Thanks SOSHorses.....the pages are held in with two screw posts.....it's a very common system found on photo albums. The screw posts are covered by the flap.
Hope this helps.....
Bobby
ABC3,
Here's some info on edge burnishing.....it's located under "More Tips & Tricks" on the LW fron page......Finishing Edges.
Hope this helps.......
Bobby
Ken,
I think that making a comparison between the two is comparing apples and oranges. They each have their place but do not really perform the same. I have never used the fantastic burnisher...I have only seen the video demonstrations. It appears to me to be a really fast system. Weaver's system performs more functions but probably doesn't burnish as quickly. In my opinion the Weaver system would be a little more versatile and easier to use on different thicknesses of leather. I think you would probably need to decide what you would need the most....speed with some limitations on weight of the leather to be burnished, or more verstility with more effort or steps required for burnishing. With the Fantastic edge burnisher you must dye the edge before burnishing because the wax used prevents you from dying the edge after burnishing. I personally do not like to dye first because I cannot get as clean a dye line on an unburnished edge. So I like to burnish using heavy canvas and saddle soap so that I can dye my edge after burnishing. I use a Weaver system that I modified, however I am not trying to get a lot of edge burnishing done quickly and I think this is probably where the Fantastic system shines. Here's a link to the method I use.....Finishing Edges
Hope this helps....
Bobby
Tim....I use a couple of different brushes. One is very narrow and one is larger. I use the smaller one the most but when the area is large enough I will go to the larger brush. I have never airbrushed before and would like to learn, but I'm not sure that would be a good place to use one. Dying with spirit dyes can get trickey, but after awhile you learn to make the "spread" of the dye work for you instead of against you.
Hope this helps....
Bobby
Without being able to handle it and look it over.....assuming that the steel is in as good a condition as it appears....the handle is tight and not cracked....it is in my humble opinion worth much more than $70. I have one excatly like it that I bought from Bob Douglas and I paid a LOT more than that for it and I wouldn't sell it...period. This knife is a hundred years old (I believe) and if I was looking for that size in a Rose again I would snap it up. I think that Douglas would knock the shoulder off...clean it up and sharpen it and sell it for $150.....or more....
Bobby
Welcome Jim, glad you found us! There are several excellent saddlemakers here and a few of them make a living punching cows as well so I know they can answer any of your gear questions.
Bobby
Really nice job on the briefcase! Stitching, tooling, everything is very well done. Is it lined? Also curious about what machine you used to sew everything. Looks very good!
Bobby
If you have no way of sewing them on you could use some heavier leather lace....1/4" or something like that and just use a running stitch to lace them on. Probably the best thing to do is to take the blankets to a local saddlemaker and have them put them on for you.
Hope this helps....
Bobby
Here is another one. When I first got Vista I was having troubles resizing and then I found this free program on-line.....Prish Image Resizer....it enables you to resize photos by right clicking and selecting a pre-selected or custom size....it then saves a resized copy without affecting the original. Very handy...nothing to learn....and it's free!
Hope this helps....
Bobby
Sorry it's taken me so long to respond....I didn't see your post. I'm not real computer savvy but if it were me I would open the photo to it's largest size...then right click and select "save picture as" which should openb a new window in which you can re-name the photo and select a file to save it in. Then you can go the that file, open it and print it. You don't have to save to a file either...you can just save it to your desktop if you want to and then delete it when you're finished.
Hope this helps....
Bobby
Storm,
Another really geat piece! Have you ever seen the Pebble backgounders? I think it is great choice for very large backgrounding areas where it is difficult to avoid the tool tracks. Great job....again!
Bobby
I've seen the damascus blades at Tandy and hefted it and looked it over...did not have an opportunity to cut with it. I thought the handle was not very well done and I just didn't get the feeling of holding a high quality knife. I'm sticking with the old Gomphs and Roses' that I have on my bench for the same or less money. I would rather spend more money and order a Dosier that will retain it's value rather than have a questionable damascus import. I'm not saying that they are bad....I just think there are better proven knives at that price level.
Bobby
Leatherhead,
The tool you are lookng for is a French edger. It will allow you to create miter edges. There is a learning curve regarding the use and sharpening but it will work very well if it's sharp. If it were me I would cut the the whole thing out where I could fold the sides up and only those edges would have to be sewn or laced together. Maybe that is what you're intending to do. If so you will use the adjustable gouge at the fold line to help the side fold.
Hope this helps...
Bobby
Hey Tommy....I missed this one! Great job. I like the colors, the tri-weave, the skull, the lettering...everything is neat and clean. I like the adjusting strap, although I hope it won't have to be moved very often. Very nicely done.
Bobby
