kgg
Contributing Member
Everything posted by kgg
  1. To sew the thickness of leather you noted you need heavy iron which does take space. Mounting a machine on a table with wheels and having a smaller foot print may help. The only other option is maybe a one armed bandit like the Outlaw but they still will require a fair bit of working space. kgg
  2. Just to add to the confusion when you by a servo motor you need to know if it is rated using the Metric horsepower or the Imperial horsepower rating. Imperial HP has 745.7 watts and the Metric HP is 735.5 watts. Maybe the horses in the metric countries were a touch smaller and a little less powerful. haha kgg
  3. It I think will come down to your thread size that you want to use. The machines that you have listed are going to limit you to small thread sizes range. Have you considered a patcher like the Cowboy CB29 that will allow you to sewing in tighter spots and use up to V138 thread? kgg
  4. My bad, you are correct. kgg
  5. I feel your pain, there is never going to be a exact conversion between Metric and English measurements. In Canada we often buy items that are weighted in pounds but priced in kilograms, lumber is still mostly English while liquids are metric (1 litre = 1.057 US quarts or 0.88 Imperial quarts). Can get a bit confusing. The best you can hope for are approximate conversion values. The easiest thing is to get a good metric ruler / tape /meter stick (.9144 yards) and forget about trying convert, it will just drive you crazy. Personally I prefer the Imperial measurements. kgg
  6. If you are looking for a nice backup machine that won't take up much space I would suggest looking for a used portable walking foot machine. Like the Reliable Barracuda, Sailrite, Techsew 611 to name a some. kgg
  7. Buy a Juki that fits your present and foreseeable future needs. Buy Once, Cry Once kgg
  8. Like the idea. Maybe if you used a larger calibre spent casing like a 45-70 it could be used in the construction of a belt. Seating the bottom cutoff of the casing so the prong of the belt buckle would go through the primer hole rather than just the normal hole in the leather. What a shame. kgg
  9. That sounds about right. The size of cone you are using is approximately 4 oz. There has be discussion on the problems associated with the 8 oz cones particularly black in colour from China in the past. I can see that the problems would be that much greater particularly when you get down towards the last 10 to 20 % with such a small cone. I would suggest replacing the thread cone with a new one of a larger size (1 lb would be best), check the needle and size of needle making sure it is fully seated and installed correctly. kgg
  10. Some good advice given. I would for upholstery class sewing recommend Juki DNU-1541S or Juki LU-1508n. For holsters definitely going to need much heavier iron in a 441 class machine. kgg
  11. Have you tried contacting / checking out American & Efird at http://www.amefird.com . Great quality thread with the technical specs of their thread available. kgg
  12. I think it looks to be similar to a Durkopp Adler 867 single needle machine. kgg
  13. The amount of magnetic field is not only going to depend on the size of magnet but the type magnet you are planning on using. The best solution is to remove the magnet from the design and come up with a different method of attachment otherwise you may have some unhappy customers with scramble info on their cards. kgg
  14. Why not give "Current Applications" a call they are the company who manufactured the motor shown in the photo and they are still in business in Watertown, NY ( https://www.currentapps.com/ ). kgg
  15. Real murky, clear as mud. I couldn't find what a limited lifetime warranty includes / excludes in my searches. I like clearly defined warranties that way I know what I am getting / not getting. You are so close to both save the shipping charges / sewing shops markup and buy direct from either Reliable or Japan Sewing. When it comes to accessories folders, binders, needles, etc buy from Japan Sewing that is who Reliable gets their stuff from. Let us know which machine you got. kgg
  16. Reliable has been around since 1955.
  17. Totally Agree! kgg
  18. I have in the past own a Reliable Barracuda and had no issues whatsoever with it. It came with a test strip under the foot of what the machine was sewn off before shipment and worked properly out of the box. The warranty as with the 4300Cw was defined. I still can't figure out for the life of me what a limited lifetime warranty gets you, maybe just me. When I was looking for a flatbed machine I compared a lot of machines for what I thought I wanted / needed. Reliable was my number two choice. My number one was a Juki 1541S, which I bought from Chris at Japan Sewing Machine and Supply C. ( http://japansewing.com/ ). Their website is terrible but once I called and spoke to Chris about what I was planning on using it for they gave me some choices, Juki or their clone, depending on the pocket book. They had a machine setup for me to test on my arrival, no BS and went over the machine with me. None of the clones I tested came close to the quality of the Juki. Since you are probably close to Toronto I would call them first. They carry Juki and their own line of Juki clones. The price I paid for my new Juki 1541S was cheaper then what some wanted for a comparable clone. With such a large layout of cash make a trip too both Reliable and Japan Sewing they are about 25 minutes from one and another. Bring some of your stuff along and do a comparison sew off. Buy Once, Cry Once. kgg
  19. I agree, knock off or clone, not good. Clone -- A copy or imitation of something already existing, especially when designed to simulate it. kgg
  20. Guns are just tools just like a hammer. Some people for whatever their reason or need will carry either a hammer or gun in the middle of the back. Accidents do and can happen. Personally I don't think I would carry in that body location from a comfort point of view carry in that location. Someone who is trained will carry and store their gun in a safe manner. kgg
  21. Thanks mikesc for the link to an interesting article about brass and you might know California Proposition 65 be in there as well. kgg
  22. I would make a waterproof cover for your machine and put a moisture absorbing pad inside it. I would use the large ones like you use in an motorhome particularly if you are going to have large temperature swings in the garage. kgg
  23. I maybe wrong but I would consider the Bernina 910 hook as being a class 15 based on the bobbin needed is a class 15. The bobbins for the Bernina are probably slightly different in height/diameter and shape when compared to those of the Singers you mentioned. kgg
  24. That is why you need to go and test drive a machine. Buy from someone with a good reputation who will stand behind their machines. Best of luck on that one. kgg
  25. It all depends on what ones needs are going to be. Either brush or brushless servo motors are going to be a good quite, controllable and cost effective solution over clutch motors in most cases. Servo motors that have brushes are more the type that you see being offered on relatively inexpensive sewing machine setups that will probably work great on light fabric / light upholstery rated machines where bottom end startup torque isn't going to be a typical problem. The brushless type is more suited for heavier work of multiple layers of thick materials / leather where the bottom end torque is going to be the priority. Within both brush and brushless servo motors you can have a large variance of quality and it will depend on the what performance specs were ordered. My rule of thumb would be the more coils the motor has the better the performance ( power consumption, noise, longevity, torque, etc. ). A 12 coil servo motor will be better then a 6 coil if the quality of the controls etc. are equal. I think in some cases investing in a servo motor or upgrading the servo motor from brush to brushless maybe a better overall solution then adding a speed reducer pulley but that will depend on the users needs. kgg
