Everything posted by Pintodeluxe
JUKI 563 thread snagging on bobbin case
Pintodeluxe replied to matcanada's topic in Leather Sewing Machines
Hmm, I've never seen one snare thread there. Surprised it isn't a more common problem. Dave has some good suggestions to try. You're not getting thread caught up on the thread stand somewhere? If so that might artificially increase upper tension and cause something like this. -
It's pretty easy to replicate with Rust-Oleum hammered spray paint. I use the dark bronze color. There is also a dark grey color that looks good. Get a couple cans and spray on cardboard as a color sample. Once dry, pick the color that matches best. The key is to fade the paint into the original. Most people paint to a tape line and the transition is obvious. If you fade it in it looks much better.
Hey Dan, That's my Pfaff 545 in the picture above. You're welcome to come try it out if you like. I also have a Juki 563 that's not for sale, but you could compare the two to see what you prefer. The main difference between these type of machines and the Consew 206rb is the way the bobbin is loaded. 206 is a side-loading bobbin, while the 563 and 545 are top loading (drop-in bobbin). I prefer the top loaders, but some people don't care either way. Cheers, Willie
I have a 563, and added the Family / Rex type servo Wizcraft linked to above. Mine uses a 45mm pulley and it worked just fine that way. Then I added a box-style speed reducer, and it can sew ridiculously slow or normal speed. The speed reducer was almost overkill, but it's nice to have punching power on thick seams and intersections. I don't have the needle positioner, and really don't think I need one (with or without the speed reducer). Good luck and happy hunting!
I've run Juki walking foot machines with and without a speed reducer. I like both just fine. If I was setting up a machine with servo only, I would for sure install a 45mm motor pulley. They cost about $2 on eBay. Good luck.
Changing pulley on a Family Sew motor
Pintodeluxe replied to mcdoug's topic in Leather Sewing Machines
The 45mm pulleys I got off eBay were about 2 bucks each, and fit the Rex / Family servo just right. If it's not easy to modify, just order another pulley. Good luck. -
On the 226 and 206 machines, I've been surprised how often Rustoleum Dark Bronze hammered spray paint is a dead ringer for the factory gray. The best thing to do is get a couple different colors from at least two brands, and spray a piece of cardboard with each color. Let it fully dry and hold it next to the machine to see which matches. You shouldn't have to repaint the whole head, just remove the parts you can, and mask the rest. Then blend the colors with no sharp lines anywhere. I've also noticed the underlying color affects the finished color. So I usually spray it with gray primer first, then the hammered paint. Regarding the cover plate... they are widely available from sewing shops or Ebay. Good luck!
I have sanded them smooth with emery cloth. If they're grooved it's best to replace them. When tension's not right on a sewing machine... nothing's right.
I would spend a few minutes trying to rule out a thread problem first. Thread stand and threading path look good? Any thread caught in the bobbin case area? Did it get knocked out of time again with the thread jam?
How can I tell if a machine is a 563 or 563-3?
Pintodeluxe replied to blackmad's topic in Leather Sewing Machines
That's a good question. Can you add a picture of the right side of the head? I'd like to see if there's a bracket for the reverse lever there. It's usually black, and functions as a limit for the reverse lever travel. Here is a related post you might find useful. -
Juki LU 563- disable reverese lever spring
Pintodeluxe replied to stor's topic in Leather Sewing Machines
You don't want to remove or bypass the reverse springs on a 563. You can hook up a foot pedal reverse via light chain. The simplest way is to operate it with your right foot. I have one on my 563, but ended up unhooking the chain because it's a hassle to remove when you need to tip the machine back. Plus it's super awkward to use your right foot. I learned on a machine with a left foot reverse so that feels more natural to me. However, it requires a rod with bearing blocks to locate the pedal on the left. It wasn't worth the effort for me. I actually really like the large reverse lever on the 563. It's so big you can't miss it. -
Juki LU 563 or new Sailrite Fabricator?
Pintodeluxe replied to RecklessRed's topic in Leather Sewing Machines
I might be biased because I use a Juki 563 as my primary machine. It is built like a tank for an upholstery weight machine. I never weighed it, but it feels a good 5-8# heavier than a comparable Consew or Pfaff. I had been running it with a servo, and it worked great. I added a box style speed reducer recently, and it really feels powerful and easy to control now. If you look at the details of how a 563 is put together, it's quite impressive. -
I highly recommend this type of speed reducer. I've had the standard double wheel variety of speed reducer before, and depending on where it's mounted you may not be able to tip your machine head back. With this box style reducer, everything sits in just the right spot. No new holes in the table, and you can still tip your machine back normally. They perform great!
consew breaking top thread on 4 layers not 3
Pintodeluxe replied to wilsonintexas's topic in Leather Sewing Machines
Needle bar thread guide in place and intact? -
That is gorgeous! The color and texture of the leather play so well against that shiny red paint.
- 7 replies
- scout tank bib
- indian tank bib
- (and 3 more)
Do the feed dogs seem like they're set really high? I've used machines that seemed to push the material forward slightly before feeding it backward. After going through the entire timing and adjustment routine, it was just the feed dogs set too high. That's the first thing I would check. Is this a CLPMN version 145 or something else?
Which one would you keep? Seiko STW-8B or PFAFF 1245?
Pintodeluxe replied to katit's topic in Leather Sewing Machines
I've had a Consew 226's and they are an elegant machine. I too like the push down to reverse. I also had an older brown 1245 and was really impressed with it. The 1245 was one of the few machines that I feel as good sewing on as my Juki LU-563. Big bobbin top loaders. That's where it's at for me. The Pfaff has that. My 1245 built in bobbin winder didn't do a very good job (no tension discs) so I used a table mounted winder. My advice... Do your next two projects without thinking about it. Whatever machine you sit down at is the one to keep. Sometimes stats don't matter as much as what you like. Good luck with a tough decision. -
I've made a custom tabletop for a Consew before, and it can be done. Mine was for a 226, but it's the same size opening as a 206rb. If you're handy with woodworking tools, it's easily managed. However, if it seems like more work than it's worth... it just may be! I had all the right tools and bits in my shop, so I decided to make a custom opening to fit my machine. I have switched the machine out since then, but still use that same table to this day. To size the opening, just make it slightly longer and wider than your machine. Here is my detailed blog on the subject with photos... http://lumberjocks.com/pintodeluxe/blog/112633 Good luck!
Consew 226 or consew 206rb?
Pintodeluxe replied to ErinTwinFlameLeatherCo's topic in Leather Sewing Machines
The 226 is a top loading small G style bobbin. You push down for reverse. The 206 is a side loading large M style bobbin. You lift the lever for reverse. The 206 is considered slightly more heavy duty, but the 226 is an elegant machine that wins in terms of ergonomics. I would pick the 206, but it's a close call. -
If it is a 145 it has an adjustment to raise the height of the feed dogs. Pull the manual to learn how, but as I recall it's pretty easy to do.
It's probably just the knee lift mechanism is slipping off the roller as it engages the machine. That's a simple adjustment with basic hand tools. If the hand lift works normally, but the knee lift clunks, it's likely an easy fix. I'd go for the 563 for sure. That's what I use, and much prefer it over the 562 because of that huge U style bobbin.
I agree with the others, I install the pulley so the raised "hub" faces the motor. The best tool I have found for the job is an impact driver and socket. It makes short work of removing the old pulley and installing the new one. Just make sure to wear gloves to save your hands.
- 9 replies
- consew 205rb
- servo motor
(and 1 more)
The Rex / Family type 550W servos work fine. I usually swap the motor pulley for a 45mm pulley. This slows it down even more. The dial will let you adjust the max speed. If it isn't slow enough for the work you do, then you'll have to add a speed reducer.
Pfaff 545 - Tread Pickup Lever Lifting Product Up
Pintodeluxe replied to Kryptonite's topic in Leather Sewing Machines
I like Wizcrafts comments to lower upper and lower tension. Did you decrease the upper thread tension and decrease bobbin thread tension too? That makes sense to me as one fairly simple cause. The take up lever is trying to pull thread, but tension somewhere in the thread path won't let it. I assume you're using a standard thread cone on the stand.
