers first, then secondary elements like any leaves. Then any other elements like smaller leaves and scrolls then the vinework starting with the stems of flowers and secondary elements. I bevel much the same order. With vinework I start with flower stems and move outward one side at a time. Usually, you bevel towards the background. That's how I see it anyway. Usually with floral, the vinework on each side of the center/main stem is layered. One sticker will be above another etc all the way to the background. That means they all bevel towards the background on the same side of the line. The other side of the main stem would bevel the other way. I hope that all makes sense haha. maybe itll help? Seeing the pattern background is hard to start, but gets easier, as you said, each time you do it.
  6. Bargrounding is tough for me. And this pattern is a bit small so I lose lines sometimes. I've started focusing more on foreground to background tooling order and its helped a lot. Before I would just tool but changing the order like that really did help the overall look
  7. Practice k adam tanner wallet pattern.
  8. If I remember correctly, theres a rather sizable detailed video or two by tony allen bernier on youtube about making a flat cap. His are lined that I've seen. It's possible that may help.
  9. Thanks Thanks. It was fun. I've seen a lot of them with bullet loops. I'd like to see it when you get it done!
  10. Qasnt too bad. About 6 hrs for me. Being slow. 8 if you include drawing the pattern. I rushed the tooling because I wasnt comfortable in my shop stool. Learned a lot too. I need one for my rif and e next haha may have to change it a bit Thanks for the kind words
  11. I'd like to see it if you make one. I bet it will look really nice.
  12. I'm no great Carver either. Just takes practice. Thanks for the kind words. It would look nice stamped with an arrow basket weave I think *hint hint*
  13. Awesome man. Good to see you back. I've been.meaning to get around to making a pocket organizer. All projects look good. I like the wrap on the first skiving knife too
  14. This was for my uncle. Its pictured on my gun but I made it for his. So I honestly cant say. But if I ever get around to making one of my own, I would definitely wrap the lever in some way.
  15. Thanks it was fun to do. Thanks Munky, it was a lot of back grounding. But turned out ok I think Thanks! I don't know. I made it for my uncle. No complaints yet though. I did skive it a little thinner than the leather i used for the rest of it. I wouldn't think it would be uncomfortable. I didn't fire it but I shouldered it and it felt about the same as normal. His is also a .357 mag instead of a 30.30 like mine
  16. Hans atelier on youtube has two videos making very similar airpods cases. Along with patterns. You may want to look it up. I think that design is actually done by him as well
  17. All I can think of for chrome tan is edge paint. Which I'm still figuring out myself. Edge kote (a feibings product) might work also. There are lots of types of edge paint, but I personally use indelible brand from makers.
  18. Finally finished this stock cover for a model 94. 100% leather construction. Lined with deerskin and laced together. Even the back strap is laced in and tied off. I'm happy with how it came out, especially since I dont own a lacing chisel haha
  19. Well, that's frustrating. But, I have had that problem before as well. What I did, depending on how much more room you need, is I took a spade bit the size of my snap and drilled out the depth I needed. If you have a french skive you can do much the same thing. Basically the idea is to cut away a circle of leather just wide enough that your snap sets lower than it would. And, if you are worried about the line coming up, stitch around the snap. Unfortunately 7/16 I think is as long as they get. You could try and separate the layers and set the snap between the layers as well. But you wouldn't be able to use the cap part, just the flat base post for both sides of the snap. Anywho, hope my experience with your frustration helps a bit
  20. Hope it works out for you
  21. Looks great. Nice job
  22. Well if it were me and I had to rely on math, I would do this for a starting place: Leather dimension = phone dimension + phone thickness+ 2x leather thickness + 2x stitch allowance + extra If needed. I would make the width of your case 76mm + extra (maybe 8 mm?) Total 86mm. Obviously this isnt exact and may vary a bit. But should get you close. The extra to add will depend on how loose the phone needs to be. Then do the same for the height. That being said, I would recommend making a blank. You can make one out of leather scrap too if you need too. And cardboard works well also for basic shapes like most phones.
  23. Bummer, I also stopped ordering from them.. well leather anyway. I got some caiman and its junk. Still rawhide in the middle and damn near impossible to cut. I get what I need elsewhere.
