hidepounder
Contributing Member
  • Content Count
    1,808
Everything posted by hidepounder
  1. Ed, That's really nice stuff. I've been wanting to do some coloring like this....now I know who's work I'll use for reference! Nice job Ed, it's top notch work! Bob
  2. Tina, Absolutely beautiful as always....your work is always spectacular! I'm particularly facinated with the tri-weave mix on the binding and the way you incorporated a tri-weave circle under the binding. These are the things which really create depth and distinction in your work! Masterful!!!! Always a fan, Bob
  3. I think I would take it up with the customer....explain the design problem. You might suggest using his initials in a mongram style, centered on each side as an alternative...... Just a thought... Bob
  4. King's X, I'm really glad my process has worked for you! I have learned so much here and it is really nice to know that something I've shared has helped others in return. Keep up the good work and thank you for the recognition...I'm humbled by your comments! Bob
  5. Rusty, I used to copy patterns like that a lot! Still do from time to time. If you lay piece of medium/heavy paper (a paper sack works good) over the tooling, and then with a #2 pencil laid flat, just brush the lead back and forth and the lines of the pattern will emerge. Then you can trace it! Bob
  6. hidepounder
    tiger
    Absolutely stunning, Bobocat...as usual. I love the colors! Thanks for sharing! I'm a Bobcat fan! Bob
  7. Get well soon Badger! Sounds like it's all downhill from here on.... Bob
  8. Mark, Thanks for keeping us uptdated. This is a tragic loss for the leather community....he will be missed!!!!!
  9. Great shop Randy!! I'm really envious....I can't even imagine how nice it would be to everything in it's place and ready to use! And WINDOWS!!!! Wow! Bob
  10. Thanks David! I always appreciate a kudo from a master! Bob
  11. I guess because until there were motorized burnishers, it was a hell of a lot of work! That has always been part of the problem....people don't really want to commit to a complete finish if it means more work than what it took to tool or build the piece! I didn't not invent the process...it's been the standard practice of saddle shops, for years! Bob I guess because until there were motorized burnishers, it was a hell of a lot of work! That has always been part of the problem....people don't really want to commit to a complete finish if it means more work than what it took to tool or build the piece! I didn't not invent the process...it's been the standard practice of saddle shops, for years! Bob
  12. Johanna.....How would I know, I can't see back there...are they permanent and is there a cure? Seriously concerned! Bob
  13. Bruce, I have started to buy a plough gauge couple of times and was just too tight to turn loose of the money. Douglas loves them like you do! What I want to know is are they good for stripping narrow widths and how well do they work on light leather. I've discovered that when I was stripping out 2/3 oz or 3/4 oz leather, my draw gauge wanders.....it's extremely sharp and with the light leather there is not enough resistance between the blade and the guide to keep me cutting straight. Bob
  14. Thank you, I appreciate it! Here is a link showing the finished product .Click Here Bob
  15. Brushpopper, Here is a thread regarding burnishing. Click Here. Hope this helps! Bob
  16. Beautiful edges Kate! I'm glad this has worked for you! Mission accomplished for me. I do want to make one clarification however....I burnish with canvas that has been wrapped on a Weaver burnishing wheel....I do touch ups by hand however. Bob
  17. Janice...yes I was referring to a jig like Tandy sells. Chuck Smith makes a really nice one also. For now a strop with white rouge is all you need. As for patterns, those sources are great! I just wanted to make the point that you want to copy an accomplished tooler rather than a novice. Bob
  18. I wasn't going to say anything....but that occured to me also. Then I thought maybe it is supposed to.....
  19. Really great job, Ed! The mauls are beautiful and so is the stand. I love the inlaid leather makers stamp....it really looks professional! Bob
  20. Hi Linday, When you say stain, I assume you are talking about a light color coat over the entire piece. An antique finish, say. That, you would do after oilng. If you are talking about using a dye....then that should be done before oiling. Before you you dye, oil or antique, you should clean the leather with oxalic acid. This will help to remove and dirt or oils from handling which can affect how the the final color comes out. Really, we could use just a bit more info in order to better answer your questions. Bob
  21. Thanks, Spinner! I appreciate your comments. Bob
  22. I was talking to Barry King, yesterday...he will be there....
